Wahoo speedplay zero - weird side to side movement
fbonde
by fbonde
Hi Guys
Have you experienced this kinda side to side movement "play" on the wahoo zero pedals? I have been on the Speedplay for many years. Never experienced this kinda "play" It's on the left and right sides. left is the worse. :noidea:
insta: @fbonde
cloud9blue
by cloud9blue
Loose retaining nut on the spindle. Return and get a new one.
fbonde
by fbonde
cloud9blue wrote:
Fri May 07, 2021 10:48 pm
Thanks - will do for sure.
insta: @fbonde
ms6073
by ms6073
Look closely at the image below and you will notice that there is a small rubber press-fit plug. Remove that and there is a stainless bolt exposed but unsure if it is torx or allen head that threads into the spindle. You can exchange the pedals or you can take 5-minutes to use the appropriate allen wrench/torx key and tighten that bolt which secures the pedal body to the spindle, the press the rubber plug back into the pedal body.
- Michael
"Solving problems you didn't know you had in ways you probably won't understand"
shoemakerpom2010
by shoemakerpom2010
Michael have you actually removed this on yours? Im asking because Im about to purchase the Nanos and that side play movement wasnt something I was hoping for.....
ms6073
by ms6073
The loose pedal body reported by the OP is not normal, suggesting that the set of pedals somehow managed to slip through Wahoo's quality control. My reply was simply meant to offer a solution that avoids having to exchange them for a new set of pedals. The set I installed on my wife's bike has no lateral play and while I have removed the press-fit rubber plug to see what was involved with swapping spindles, I have gone any further.
- Michael
shoemakerpom2010
by shoemakerpom2010
The problem I see with that is it looks like it went out with the wrong level of locktight and therefore became loose. I think even if you tightend it it may become loose again and damage the bearings before you realize it since there is no way to get locktight in there and fix yourself.....
ms6073
by ms6073
Yes, all good points and something the OP should consider as to whether or not to exchange or tighten, as my reply was based on the impression that the play was present for the OP new out of the box.
- Michael
keefzip
by keefzip
This lateral play exists on all four of the pedals in my 2 sets, which were some of the first batches. I have contacted Wahoo to find out why. Having taken the rubber grommet out of the end, the bolt which screws into the spindle is tight...
keefzip
by keefzip
fbonde wrote:
Fri May 07, 2021 8:55 pm
Hi Guys
Did you resolve this with Wahoo?
Robius
by Robius
keefzip wrote:
Thu May 20, 2021 11:26 am
Oh that doesn't sound good I was also considering to buy. :|
2016 Felt AR2 Di2
Retired:
2017 Giant TCR Pro 2
2015 Cannondale Synapse 6
milanv
by milanv
So I have tried the pedals today and I have the same side to side play, one of the first pieces on the market...
ms6073
by ms6073
Given what I see inside the pedal body with the spindle removed, if the end bolt is tight against the spindle, I would imagine that pedals exhibiting such lateral movement are probably missing both the middle bushing and end bearing.
For those who are curious regarding the differences, below is an image of an aftermarket Ti spindle for the legacy Speedplay Zero:
- Michael
welchy
by welchy
I'm hoping this means some of the normal players for aftermarket spindles will be out in force shortly with a Ti offering. My current pedal bodies have worn a fair bit on the old style and I was about to but the bullet on a new set, but, have you guys resolved the play issue yet with Wahoo? I'll be holding off until I know the quality issue is fixed for all of £200 for a set!
cloud9blue
by cloud9blue
I have no issue with the stainless steel version. Purchased in mid April directly from wahoo website.
