Deda Vinci handlebars owners - HELP
Is there anyone out there with a Deda Vinci handlebar who can tell me if the declared width is the total width or the C-C?
For example I have a Deda Superzero in size 40 which measures 38cm C-C.
Essentially, I'd like to know the C-C width of the Vinci in size 40.
- wheelsONfire
It even says outside to outside if you read!doraymon wrote: ↑Wed Aug 04, 2021 6:08 pmIs there anyone out there with a Deda Vinci handlebar who can tell me if the declared width is the total width or the C-C?
Vinci Shallow handlebar
Material: UD Carbon construction
Shape: Super Shallow
Diameter handlebar: 31.7 mm
Reach: 75 mm
Drop: 125 mm
Sizes: 40cm (VNSHALLOWPOB40), 42cm (VNSHALLOWPOB42), 44cm (VNSHALLOWPOB44)
Measurement: outside to outside
Weight: 225 grams (42cm)
Colour: POB (Polish on Black)
Note: compatible with full internal cables routing (up to 4 cables)
Bikes:
Open *UP* (2016.04.14)
i just measured my 40cm and indeed c-c is 38cm at the shifter gripper section
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes.
n+1...14 last time i checked, but i lost count
Few qs also.
Does anyone have experience with the stem and the stack height? What's the minimum amount of spacers or top caps you need to use with these? Looking at the headset covers and parts, I'm assuming it's two?
And does anyone know if the labels can be removed? It's a bit too lairy for me.
You certainly need to use the first plastic section under the stem as it both has the cable routing option, as well as covering the lower section of the stem itself. Stack height of these 2 is just over 41mm
The bottom of this plastic section does then have 2 “bumps” on the bottom to locate into one of the included headset top pieces however I thought of sanding these off so I can use my regular thin headset top piece
I painted the top cap and bar clamp front piece satin black via Rustoleum spray can. I cobbled together a Metron 5d headset top cover with a BMC Time Machine (cut off top half) headset top cover, and the Deda Vinci bottom of stem spacer piece. Assembled into one piece with epoxy. Shaped with Bondo. Lots of time sanding. It felt like I was making a surfboard!
2016 Time Skylon w/Sram Force 22 and Boyd 60's
2020 Merida 8000e w/Sram Force AXS and Token 52's
Yeah! That's why I'm asking the measurement C-C mate!wheelsONfire wrote: ↑Thu Aug 05, 2021 8:35 amIt even says outside to outside if you read!doraymon wrote: ↑Wed Aug 04, 2021 6:08 pmIs there anyone out there with a Deda Vinci handlebar who can tell me if the declared width is the total width or the C-C?
Fantastic, thanks!WorkonSunday wrote: ↑Thu Aug 05, 2021 8:57 ami just measured my 40cm and indeed c-c is 38cm at the shifter gripper section
