Deduction of two 6805s would result in around 580 grThejingerr wrote: ↑Sun May 02, 2021 4:16 pmcampy weight +/- 620gr like dura but cost twiceWorkonSunday wrote: ↑Sun May 02, 2021 3:30 pmdoes campy "25mm " axle count? bearing balls are the same size as normal bb84 bearings.
any concurent 24mm cranks ?
Lightest 24mm cranks 2021
DUB on pf86 with smaller bearings shall wear fasterryanw wrote: ↑Sun May 02, 2021 10:38 pmJust buy a PF4130 or PF41DUB BB from C-Bear (around £100) and run whatever cranks you like.
Some people will say that the smaller bearings shall wear faster. Well after 10k+ miles, one of my customers (genuine 400w ftp/turning pro), his BB is still perfect and spinning better than the day it was fitted.
I believe ride that summer ±7.000 miles (in backpacking format) and bb problem is last what i need
p.s. like gxp/dub sram cranks but can not
that weight includes the bearings already, the bb cups are quite abit lighter than dura aceThejingerr wrote: ↑Sun May 02, 2021 4:16 pmcampy weight +/- 620gr like dura but cost twiceWorkonSunday wrote: ↑Sun May 02, 2021 3:30 pmdoes campy "25mm " axle count? bearing balls are the same size as normal bb84 bearings.
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes.
n+1...14 last time i checked, but i lost count
- robbosmans
- Moderator
- Contact:
If I where you I wouldn’t watch to much of the toxic Hambini
there is a way around that, the Praxis M30 thru BB bearing integrates the bb cup with the bearing outer race. this allows the balls to be the same size as a normal PF30/BB30/BB386evo.Thejingerr wrote: ↑Mon May 03, 2021 8:01 amDUB on pf86 with smaller bearings shall wear fasterryanw wrote: ↑Sun May 02, 2021 10:38 pmJust buy a PF4130 or PF41DUB BB from C-Bear (around £100) and run whatever cranks you like.
allows the balls to be the same size as a normal - WorkonSunday ,WorkonSunday wrote: ↑Mon May 03, 2021 8:07 amthere is a way around that, the Praxis M30 thru BB bearing integrates the bb cup with the bearing outer race. this allows the balls to be the same size as a normal PF30/BB30/BB386evo.
if size of bearing is normal (for pf86) maybe "Praxis M30 thru BB bearing" it is decision ...
"this allows the balls to be the same size as a normal PF30/BB30/BB386evo."
Sorry but praxis looks like dual row bearing - not so good idea
Is there 24mm cranks ?
no, it's dual row like Rotor 4130. it's a single row, the outer race is extra deep to provide the press fit the actually bearing is still thin. have a look at their video:Thejingerr wrote: ↑Mon May 03, 2021 12:03 pm"this allows the balls to be the same size as a normal PF30/BB30/BB386evo."
https://praxiscycles.com/product/m30-bb86-road/
around 1min 35s mark.
His critique of GXP is valid though. Its variability of tolerances and the axle / bearing / crank interface is crap.robbosmans wrote: ↑Mon May 03, 2021 8:05 amIf I where you I wouldn’t watch to much of the toxic Hambini
Cranks themselves are excellent and good value for money - and a textbook illustration of why Shimano should also move to thermoplastic cranks (they're cheap, easy to mass produce & don't fall apart). But if DUB fits your bike, you'd be mad to go with GXP now ... it isn't perfect, but it's a whole lot less *f##k* than GXP.
- robbosmans
- Moderator
- Contact:
Yes off course, I haven’t had any issues with gxp, i have it on 3 bikes. I just use a shimano bb with a gxp adaptor and it works great.
Pretty sure this is the case. I have the carbon arms, they only come with arms, the spindle is purchased separately.LanceLegstrong wrote: ↑Sun May 02, 2021 6:51 pmOh are they not available for 24mm yet? I thought the axle interface was the same and you could just swap either axle in.Thejingerr wrote: ↑Sun May 02, 2021 6:49 pmalu = twice price, weight like ultegra
carbon aldhu is 30mm version
It is not the case.dcorn wrote: ↑Mon May 03, 2021 8:55 pmPretty sure this is the case. I have the carbon arms, they only come with arms, the spindle is purchased separately.LanceLegstrong wrote: ↑Sun May 02, 2021 6:51 pmOh are they not available for 24mm yet? I thought the axle interface was the same and you could just swap either axle in.Thejingerr wrote: ↑Sun May 02, 2021 6:49 pmalu = twice price, weight like ultegra
Rotor dropped the ball when they design the 30mm version. The spindle are sold separately, yes. But 24mm and 30mm spindle require different arms too...
Why is it?
Well, you see, to fit through the bottom bracket bearings, at least one side of the spindle interface must be smaller than the bearing diameter. Right side is not an option, it has large interface for fitting the spider. So, left side interface must be made smaller than 24mm so that it can go through 24mm as well as 30mm.
That's where Rotor dropped the ball. Their original 30mm version has interface that is too large to go through 24mm bearing. So to support 24mm axle, not only they need to make a 24mm axle. But they have to make 24mm specific left arm that fit to a modified interface that is smaller than 24mm (and incompatible with interface on 30mm arms) as well.
I see no alternative to shimano :
With PF86 all 30mm variant need 2 row of bearings.
No real 24mm variant.
Only twice+ campa or questionable gxp.
Exotic variants is interesting, but it is not just simple to buy them.
Hambini basically has no idea what he's talking about. GXP is fine, I run 6 of them (3x Red, 2x Force, 1x X01) and no problems. Sram GXP bearings aren't the most durable, but they are cheap and there are alternatives.Thejingerr wrote: ↑Sun May 02, 2021 9:26 pmgxp it is the lightest "24" mm, but hambini "avoid if you can" from gxp
Stop reading up on crap that people say about X... Most of these plonkers look at something and make a call based on their 'experience' (read this as they make a judgment call based on sweet FA actual real-world practice using the product).
Hambini (Sanjeev) states he is not a cyclist but an engineer. On paper maybe it isn’t as good as a bigger 6806 type bearing, but doesn’t mean it’s rubbish.
I am a cyclist and the people I build bikes for are pretty handy on two wheels too.
Three C-Bear PF4130/DUB units that spring to mind that I've installed have been faultless on bikes with riders who have 360-450w FTPs, 70-90kg body weight, 1,500w+ peak power. They have not been treated kindly yet still running smooth as silk after probably 30,000 combined KM.
Now if you're a stronger rider than the above and exceed their numbers, I can't comment on how it will last, but I doubt you are, so stop worrying and don't constrain yourself to a 24mm crank...
IG: RhinosWorkshop
IG: RhinosWorkshop
