Campagnolo 12s crankset compatibility
What crankset can I use with a Campy SR 12s mechanical groupset?
Not convinced by the Stages arm on a SR 12 crankset approach, and I find the P2M and SRM solution way to expensive. But would a Quarq dZero or Sram Red AXS power meter work within a full campy 12s groupset (campy 12s chain, campy 12s mech derailleurs). If not, is there any other options?
#RETIRED# Lynskey “the Do-it-all Helix” :https://tinyurl.com/bdmb5y24
ive used Rotor and FSA crank with praxis rings on SR11 EPS with no problem, im sure it will work with sr12 if you have the correct chainrings that will match the sr12 chains
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
Remember that chainline was pushed 1mm outward; I had the chain falling outside constantly until I discovered it and managed to fix the problem.
Rotor 3D 24 mm with old Praxis chainrings on BB86 I used with 11SR, no problem with shifting just "noisy" on the 50.nismosr wrote:ive used Rotor and FSA crank with praxis rings on SR11 EPS with no problem, im sure it will work with sr12 if you have the correct chainrings that will match the sr12 chains
Inviato dal mio ONEPLUS A6003 utilizzando Tapatalk
Thanks guys. I am currently using Quarq crankset with SR11, no problem.
But my understanding was that SR12 is another animal, with different spacing...
Fixing the problem meaning using a campy 12S crankset?
it is and if you want perfect shifting use campy 12sp crankset.
i've used for some time rotors crankset, it's difficult to setup and shiftting isn't perfect. switched to campy 12sp record crankset and all problems gone.
I added a 1mm spacer on both sides of crankset.
Haven't tried them but Miche make Campagnolo 12 Speed Chainrings for SRM Origin.
https://powermetercity.com/product/srm- ... chainring/
The Miche Attiva SRM is now also available with Campagnolo 12 compatible rings
https://flagbikes.com/products/miche-at ... chainrings
