Fabric saddles: scoop flat vs line-s
- musiclover
Sorry guys, yet another saddle topic.
It seems that line-s is the new line (no pun intended) to keep up with the modern trends (stubby, relief channel).
The shape is quite a lot different. S-line is offerred in huge 155 mm width. I wonder why?
What to choose if you have not tried either of them?
Thanks!
Thanks!
I have retired from this forum, not wasting any more time here.
Seems like an apples to oranges comparison. I have riden on Fizik saddles since they came to market but decided to try the Fabric Ultimate and Scoop Flat a couple years ago, but was not oeverly impressed and now riding on Fizik Tundra M1 saddles on both my raod and gravel bikes.
- Michael
- musiclover
Any saddle advice is always so personal but heres my experience....
Ive used both and decided to stay with the scoop flat (142mm). I've been pretty happy with it from the start, it treats my sit bones really well but i found when I was in the drops I had perinium pressure that got uncomfortable. Manageable but uncomfortable. So i decided to try the line-s flat (142mm) thinking it would basically be the same but help relieve the perinium pressure. I just wasnted as all round comfortable on it though, I could of played with the exact saddle position a bit more but decided to go back to the scoop flat as I went on bikepacking trip and knew id be fine on it. I must say on this trip I did alot more climbing and noticed decidely more sit bone pain when climbing for longer than a 500 metres. I didnt really expect that. So im eyeing off something else now.
The shapes are differant. The line-s seems to be slightly more raised at the back and a little wider in the middle.
- musiclover
Thanks, that's helpful.Yoeki wrote: ↑Wed Jul 28, 2021 12:59 pmAny saddle advice is always so personal but heres my experience....
At the moment there are big issues with fabric saddles stock availability. They expect them to be resolved around October but it could be longer than that. Maybe, I will try Repente saddle instead.
I once got to try out a Fabric Tri Flat Pro and absolutely loved it. Since then I haven't used another saddle, I even have one on my gravel bike.
However saddles are extremely personal, so if you can, try before you buy. Or buy the cheapest versions and try out different saddles.
- musiclover
It is a very hard saddle is it? I wish I could try Fabric but many stores experience stock issues.Renne wrote: ↑Thu Jul 29, 2021 3:26 pmI once got to try out a Fabric Tri Flat Pro and absolutely loved it. Since then I haven't used another saddle, I even have one on my gravel bike.
It doesn't have much in the way of padding but if the shape fits that doesn't really matter.musiclover wrote: ↑Sat Jul 31, 2021 4:13 amIt is a very hard saddle is it? I wish I could try Fabric but many stores experience stock issues.
I don't even remember how I got to Fabric saddles but I really like their saddles.
I use fabric scoop shallow race on all my bikes. previously used the flat but was getting some skin irritation down there. The shallow has a touch more padding and is more comfortable. The Ti rails on the race version make the price right at around $100 USD. It's such a simple saddle that works.
I bought two lines s flats, one in 142mm, the other in 155mm, as I wasn't sure what size I should go for.
So far, the 142mm is feeling good in terms of width, but the padding is really quite soft. I've been on one ride only, quite an easy one really, but I find the combo of my chamois and the relatively soft padding of the saddle is too unstable.
Is there a similar saddle out there (flat and wide) that has minimal, or at least firm, padding?
Ridley Helium SLX - RIP https://weightweenies.starbike.com/for ... lit=ridley
Scott Foil - current viewtopic.php?f=10&t=173046&p=1813155#p1813155
