Ultegra 8070 olive
Hello,
Need to disconnect my brake lines as the cables route through the headset so changing
the headset bearings mean disconnecting the brake lines.
As I am only disconnecting the brake lines can I reuse the current olive that is on the line
or do I need to change the olive to a new one?
Thanks
Thanks
Thanks, will bear that in mind. Additionally, the front derailleur trim has stopped working on my Di2. When shift to big and big the trim you can do from the lever to move it over slightly no longer works.
Any ideas? Have charged, reconnected cables, before it stopped working didn't make any adjustments it's just gone as a function.
Slight topic drift, but for bikes that have integrated brake hose and next to no excess, what is the technique/process for removing the old olive while leaving the brake hose serviceable?
- Michael
You can try to cut the olive, but you Probably will damage the hose, so you cut it at the olivems6073 wrote:Slight topic drift, but for bikes that have integrated brake hose and next to no excess, what is the technique/process for removing the old olive while leaving the brake hose serviceable?
I've reused olives before and it works most of the time...the second time I use it...I clamp down the bolt a bit more so there.s no leaks due to mis-mate of the olive to the inside seat.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Regularly reuse olives in this scenrio.
Very very very rarely had any issue. (Probably reusing a dozen a year, maybe 5 years since the last one leaked.).
Thanks for the reply. Was hoping there was a tool that could be used to crack the olive in half which is essentially what I do now with wire cutters.
- Michael
