Garmin Rally 200
Well checking around on internet I couldn't really find any opinion out of the box I mean, apart from different magazines or website that I'm sure were paid in advance, I couldn't find any rider opinon or someone who tried them and can give me a proper review so I would like to know if anyone tried them and if it's worth it to get them.
Thanks in advance.
Thanks in advance.
He ran into an offset/drift issue which has nothing to do with which style of pedal body is attached. Rally is almost identical to late revision Vector 3.
I personally have not observed any drift or auto-zero issues with my set like GPLama saw in his tests. One thing I have noticed is they like are very, very quick to "idle" at 0W and slow to "wake" after such a pause. This is noticeably different than the current Vector 3 firmware and I'm assuming the pedals aggressively toggle some kind of half-power mode or something... like auto-start/stop on a modern car.
All-in-all Rally is the most advanced pedal PM on the market and also the most versatile. The power drops/spikes caused by the battery door issue is gone. The battery cap threads in the pedal bodies are now metal. The only hang-up is the price now, but if you want SPD-SL.
Any other Garmin Rally users here? Im thinking of buying a set of the Shimano road version and then getting the SPD dummy pedals to swap to my gravel bike.
Im a wahoo elemnt bolt user, hopefully that wont be an issue but I can be swayed to get a Garmin head unit
Anyway positive and negative views appreciated
also check out Garmin forumsgSporco wrote: ↑Mon May 17, 2021 1:53 amAny other Garmin Rally users here? Im thinking of buying a set of the Shimano road version and then getting the SPD dummy pedals to swap to my gravel bike.
https://forums.garmin.com/sports-fitnes ... ng/f/rally
Thank you!jlok wrote: ↑Mon May 17, 2021 1:58 amalso check out Garmin forumsgSporco wrote: ↑Mon May 17, 2021 1:53 amAny other Garmin Rally users here? Im thinking of buying a set of the Shimano road version and then getting the SPD dummy pedals to swap to my gravel bike.
Are there any benefits why one would choose the Garmin Rally pedals over the Favero Assioma Duo's? Other than interchangeable pedal bodies...
Field replaceable batteries; proprietary cable unnecessary.
Aesthetics, some people are put off by the pods.ThomasBr96 wrote: ↑Mon May 17, 2021 9:20 amAre there any benefits why one would choose the Garmin Rally pedals over the Favero Assioma Duo's? Other than interchangeable pedal bodies...
And to compete the list: Garmin has full cycling dynamics, whereas Assioma don't report anything in the platform center offset field.
List of things Assioma have over Rally: rechargeable batteries (they deserve to appear on both sides), official support for oval chainrings (no idea how successful they are at supporting, but they do try, while others don't)
PS: oh, and Favero have dirt cheap bearing replacement if you happen to be one of those people who eat through bearings fast: official kits are cheap enough, and third party are cheaper (assuming equal durability). Garmin apparently can only reasonably be replaced by buying a full body kit.
I think PCO is a feature, at most an advantage, with unknown benefit.
One thing that bugs me about the Assiomas is that the spindle nut doesn't take up all the axial play. The bolt covers have to be torqued down pretty hard to remove the play, and the threads in the pedal body are plastic.
Overall the pod design can be problematic with shoe covers, even ones as thin as VeloToze. For once race, I wore pink VeloToze, and the rolled up lip around the cleat opening rubbed against the pods, leaving "eraser" marks in the same color as my VeloToze on the pods.
The Vector 3 and Rally also have longer pedal threads. I can use the included 2mm washer + another 1mm washer and it still sticks out the other side of my Red AXS crankarms. 3mm in spacers with the Assiomas is cutting it very close.
TobinHatesYou wrote: ↑Mon May 17, 2021 9:16 pmOne thing that bugs me about the Assiomas is that the spindle nut doesn't take up all the axial play. The bolt covers have to be torqued down pretty hard to remove the play, and the threads in the pedal body are plastic.
@TobinHatesYou, Assuming you own both Garmin and Assioma pedal PM's do you find the Garmin usability/ accuracy a concern.. No matter what I guess we would hear peole have had issues with both.. But curious on your thoughts to a prospective buyer of the new Garmin Pedals? I am a current Quarq AXS PM user and absolutely love it.. I just dont want to buy one for all my bikes, it would be nice to just swap pedals when needed.
The real question is: are they worth just about double the cost of the Assioma? You can buy 2 sets of Assioma for a little more than one set of the Garmin. Are they worth the extra cost?ThomasBr96 wrote: ↑Mon May 17, 2021 9:20 amAre there any benefits why one would choose the Garmin Rally pedals over the Favero Assioma Duo's? Other than interchangeable pedal bodies...
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
gSporco wrote: ↑Mon May 17, 2021 10:03 pm
My Quarq, V3 and Assioma Duo are all within a watt of each other the vast majority of the time...even at some really short durations where a single spike or differences in filtering can mess with averages.
