New Benchmark aero road bike: Simplon Pride 2
I guess the devil is is in the details, but if it has 3 different length stems, and you can move the bars fore and aft 0-50mm on the stem, then that's absolutely huge for fit. Especially for those gradually trying to get flatter back. We really ought to be seeing more of this from integrated setups - this is where their potential lies.
I do rather suspect that it's going to be ridiculously heavy though. Average builds probably over 9kg. I don't buy the 7.8kg in 55cm from the test ... especially as they state that the ARC 1400 Dicut 62mm wheel set is 120g lighter than it actually is.
Was reading some article about this bike.
Half serious question:
It is mentioned that pride 2 BB area is built up to benefit from sailing effects. So was wondering if a full frame-bag matching the frame tube shapes will give a similar sailing effect in crosswinds or aero advantage?
A full frame-bag/ frame triangle cover made with light & fine material (<500gram) sewn to a light bike like 6.2kg Aethos. Will this give any aero advantage/ sail effect in crosswinds like in the other aero bikes for ex. Ribble and Simplon pride 2?
Bottles need to be kept in the back pockets or bottle holder attached to the saddle (like in some TT bikes).
2018 Specialized Tarmac Expert
- cyclespeed
This kind of confirms to me that the Factor Ostro VAM is probably one of the best all round bikes you can buy right now.
It's up in the top echelons for it's aero performance, but can still be built to 6.8kgs without difficulty. Mine weighs 6.3kg.
And yes, the maths says that weight is 'immaterial' in all but the steepest climbs, but you just cannot quantify how a light bike feels, reacts and handles. That is very important to me.
Also, that swiss side link trashing tubulars is a bit binary. Some tubs are better than some clinchers or vice versa. It's not just 'clinchers roll better than tubs'.
Why do you assume the Ostro is aero? Have there been any 3rd party tests?
Edit: Also, the difference between heavy and light framesets isn't that huge. 800g is very light (Ostro). 1000g is very heavy (SystemSix). Something like a Venge is somewhere between. If your build is 6.3kg then using the same components on a "heavy" bike would maybe be 6.6kg. I feel like people say 8kg bikes are that heavy because of the frame, when in reality it's mostly due to component choices (barring proprietary bars like Cervelo and Simplon).
These propiatry aero stems, bars and seatposts will often weigh a fair bit more than more standard items and you're locked into these parts.BigBoyND wrote: ↑Thu Sep 16, 2021 11:33 pmWhy do you assume the Ostro is aero? Have there been any 3rd party tests?
Example - 100mm Hollowgram KNOT Stem - 229g, 100mm Kalloy Uno Stem - 103g.
- cyclespeed
Because it uses many of the same design cues as the most aero bikes, and in some areas, improves on them.
eg. dropped seat stays, deep thin fork, Kammtail shaped downtube and seat tube, aero seatpost and a very smooth aero bar/stem combo.
I also feel that the widely spaced fork leg and the very smooth transition area around the fork/headtube can only help.
I have no hard data, but it certainly feels a good bit quicker than my SL6 Sworks just about everywhere.
KNOT stem is a bad example since you aren't locked into that part. Specialized and Bontrager use the same cable routing. Put a RSL VR-C bar on a Cannondale and it's lighter than any Kalloy + aero bar combo.CampagYOLO wrote: ↑Fri Sep 17, 2021 9:42 amThese propiatry aero stems, bars and seatposts will often weigh a fair bit more than more standard items and you're locked into these parts.BigBoyND wrote: ↑Thu Sep 16, 2021 11:33 pmWhy do you assume the Ostro is aero? Have there been any 3rd party tests?
Same holds true for more "proprietary" bars, aside from Simplon/S5 type setups, which are in the minority. For 95% of aero bikes, you have light options.
Aero seatposts are generally not much heavier, either.
As I said, the frame weight difference is 200g at best. But I added another 100g for fork and seatpost being a little heavier for the reasons you mentioned. Hence my comment: "If your build is 6.3kg then using the same components on a "heavy" bike would maybe be 6.6kg."
There is simply not a 1kg difference in frames alone between heavy aero bikes and lightweight climbers. So saying "my bike is 6.3kg but this bike is 8kg" while ignoring that 80% of that weight is from components is not comparing apples to apples.
What do you mean by "real race conditions"?
Here's a "real race condition" - you're not a pro rider. If you were, you'd be riding whatever the team provided and you'd be happy to do it. And 9 out of 10 times you'd be lucky to stay with the bunch. But you're not.
Any other "real race conditions" you can apply their scenario 1 or 2 which are clearly your most realistic options. Or you can apply faith and belief but then stop pretending you care about the actual numbers.
Humans are terrible with "feelings". Of you're into coffee, look no further than tamping an espresso puck for proof of this.cyclespeed wrote: ↑Fri Sep 17, 2021 9:51 amI have no hard data, but it certainly feels a good bit quicker than my SL6 Sworks just about everywhere.
The previous Canyon Speedmax looked aero everywhere but was actually mediocre. We always need proof.
- wheelsONfire
And how many % depends on the rider itself?otnemem wrote: ↑Sat Sep 18, 2021 10:31 amHumans are terrible with "feelings". Of you're into coffee, look no further than tamping an espresso puck for proof of this.cyclespeed wrote: ↑Fri Sep 17, 2021 9:51 amI have no hard data, but it certainly feels a good bit quicker than my SL6 Sworks just about everywhere.
I'd love to like aero-stuff, but sadly too much is still up to my legs and to maintain aero position.
I still believe many (perhaps not here, but anyway) buy into this because in our minds, we dream of just taking off like a rocket into the sunset.
Bikes:
Open *UP* (2016.04.14)
They do "all things being equal" since introducing confounders would lead to the impossibility of drawing any conclusions. It's the only way to inform and the only way for us to have information. What you ask for is impossible and largely irrelevant.
You can have your preference and your preference might be the lightest bike possible, but anyone still denying that aero > weight at this point is like an antivaxxer or a flat-earther.
- cyclespeed
I've been riding bikes ALOT for 40 years, so I'm pretty sure I can spot and feel important differences when they are there. There are subtle handling differences between the SL6 and the Ostro too, and I still (just) prefer the SL6 in that respect.otnemem wrote: ↑Sat Sep 18, 2021 10:31 amHumans are terrible with "feelings". Of you're into coffee, look no further than tamping an espresso puck for proof of this.cyclespeed wrote: ↑Fri Sep 17, 2021 9:51 amI have no hard data, but it certainly feels a good bit quicker than my SL6 Sworks just about everywhere.
I would 'guesstimate' the difference between the 2 bikes at 40km/h to be about 10 watts. My position is as identical as I could make it.
