Seka Exceed RDC
@dsveddy I wouldn't say the carbon is visible. Still a bit early here so will take a close up or two when the light gets better.
I wasn't thinking this frame had a transparent finish though, so wasn't expecting that in the first place. Now that you've mentioned it their listing is indeed for "Transparent Midnight Blue".
Edit - on closer inspection it is indeed transparent, just very subtle in the UK winter light. Might be a bit more obvious in direct sunlight but I can def see some of the layup through the blue paint. Can't quite get a decent photo of it though as I either get too much glare or not enough light to show it.
Cervelo R3 - 5.4kg viewtopic.php?f=10&t=142420
Do these help with the piant transparency?
No, those aren't scratches
Sorry, probably wasn't being specific enough for the internet - No, they aren't scratches in the top layer of clearcoat or whatever. Yes, they may be scratches left over from sanding the carbon underneath that smooth layer on top.
Was just trying to anticipate any "send it back it's scratched" comments
To be fair... Those scratches do look like they are on the clearcoat. You can probably polish those out if you cared enough.
Huge thanks for the photos Rudi! That does indeed look beautiful and transparent.
I was worried that with the reports of declining paint quality as Seka faces overwhelming demand, that they had abandoned the beautiful transparent finishes you see in the promo photos, and that I'd be waiting all this time for a frame in vain. I'm glad to see that's not the case.
You'll only really notice them at certain angles in the sun like that photo. They're nothing like as bad as a lot of stuff you see. If you see many stripped or paintless frames you'll see a lot of really bad low grit machine sanding and sand through.
Nice one thanks Ladeef, will try it out. Out of interest, what does washing with dishsoap do? Clean greasy contaminants?ladeef wrote: ↑Wed Jan 18, 2023 7:19 pmI was having that issue as well, I washed the seat post with dish soap and warm water, then reapplyed carbon paste. It seem to solve it.zmiah90 wrote: ↑Wed Jan 18, 2023 5:35 pmHi guys,
Anyone had issues with seatpost slippage? Mine seems to be slipping down about 10mm from my set height every time I ride. I've put plenty of carbon paste and tightened clamp to recommended torque but no dice. Any pointers would be appreciated otherwise may have to go back to SEKA.
Cheers
Yea, dishsoap is a good safe grease / oil stripper.zmiah90 wrote: ↑Mon Jan 23, 2023 10:59 amNice one thanks Ladeef, will try it out. Out of interest, what does washing with dishsoap do? Clean greasy contaminants?ladeef wrote: ↑Wed Jan 18, 2023 7:19 pmI was having that issue as well, I washed the seat post with dish soap and warm water, then reapplyed carbon paste. It seem to solve it.zmiah90 wrote: ↑Wed Jan 18, 2023 5:35 pmHi guys,
Cheers
Ordered mid July '22
Received mid November '22
Naked Black Exceed RDC (Small). Originally ordered white but the naked black (2nd choice) became available.
110/38 bar/stem combo
Frame weight - 915 grams
Fork uncut - 395
Complete build (for now)
SRAM Red AXS drivetrain (except for crankset)
ZIPP 303S wheelset (thinking of getting Hyper Lun D45s)
Speed play Zero SS pedals
Supacaz sticky bar tape
Fizik Antares R1 saddle
Enve carbon water bottle cages (Arundel Mandibles to be installed)
Kogel Ceramic BB
Kogel KOLOSSIS OSPW (to be installed)
Total weight 17.4 lbs
Fork uncut - 395
Kogel Ceramic BB
tried it out, defo helped but still had a 5mm slip. I've sent a mail to cycling100. Thanks for you help.ladeef wrote: ↑Tue Jan 24, 2023 5:10 pmYea, dishsoap is a good safe grease / oil stripper.zmiah90 wrote: ↑Mon Jan 23, 2023 10:59 amNice one thanks Ladeef, will try it out. Out of interest, what does washing with dishsoap do? Clean greasy contaminants?ladeef wrote: ↑Wed Jan 18, 2023 7:19 pmI was having that issue as well, I washed the seat post with dish soap and warm water, then reapplyed carbon paste. It seem to solve it.zmiah90 wrote: ↑Wed Jan 18, 2023 5:35 pmHi guys,
Cheers
bummer, did you try cleaning the wedge as well? I know that's a lot but you can scuff the wedge and seatpost with scotch brite then add carbon paste. Could be the seatpost is out of tolerance however.zmiah90 wrote: ↑Tue Jan 31, 2023 5:45 pmtried it out, defo helped but still had a 5mm slip. I've sent a mail to cycling100. Thanks for you help.
