Nice catch, and I must say, a bit of a letdown...RDY wrote: ↑Wed Nov 09, 2022 12:32 pmBtw I don't know when this changed, but potentially of note is that Seka now state in their FAQ that the frame has max clearance for 28mm tires (not 30mm), according to ISO guidlines (4mm clearance left and right). If they've revised it down by 2mm, then I'm guessing 32s are indeed a no-go.
Seka Exceed RDC
Just FYI for those who ordered from Canada (might be the same for US)..
Here's my brokerage receipt with UPS (not DHL as I was expecting...) It looks like they declared the the shipment as "OTH JEWELLERY,BSE MTL,W,WO PLT" with a value of 200$, which I find a bit weird as there are duties for this HS code. I will check the box once I receive it tomorrow, but the good news is that normally I would have had to pay taxes on the total value.
Thanks. On their order page it says:warickwrx wrote: ↑Wed Nov 09, 2022 12:28 pmThe BB is a standard T47 type.So any inboard T47 BB matched to your crankset spindle diameter should work. On other builds I have found the Token BB's to be of decent quality. The frame should come with headset bearings, however I recall someone mentioning they are slightly shallower when compared to FSA ACR versions. Maybe something like a FSA SL MR110R would work for the upper.
"An optional CNC machined bike computer mount is available for continue the clean lines."
I don't see such an accessory in their shop though. I do see the BB and the direct mount hanger there, but not the computer mount?
Perhaps CNC machined bike computer mount comes with the handle bars. Others might be able to comment.Stoffa wrote: ↑Wed Nov 09, 2022 2:14 pmThanks. On their order page it says:warickwrx wrote: ↑Wed Nov 09, 2022 12:28 pmThe BB is a standard T47 type.So any inboard T47 BB matched to your crankset spindle diameter should work. On other builds I have found the Token BB's to be of decent quality. The frame should come with headset bearings, however I recall someone mentioning they are slightly shallower when compared to FSA ACR versions. Maybe something like a FSA SL MR110R would work for the upper.
Paypal payment is restricted for them, they had too many refund request (above 3%) and too long lead times. That's info coming directly from C100. I paid my balance using credit card on November 1st for a white RDC size L with 400x110 handlebars. Had to change the handlebar to have it shipped out immediately (order was for 400x100, not in stock for 3 more weeks at least).
They shipped the frame 2 days later and is traveling with UPS to Switzerland. Should receive it on Friday.
So a quick recap - I paid my deposit on 19/4 and then, on C100's request paid the balance on 27/7. There followed a multitude of emails to C100 and Seka, most of which were unanswered, until after nearly 6 months I cancelled the order on 19/10 and received a full refund a couple of days later.
Despite all the shenanigans with C100, I still was of the opinion that Exceed RDC was probably a decent product at a good price, something that was borne out by the majority of people on this forum who have already received their frames. SO after a bit of a root around on the internet I found an ebay listing from Ccache, a Seka dealer in Sydney, for a Large in naked gloss. I ordered and received my frame delivered for Australia to Ireland in less than 10 days!! I originally ordered a 380/110 bar just to try a slightly narrower option but Ccache only had 400/110 which is ok because that's my usual width anyway.
The whole package did cost about £200 more than C100 but at least I received the frame very quickly and, although I know very little about Ccache, they couldn't be any worse than C100.
For the record:
Frame including derailleur hanger, bottle bolts and seat clamp 965g
Fork uncut 390g, cut 368g
Seatpost complete 176g
400/110 bar combo 350g
Headset 90g
Thru axles 62g
Top cap 4g
The frame is really well made, certainly on a par with any of the mainstream frames I've used such as Specialized, Scott and even Colnago. Here on the north coast of Ireland it'll rain right through until about early March so I'll build it at my leisure but won't get to cock a leg over it for a few months! Planned build DA R9200, Farsports 40mm wheels with Extralite hubs, San Marco saddle, Carbon Works cages with estimated weight of about 6.5kgs. I'll put my details on the spreadsheet shortly. Cheers.
For the record:
Headset 90g
Thru axles 62g
Top cap 4g
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
For those looking at other buying options, Seka frames are also available through an AliExpress seller that goes by "Nick's Road Bike Equipment Store." Also a tad more expensive than C100, but maybe they're a bit more responsive to customer service issues that C100?liam7020 wrote: ↑Wed Nov 09, 2022 9:18 pmDespite all the shenanigans with C100, I still was of the opinion that Exceed RDC was probably a decent product at a good price, something that was borne out by the majority of people on this forum who have already received their frames. SO after a bit of a root around on the internet I found an ebay listing from Ccache, a Seka dealer in Sydney, for a Large in naked gloss. I ordered and received my frame delivered for Australia to Ireland in less than 10 days!! I originally ordered a 380/110 bar just to try a slightly narrower option but Ccache only had 400/110 which is ok because that's my usual width anyway.
Hi there, quick question to the lucky ones who already got their frame: does it come with thru axles?
NB That's for the Afield from the Seka FAQs page.mrlobber wrote: ↑Wed Nov 09, 2022 12:44 pmNice catch, and I must say, a bit of a letdown...RDY wrote: ↑Wed Nov 09, 2022 12:32 pmBtw I don't know when this changed, but potentially of note is that Seka now state in their FAQ that the frame has max clearance for 28mm tires (not 30mm), according to ISO guidlines (4mm clearance left and right). If they've revised it down by 2mm, then I'm guessing 32s are indeed a no-go.
Scroll down and see that the Exceed section still lists 30c as the maximum tyre size.
http://www.sekabikes.com/en/faq2/
Yes, X-12 thru-axles are included. Weight is 64g for the pair.renegade1848 wrote: ↑Thu Nov 10, 2022 1:44 pmHi there, quick question to the lucky ones who already got their frame: does it come with thru axles?
Sure thing, heres the details:maxim809 wrote: ↑Tue Nov 08, 2022 3:36 amCongrats stainless, looks great.
Very interesting you ordered off of Aliexpress successfully. Would you be up for filling out your details in the Seka Order Tracking spreadsheet? The ordering experience you went through is particularly unique compared to most and I'd be interested to have it captured:
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
Thanks.
Pre Order Reservation Date: Mar 4
Full Balance Payment Date: Mar 4
Order Expidation Date: Jul 7
Payment Sent Before asked By Seka? N/A
Your Country Location: Canada
Frame Size: L
Which Model: RDC
Which Color: Pearl White
Which Bar-Stem Combo: Ordered 400-100
Shipment Received: Yes
Which Website or Shop did you order from? Aliexpress
Customs?: None
Comments:
- Original Aliexpress order had expired, seller asked to buy the cheapest item in the store for tracking (kinda sketch, but Aliexpress reviews on the seller were good so I took the gamble)
- China Post took over 1mo for delivery, though there was no customs
- Seller insisted since he receives it for domestic production, this is prioritized vs Intl sales channels
