Mr.Gib wrote: ↑Wed Sep 22, 2021 10:56 pm
Hexsense wrote: ↑Wed Sep 22, 2021 10:21 pm
The second option is taller than the first one (source: see height versus width of 25c tire on 15mm id rim vs 23c tire on 19.5mm rim in this
figure where one is wider but another is taller).
I have such a mental block on this concept.
Doesn't a flexible material just inflate to a constant radius? I would assume the inside of a bike tire will always form some part of a circle - move the beads further apart and the constant radius gets bigger? So wider and taller? Never could wrap my head around the idea of some part of the tire resisting pressure more than another so that it will form a shape with variable radii, unless of course the material is variable in its flexibility and thickness, and then anything is possible I guess.
Yes, it does, almost perfectly. Your assumption is correct, for tires of the construction that are available to buy. The tread of course has variable thickness so the outer surface is not circular, but the casing (the fibres embedded in elastomer matrix) experiences high stress at normal pressures so the tread has virtually no impact on the casing shape, which is circular (constant radius) from the points of rim contact.
To be blunt: diagrams that "show" non-circular casings are purely imaginary for the sorts of tires used on road bikes. Even heavy-treaded gravel/MTB tires at low pressure have very little deviation from this. Except, of course, at the contact patch - the tire conforms to a hard surface and there's a mix of tire/surface deformation on soft surfaces. Even then, the casing will have near-constant radius between the rim and the contact patch.
In addition: there's a lot of confusion over the relevance of "volume".
For a start; which volume? If once specifies the volume of pressurized air contained by the tube/tire or just tire (for tubeless), then it's of secondary (if not tertiary) importance in almost all circumstances. As a thought experiment - compare two wheel/tire systems, identical except that one has a deeper rim well. The volume of air is larger in that one (simple geometry). What are the effects? Assuming that we're talking about "normal" sized tires - let's say an actual 23mm tire on a 700c rim - then about the only practical effects are rim brakes heating the pressurized air; the greater amount of air takes a bit longer to heat up (still a very small change), and potentially much better sealing for tubeless tires - probably a significant, worthwhile advantage.
As for what you would feel on rough/bumpy tarmac (that almost-mythical ride quality) between the two differing volumes ? Nothing. The tire doesn't know the difference because there's virtually no change in air pressure as the casing deforms on normal surface irregularities (roughness/bumps). This is why the pneumatic tire works so well!!!!
Volume in terms of actual tire size is obviously completely different - it really matters, a lot. I'm also of the view that modest changes in shape* (actual tire width combined with rim internal width) can be detected by sensitive riders - as can 5psi on a given setup at "road" pressures of say 75psi. As a rule of thumb for myself - I can't be sure of a 5% change in pressure, but I can usually detect 10%.
*this is a change in the cross-section radius
