Where to buy aluminium brake caliper nuts?
Lucendi
by Lucendi
Hello,
I recently swapped my Sram shifter clamps to Schmolke Shimano clamps. Part of the Shimano system is using M6 nuts just like you average rear brake caliper nuts.
The steel ones weigh some 5 grams, shortened to some 6-7 mm.
I'm looking to upgrade them to aluminium alloy to save some additional weight.
Does anyone know where you can find aluminium M6 nuts?
Lucendi
by Lucendi
Bobbyc123 wrote:
Mon Apr 26, 2021 9:33 am
I got some of these recently https://www.ebay.co.uk/itm/Shimano-Sram ... 890.l49286
I asked the seller if has more than just the one in stock, but he didn't. :(
Are these aluminium and are they threaded all the way through so then can be cut down to size?
mikemelbrooks
by mikemelbrooks
Lucendi wrote:
Mon Apr 26, 2021 10:01 am
The seller states they are aluminium, I don't know if they are threaded all the way through. But if not then threading it should be easy, also they have different lengths for sale. I have a few aluminium nuts in my garage that came with the Fourier/planet X brake set. Where in the world are you?
Lucendi
by Lucendi
mikemelbrooks wrote:
Mon Apr 26, 2021 12:14 pm
I'm the EU, Sweden to be precise. - Where are you located? :)
mikemelbrooks
by mikemelbrooks
I am in the UK but can't post at the moment as I am isolating, (Covid).
Lucendi
by Lucendi
A donation from fellow WW-meber mikemelbrooks arrived today. Thanks again Mike!!
Some aluminium alloy brake caliper nuts to be used with the shifter clamp;
They needed to be threaded a bit deeper, so I drilled and tapped them all the way through.
The final weight came to 1.9 grams!! vs steel ones at 5,5 grams, a 3,6 gram weight saving! :)
Since I drilled out and tapped the nuts I slotted them to work with a screwdriver bit;
The stock Sram Red 22 shifters weighed about 280 g, these tuned weigh 226 g now, a 54 gram total weight saving. :)
Zakalwe
by Zakalwe
Proper old school weenie-ism
