Aftermarket rear derailleur hanger
Is there any choice of aftermarket/custom rear der hangers?
Or at least, is there any advantage of getting stiffer steel custom one on road bike, like crisper shifting?
rd hanger must be much weaker than the frame.
Such that, it's the part that break early in crash. Rather than stress and break to the frame.
There are sigeyi direct mount hanger for Shimano RD. And wheelsmfg Rd hangers. All of these are aluminum.
I know there´s risk of damaging the frame in crash, but would the stiffer RD hanger improve shifting or not?
I think there is some amount of flex coming from RD during shifting.
In theory yes, a steel hanger would improve shifting quality under demanding conditions. The only race bike that I know of that comes with a steel hanger is this bike. A member here (Calnago) has one and he once commented on it. This bike is usually made for the pros to race in the cobbled classics. The steel hanger is probably overkill for us mortals.
https://www.trekbikes.com/us/en_US/bike ... t/p/16986/
It would improve, yes. The improvement with the Sigeyi hangers comes from them being direct mount meaning that you can remove the B link, making it a stiffer setup while still being able to break during a crashRoadrocket wrote: ↑Fri Sep 17, 2021 8:53 pmI know there´s risk of damaging the frame in crash, but would the stiffer RD hanger improve shifting or not?
I just had a look at Sigeyi hangers, but are they compatible with 12S Mechanical Campagnolo? My original hanger is Canyon No.25cberg wrote: ↑Sat Sep 18, 2021 9:07 amIt would improve, yes. The improvement with the Sigeyi hangers comes from them being direct mount meaning that you can remove the B link, making it a stiffer setup while still being able to break during a crashRoadrocket wrote: ↑Fri Sep 17, 2021 8:53 pmI know there´s risk of damaging the frame in crash, but would the stiffer RD hanger improve shifting or not?
Im not completely sure, but it looks like it from this page:Roadrocket wrote: ↑Sat Sep 18, 2021 9:24 amI just had a look at Sigeyi hangers, but are they compatible with 12S Mechanical Campagnolo? My original hanger is Canyon No.25cberg wrote: ↑Sat Sep 18, 2021 9:07 amIt would improve, yes. The improvement with the Sigeyi hangers comes from them being direct mount meaning that you can remove the B link, making it a stiffer setup while still being able to break during a crashRoadrocket wrote: ↑Fri Sep 17, 2021 8:53 pmI know there´s risk of damaging the frame in crash, but would the stiffer RD hanger improve shifting or not?
https://www.campagnolo.com/WW/en/Compon ... derailleur
Removable pivot on the upper body
Perfect functionality with standard drop-out (with pivot) and direct-mount (without pivot)
With mechanical, yes, but you need the elusive RD-SR105 because the Campag B-link has the adjustment screw stop in a different angle.Roadrocket wrote: ↑Sat Sep 18, 2021 9:24 amI just had a look at Sigeyi hangers, but are they compatible with 12S Mechanical Campagnolo? My original hanger is Canyon No.25
And I found the Record derailleur looking even more bulky when it's levitating on that almost invisible (compared to the regular No.25+B-link) hanger. Now it's looking like a separate machine hanging on the side of the bike, instead of like a single composite-aluminum-and-steel organism all the way to the NDS hub flange. Yeah, aesthetics are purely subjective, I found the optics to work better once switching to Boras, because the G3 rear wheel picks up some of the "one big machine" vibe, compensating the separation)
I found it depends on the hanger that you have to start with.
Some brands have a decent grade of aluminium precisely CNCed to fit the frame and mech.
Some use compressed tin foil.
Guess which ones I tend to replace with wheels manufacturing or similar...
I have Canyon Aeroad No.25 RD hanger, I have no idea what grade of aluminium they used, but I´ll ask their support.
I´ll rebuild it to SR12s som I am still not sure this hanger is Campagnolo compatible, but they have sold some Campagnolo 11s equipped bikes in past.
Ok, in a bit of a bind here with a frame build that is in progress, but have just rtealised a crucial part is missing !
The frame is a LLlewellyn Discus Colossus that is getting built at the moment, and will be installin a Shimano R800 Di2 Groupset - this was purchased lightly used (some parts still in their box) and having been removed from a BMC frame (I believe).
Anyway, just realised that the "Bracket Axle Unit" - either Part No. Y3FC98010 or Y5ZV98010 are the compatible parts,. and of course are OOS here in Oz. And with Shimano geoblocking and the Pomms BREXIT crap, the places where they are in stock are not able to ship. I've found one option via Fleabay at a stupid price of about A$75 (US$50+).
Also, any idea of the differences between some of the other Shimano parts that are available (e.g. the other 6 or so versions that look almost the same ??)
I've looked at either the Sigeyi or WFG options, but they are specified by Frame model/Manufacturer.
I'm waiting on a reply from Darrel McCulloch (but suspect he's busy working on the frame) and a local supply option here, but wondering if there are any other suggestions ?
Aftermarket RD hangers are totally a thing, these are easy to manufacture and the demand is always there, given how often these break and limited availability from original manufacturer. As already mentioned above, Sigeyi does fancy Shimano DM hangers. I had great experience with local to me Velofrezer. There are other similar companies too.
Interesting! I always assumed that direct mount hangers was something exclusive to Shimanousr wrote: ↑Sat Sep 18, 2021 12:56 pmWith mechanical, yes, but you need the elusive RD-SR105 because the Campag B-link has the adjustment screw stop in a different angle.Roadrocket wrote: ↑Sat Sep 18, 2021 9:24 amI just had a look at Sigeyi hangers, but are they compatible with 12S Mechanical Campagnolo? My original hanger is Canyon No.25
Do you know if Ekar can be mounted this way too?
Thank you. Do you also know if the Shimano Road DM hanger design is the same as the one on their 11 speed MTB derailleurs? I can theoretically attach a XTR M9000 RD via Sigeyi's DM hanger to a compatible road frame?
