Thats quite far from the specified 775 gram for medium size... So the Seka isnt as light as advertised then?RustyCage wrote: ↑Wed Aug 03, 2022 9:37 pmI received my frameset over a month ago... still need a cassette before I can build it up. Anyone know where I can get a Sram 10-33 cassette?
I'm generally excited about the frame. The geometry is perfect for me. The top cap is a ridiculous 3g. The rest of the bits are well thought out. The compression plug is heavy compared to the FSA one that I got with the 5D super compact bars.
Weights
891 Frame "Exceed S, ""naked paint"" standard rd/fd mounts and seatpost set screw"
393 Fork Uncut
56 Axles
3 SEKA top cap
19 Headset adapter and wedge (unmodified)
61 Bearings SEKA 52x40x7 45/45
29 SEKA compression plug
332 Handlebars Metron Super compact
161 Seapost Uncut with standard hardware and seal (bolt = M6 55mm 13g)
12 Seatpost wedge
Seka Exceed RDC
- eucalyptus
- wheelsONfire
Framesets are always specified with no hardware (hanger, bearings yada yada)eucalyptus wrote: ↑Thu Aug 04, 2022 7:27 amThats quite far from the specified 775 gram for medium size... So the Seka isnt as light as advertised then?RustyCage wrote: ↑Wed Aug 03, 2022 9:37 pmI received my frameset over a month ago... still need a cassette before I can build it up. Anyone know where I can get a Sram 10-33 cassette?
Weights
393 Fork Uncut
56 Axles
3 SEKA top cap
12 Seatpost wedge
So a BB might add quite alot of weight pending on option!
Bikes:
Open *UP* (2016.04.14)
- eucalyptus
Even so, the parts he specified including der hangers doesn't add up But yeah, manufacturers weight is never correct. Just a bummer as the Seka is advertised as a lightweight race machine just like S-works SL7 and similar frames which really is that light.wheelsONfire wrote: ↑Thu Aug 04, 2022 8:10 am
Nevertheless it will be a sweet ride and I hope you enjoy it !!
- wheelsONfire
Yeah, right you are!
The weights given by manufacturers are often from a scale tuned for weight weenies (well, it seems like it anyway)!
Our regular scales are often more true!
Bikes:
Maybe "RustyCage" could clarify, what the "S" stands for. In case it means "Standard", the weight is just like advertised.
Read carefully on cycling100eucalyptus wrote: ↑Thu Aug 04, 2022 7:27 amThats quite far from the specified 775 gram for medium size... So the Seka isnt as light as advertised then?RustyCage wrote: ↑Wed Aug 03, 2022 9:37 pmI received my frameset over a month ago... still need a cassette before I can build it up. Anyone know where I can get a Sram 10-33 cassette?
Weights
393 Fork Uncut
56 Axles
3 SEKA top cap
12 Seatpost wedge
Frameset weight(size M unpainted): 775g - Paint and fittings adds approximately 135g, for RDC
Frameset weight(size M unpainted): 953g - Paint and fittings adds approximately 101g, for non-RDC
S is Size S.reedplayer wrote: ↑Thu Aug 04, 2022 8:51 amMaybe "RustyCage" could clarify, what the "S" stands for. In case it means "Standard", the weight is just like advertised.
The weights are (so far) just like advertised (fpr the RDC an Standard Versions) - like advertised and already written you have to add paint and fitting adds.
viewtopic.php?f=3&t=167579&start=240
https://www.rennrad-news.de/forum/threa ... dc.180317/
- eucalyptus
Quite heavy paint for only being a clearcoat
About 100g for a bit of black color, decals, clearcoat and fittings ist not heavy at all (RDC).
About 135g for color, clearcoat and fittings ist also not heavy at all (Non-RDC).
Especially concerning, that (as already mentioned) the claercoat (on my / the RDC) seems to be quite thick and not very sensitive to scratches and that it has (some kind of) aero tubes.
(Leaving out the price).
The black RDC has been weighed at 897g for M and 914g for L
totally respectable numbers.. what does a Factor Ostro weighStiffWeenies wrote: ↑Thu Aug 04, 2022 4:14 pmThe black RDC has been weighed at 897g for M and 914g for L
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
Yes, S=small and RDC version.nino10 wrote: ↑Thu Aug 04, 2022 9:09 amS is Size S.reedplayer wrote: ↑Thu Aug 04, 2022 8:51 amMaybe "RustyCage" could clarify, what the "S" stands for. In case it means "Standard", the weight is just like advertised.
For me sub-900g for this frame is great with all the bits. Getting sun 7kg with aero wheels is no problem.
Is there any other color option for RDC Exceed other below?
Naked Black
Red/Black
Pearl white
TIA
Naked Black
Red/Black
Pearl white
TIA
only for non rdc, ther is a new aurora/green color, there would be a nice option to have custom painting or more color palette to choose fromNatestaana831 wrote: ↑Sun Aug 07, 2022 3:54 pmIs there any other color option for RDC Exceed other below?
Naked Black
Red/Black
Pearl white
TIA
