Thanks; I hadn't spotted the upcoming BRR testing. I'm glad Jarno's the one to start doing this - I find his approach to testing thorough, so they'll be useful info out of it.Hexsense wrote: ↑Mon Jul 26, 2021 12:23 amSoon there'll be some data.
Quoted Jarno from BRR disqus comment on Pirelli's test below. Apperantly, they are testing tire grip. Data will be available maybe next month. :So, it seems Vittoria Corsa use mid-level grip compound on the center, but high grip compound on the side.Didn't test the Wolfpack yet. Power Road does very well. Vittoria Corsa and Corsa Control as well but they do a bit worse on center grip but better on edge grip (4c compound really seems to work).
The multi-compound tread is as old as......I've used all sorts over the years, from Schwalbe, Michelin and Vredestein. In my experience, Michelin are the only ones to get it about right, and it took them many attempts. The main problem with the "high grip compound on the side" idea is that you have to take into account off-camber cornering/turning. Because of the way maximum lean angle relative to the surface varies according to the absolute angle of the surface, the higher-grip part of the tread needs to extend much further up to the centre [crown] of the tire than appears to be the case based on a surface that's always perpendicular to gravity.
In the end, there's not really much benefit in reduced rolling resistance, but you have less traction. I suspect that Conti have never offered that type of mult-compound tread because it's just not worth it. In any case they have Black Chili which is still outstanding, so they don't really need to bother.
OP, you're going to have to compromise somewhere! Something from Challenge will come closest I think, but I don't have enough experience to recommend a specific tire........
