Original VS third party DT Swiss Star Ratchets
I'm looking to upgrade my DT Swiss 18T star ratchets, for the 54T option.
I see there are many third party manufacturers selling this part.
I was wondering if anyone here bought, and used some of these third party star ratchets.
And share your experiences.
Thanks
Louis
Thanks
Louis
I've looked into this, several times, and the general consensus I received was that they were mostly cheap knocksoffs, prone to chipping. Given that the teeth on the 54T ratchet are pretty small, to begin with, I'd opt for the original DT Swiss version, until it's vetted (unless you don't mind being a beta tester).
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
It's a matter of taste. Personally, I love the 54T sound.
I never used to, but after updating three sets of Roval's, I almost don't need a bell to alert anyone.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's). Sold.
2016 Rca: 11.07lbs/5.048kg.
2015 Rca. 11.15 lbs(w/Roval CLX 32's)
2015 Rca/NOS(sold).
2018 S-Works SL6 Ultralight 12.03lbs(w/Roval CLX 50's)
2015 Rca/NOS(sold).
To the OP: is this for road or MTB? On the road bike there's absolutely no benefit with a high engagement count. Higher engagement count has more drag. The louder sound that you hear is converted kinetic freewheeling energy. On the MTB higher engagement count is needed due to the lower than 1:1 gearing and the need for the crank to clear road obstacles. On the road bike when you do freewheel you're already in the higher gear, like on the big ring. And on the road you never freewheel when you're on a low gearing when climbing since there are no obstacles on the road for you to stop pedaling. My advice is for you to stick to 18T. A 54T will only cause you to freewheel slower with no additional benefit.
I can't agree with you, for powerful riders are 36T better and many LBS are recommending this change from 18T...pdlpsher1 wrote: ↑Sun Jun 13, 2021 9:37 pmTo the OP: is this for road or MTB? On the road bike there's absolutely no benefit with a high engagement count. Higher engagement count has more drag. The louder sound that you hear is converted kinetic freewheeling energy. On the MTB higher engagement count is needed due to the lower than 1:1 gearing and the need for the crank to clear road obstacles. On the road bike when you do freewheel you're already in the higher gear, like on the big ring. And on the road you never freewheel when you're on a low gearing when climbing since there are no obstacles on the road for you to stop pedaling. My advice is for you to stick to 18T. A 54T will only cause you to freewheel slower with no additional benefit.
Many shops recommend it so they can sell the ratchets and the work to people who don't know better. Power output has absolutely nothing to do with freewheel engagement.milanv wrote: ↑Mon Jun 14, 2021 7:17 amI can't agree with you, for powerful riders are 36T better and many LBS are recommending this change from 18T...pdlpsher1 wrote: ↑Sun Jun 13, 2021 9:37 pmTo the OP: is this for road or MTB? On the road bike there's absolutely no benefit with a high engagement count. Higher engagement count has more drag. The louder sound that you hear is converted kinetic freewheeling energy. On the MTB higher engagement count is needed due to the lower than 1:1 gearing and the need for the crank to clear road obstacles. On the road bike when you do freewheel you're already in the higher gear, like on the big ring. And on the road you never freewheel when you're on a low gearing when climbing since there are no obstacles on the road for you to stop pedaling. My advice is for you to stick to 18T. A 54T will only cause you to freewheel slower with no additional benefit.
I have tested several wheelsets and for my riding style is 36T better than 18T... Your life, your decision, but if you don't test it, your opinion is based on rumours and dumb information...Lina wrote: ↑Mon Jun 14, 2021 7:51 amMany shops recommend it so they can sell the ratchets and the work to people who don't know better. Power output has absolutely nothing to do with freewheel engagement.milanv wrote: ↑Mon Jun 14, 2021 7:17 amI can't agree with you, for powerful riders are 36T better and many LBS are recommending this change from 18T...pdlpsher1 wrote: ↑Sun Jun 13, 2021 9:37 pmTo the OP: is this for road or MTB? On the road bike there's absolutely no benefit with a high engagement count. Higher engagement count has more drag. The louder sound that you hear is converted kinetic freewheeling energy. On the MTB higher engagement count is needed due to the lower than 1:1 gearing and the need for the crank to clear road obstacles. On the road bike when you do freewheel you're already in the higher gear, like on the big ring. And on the road you never freewheel when you're on a low gearing when climbing since there are no obstacles on the road for you to stop pedaling. My advice is for you to stick to 18T. A 54T will only cause you to freewheel slower with no additional benefit.
I have tested 18t, 36t and 54t on the road. Apart from the different sound, I see 0 benefit for more than 18t. Let's be honest, on the road you only re-engage pedals after a corner on a descent or after a red light. For a sprint, you're already pedaling and keep the chain tensioned before you actually start to kick. So a ratchet with more teeth doesn't help you there. Where does a powerful rider need the 36t then?
I agree that on a CX or a MTB it is very useful. I have a 54t on my CX bike for the reason pdlpsher1 mentioned.
I know the difference between them all. I've even got hubs with both 18 and 54T.milanv wrote: ↑Mon Jun 14, 2021 11:36 amI have tested several wheelsets and for my riding style is 36T better than 18T... Your life, your decision, but if you don't test it, your opinion is based on rumours and dumb information...Lina wrote: ↑Mon Jun 14, 2021 7:51 amMany shops recommend it so they can sell the ratchets and the work to people who don't know better. Power output has absolutely nothing to do with freewheel engagement.milanv wrote: ↑Mon Jun 14, 2021 7:17 amI can't agree with you, for powerful riders are 36T better and many LBS are recommending this change from 18T...pdlpsher1 wrote: ↑Sun Jun 13, 2021 9:37 pmTo the OP: is this for road or MTB? On the road bike there's absolutely no benefit with a high engagement count. Higher engagement count has more drag. The louder sound that you hear is converted kinetic freewheeling energy. On the MTB higher engagement count is needed due to the lower than 1:1 gearing and the need for the crank to clear road obstacles. On the road bike when you do freewheel you're already in the higher gear, like on the big ring. And on the road you never freewheel when you're on a low gearing when climbing since there are no obstacles on the road for you to stop pedaling. My advice is for you to stick to 18T. A 54T will only cause you to freewheel slower with no additional benefit.
The only differences in them is faster engagement after coasting and sound. More sound means more drag while freewheeling, so for that reason you'd want to go with the smallest you can tolerate. On the road it doesn't matter if there's a bit of slack after freewheeling. Where it does matter is off the road where you want to position your cranks in relation to the terrain so that you don't strike your pedals to everything on the ground. Or when you're doing really technical terrain and want to do really small pedal strokes. That's where you need hubs with fast engagement.
Yes, in/after downhills, when you need it... I feel the difference...Lina wrote: ↑Mon Jun 14, 2021 2:19 pmI know the difference between them all. I've even got hubs with both 18 and 54T.milanv wrote: ↑Mon Jun 14, 2021 11:36 amI have tested several wheelsets and for my riding style is 36T better than 18T... Your life, your decision, but if you don't test it, your opinion is based on rumours and dumb information...
1) Simple Calculation, using gear ratio only to find dead space angle.milanv wrote: ↑Mon Jun 14, 2021 4:52 pmYes, in/after downhills, when you need it... I feel the difference...Lina wrote: ↑Mon Jun 14, 2021 2:19 pmI know the difference between them all. I've even got hubs with both 18 and 54T.
For down hill
So, on downhill. Let say you are at 40 km/h (pretty slow for a downhill honestly. But using even higher speed make more ratchet teeth even more insignificant).
For that speed with 700x28c wheel, let say you are in 53t front ring and 15t rear cog (more like fast flat gear rather than actual down hill gear IMO). That has ratio of 53/15 = 3.53
18t means you have a pedaling dead space at most (360 degree)/18/3.53 = 5.66 degree
36t means you have a pedaling dead space at most (360 degree)/36/3.53 = 2.83 degree
search "6 degree angle" to see how small 5.66 degree is...
2) More comprehensive calculation using cadence too, to find wasted time.
Let say you pedal at 85rpm consistently (again, very slow, to make the difference noticeable). < this is a bit unrealistic, as you'd normally pedal faster when there is no resistance vs when there is.
18t means you pedal without applying power for at most (5.66 degree)/360 /85 -> 0.00018 minutes. That is 0.01 seconds
36t means you pedal without applying power for at most (2.83 degree)/360 /85 -> 0.000092 minutes. That is 0.005 seconds
Average human have response time of 250ms (0.25 s). Yeah, right. You definitely feel the 0.005 seconds.
PS. on MTB side, ride at 6 km/h at 50rpm using 32t front ring and 50t cassette result in dead space of 31.25 degree vs 15.62 degree
and 0.086s vs 0.043s. That might be detectable.
EDIT: There was a mistake in the first version, I shouldn't need tire size and wheel circumference, it's already taken care of by using gear ratio and cadence.
