Wow, this is going to be great!Trkorb wrote: ↑Thu Apr 29, 2021 9:53 pmXLPR will be available in Rival Force and Red version from launch.gSporco wrote: ↑Thu Apr 29, 2021 5:02 pmI wonder if they will release a lighter tier of XPLR in Force or Red next year.. But either way this is a great start.. For me 10-40 something would be a true 2x killer for all my riding needs (not a cadence junky) my e13 9-46 was almost perfect, but the shfting wasnt as crisp as full AXS Eagel, Force and Red for meMayhemSWE wrote: ↑Thu Apr 29, 2021 4:38 pmThis has now turned up at Chain Reaction:
https://www.chainreactioncycles.com/sra ... prod205834
Etap AXS XPLR
Still there on my screen. May be some regional filtering going on depending on where your IP says you live. Only specs listed is that it is for 12 speed and max 44T, no photo or more descriptive text yet.
SRAM Force XPLR Etap AXS Rear Derailleur AU
AUD507.5 (~USD394)
https://www.chainreactioncycles.com/au/ ... prod205835
XG-1251 10-44T
AUD253.8
https://www.chainreactioncycles.com/au/ ... prod205836
XG-1271 10-44T
AUD350
https://www.chainreactioncycles.com/au/ ... prod205837
AUD507.5 (~USD394)
XG-1251 10-44T
AUD253.8
XG-1271 10-44T
AUD350
quite exciting to find out if they will follow road groupset and use flat top chain or stick with mtb groupset and use conventional design.jlok wrote: ↑Fri Apr 30, 2021 7:59 amSRAM Force XPLR Etap AXS Rear Derailleur AU
AUD507.5 (~USD394)
XG-1251 10-44T
AUD253.8
XG-1271 10-44T
AUD350
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes.
n+1...14 last time i checked, but i lost count
- Moderator
This!
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
So before the 10-52 Eagle Cassettes came out.. The Eagel AXS RD used to say some where that the minimum tooth cassettes was 44 or something in the 40's. I can confirm that the XX1 Eagle AXS RD works flawlessly with an e13 9-46 Cassette, So I cant imagine why a 44 wouldn't shift just fine.
This all being said, Sram redesigned their X01 AXS RD with a 10mm shorter cage for what they say is more ground clearance and increase chain wrap. So I would think the X01 AXS would work even better.
Duplicate
Sorry but this is thread that gives most rival axs search results.
So...where did the rival axs thread go?
My question: maybe a bit too soon but anyone knows if it would be possible to use rival axs with the sram etap hrd "old" 11spd calipers (the postmount version)?
Can't answer your question, but here's a link to the rival thread.
viewtopic.php?f=3&t=165642&p=1669862&hi ... s#p1669862
You can use a MTB caliper. The AXS used an existing platform- Level maybe. The AXS calipers push 15% more fluid, so you can just have touchy brakes too.pmprego wrote: ↑Sun May 02, 2021 10:48 pmSorry but this is thread that gives most rival axs search results.
Do you mean the AXS brake levers push more fluid (bigger bore hence more fluid per stroke distance)? Also, from which document could we find that 15% figure?jfranci3 wrote: ↑Mon May 03, 2021 4:59 am:You can use a MTB caliper. The AXS used an existing platform- Level maybe. The AXS calipers push 15% more fluid, so you can just have touchy brakes too.pmprego wrote: ↑Sun May 02, 2021 10:48 pmSorry but this is thread that gives most rival axs search results.
p.s. yes, I'm using Red AXS with 2-piece Level TL post mount caliper.
Product announcement does not necessarily mean product delivery in any significant quantity. lolbikewithnoname wrote: ↑Thu Apr 22, 2021 3:20 pmSRAM really are rubbing thier superior supply chain in Shimano's face if this is true (and they can ship it). So many new releases this year!
I was listening to a podcast where they interviewed the president of a bike manufacturer and he said the delays for SRAM components is now similar to Shimano's. There was only a small window last year when SRAM was still able to deliver with a reasonable wait time.
With the imminent release of new Shimano groupsets, SRAM naturally would want to announce their new products ahead of the inevitable steamroll by the 900lbs gorilla that commands 85% market share. Many bike manufacturers are expected to announce 2022 models with the new Shimano components. (That same president said their order of Shimano last year, which could not make it for this summer, has been converted to an order of the new Shimano for their 2022 bikes,)
yep, a perfect example right now for all the gamer nerds out there: graphics card supply has been choked for the last ~7 months yet the biggest player in the market continues to push out new models one after the other despite not being able to stock anything, even when the products use the same critical (and supply-scarce) parts and new models have barely any difference in performance between the previous (yet the demand is just as ferocious every time regardless)darrydonds wrote: ↑Mon May 03, 2021 6:45 amProduct announcement does not necessarily mean product delivery in any significant quantity. lolbikewithnoname wrote: ↑Thu Apr 22, 2021 3:20 pmSRAM really are rubbing thier superior supply chain in Shimano's face if this is true (and they can ship it). So many new releases this year!
