no, with a headtube reaming and facing tool.
Sent from my SM-G981B using Tapatalk
??? What do you think reaming means?
Since the frame is not correctly manufactured and it sounds like it's new, any cost involved will be the seller's responsibility. I'm surprised that's not obvious, tbh.Probably cost more than the frame itself from my experience with titanium shops
the shop should cover the cost as a fitting adjustment which is very common on metal frames, like facing the bb, brake disc mounts or chasing threads, piece of cake for any decent shop.Karvalo wrote:??? What do you think reaming means?Since the frame is not correctly manufactured and it sounds like it's new, any cost involved will be the seller's responsibility. I'm surprised that's not obvious, tbh.Probably cost more than the frame itself from my experience with titanium shops
I will have to ask around to find the nearest shop with one. Thanks
I strongly suggest you post some images detailing the issue as there is a lot of advice but no real facts around the issue. For example, what are the headset specs and the brand of the frame?Raccooningtanuki wrote: ↑Sun May 23, 2021 4:39 amFrame head tube inner diameter apparently about 30.9 and the bearing is 31. My thought is to sand the outer edge of the bearing down til it fits. Any other suggestions?
I’ll take more pictures next time I go in to the shopms6073 wrote: ↑Mon May 24, 2021 2:46 pmI strongly suggest you post some images detailing the issue as there is a lot of advice but no real facts around the issue. For example, what are the headset specs and the brand of the frame?Raccooningtanuki wrote: ↑Sun May 23, 2021 4:39 amFrame head tube inner diameter apparently about 30.9 and the bearing is 31. My thought is to sand the outer edge of the bearing down til it fits. Any other suggestions?
Then charge back the credit card, chuck it in the bin and buy something "from a shop" that's made properly by people with accountability.Raccooningtanuki wrote: ↑Sat May 29, 2021 3:26 amIt came with an integrated headset. If I get custom spacers to fit where the bearings would go could I use an external headset? And none of my bikes come “from a shop”. I’m not sending it back across the world the the eBay seller, aliexpress shop, etc.
Even though it would cost more than I paid for the frame, the cost of the frame + getting it fixed a titanium shop would still be cheaper than aero titanium single speed frame from wherever you can actually find one.Karvalo wrote: ↑Sat May 29, 2021 10:38 pmThen charge back the credit card, chuck it in the bin and buy something "from a shop" that's made properly by people with accountability.Raccooningtanuki wrote: ↑Sat May 29, 2021 3:26 amIt came with an integrated headset. If I get custom spacers to fit where the bearings would go could I use an external headset? And none of my bikes come “from a shop”. I’m not sending it back across the world the the eBay seller, aliexpress shop, etc.
Who would have thought making something that works comes with a price Anyway, you had already dismissed that option.Raccooningtanuki wrote: ↑Sun May 30, 2021 8:16 amEven though it would cost more than I paid for the frame, the cost of the frame + getting it fixed a titanium shop would still be cheaper than aero titanium single speed frame from wherever you can actually find one.Karvalo wrote: ↑Sat May 29, 2021 10:38 pmThen charge back the credit card, chuck it in the bin and buy something "from a shop" that's made properly by people with accountability.Raccooningtanuki wrote: ↑Sat May 29, 2021 3:26 amIt came with an integrated headset. If I get custom spacers to fit where the bearings would go could I use an external headset? And none of my bikes come “from a shop”. I’m not sending it back across the world the the eBay seller, aliexpress shop, etc.
Karvalo wrote: ↑Sun May 30, 2021 10:04 amWho would have thought making something that works comes with a price Anyway, you had already dismissed that option.Raccooningtanuki wrote: ↑Sun May 30, 2021 8:16 amEven though it would cost more than I paid for the frame, the cost of the frame + getting it fixed a titanium shop would still be cheaper than aero titanium single speed frame from wherever you can actually find one.Karvalo wrote: ↑Sat May 29, 2021 10:38 pmThen charge back the credit card, chuck it in the bin and buy something "from a shop" that's made properly by people with accountability.Raccooningtanuki wrote: ↑Sat May 29, 2021 3:26 amIt came with an integrated headset. If I get custom spacers to fit where the bearings would go could I use an external headset? And none of my bikes come “from a shop”. I’m not sending it back across the world the the eBay seller, aliexpress shop, etc.
So; you dont want to pay for it to be fixed. You don't want to send it back for the manufacturer to fix it. You don't want to get a frame that isn't junk.
OK. Charge back the credit card, throw this one in the bin, order another one from where you got it and cross your fingers that it might be ok this time and nothing else is wrong.
Just remember to tell them how much the frame cost so they can charge you more.Raccooningtanuki wrote: ↑Sun May 30, 2021 10:08 amThe shop on my TT Fuji farpoint conversion appears to have the reaming tool on their wall. I’ll take it to this shop and cross my fingers
