Remove/replace alu BB insert in carbon frame?
Hi all, I have an older Fuji carbon frame which I like but for the obsolete bb86 bottom bracket shell.
As the photo shows, the 86.5mm bb shell extends way beyond the frame and has some non structural carbon around the ends.
I would like to have the shell removed and the frame converted to a modern standard. Wondering in particular whether the shell can be debonded (with heat?) without damaging the frame.
Grateful for any advice.
Short answer, get a new frame as there is no practical means of removing that alloy insert. On a tangent, BB86/PF86 is hardly obsolete and from a technical standpoint, that 'older' alloy shell prevents many of the alignment issues present with curernt generation BB86 frames with an all-carbon bottom bracket shell. Finally, the newer standards like BBRight, BB386, T47, and even Colnago's Threadfit 82.5 all introduce there own set of issues, especially availability of replacement BB's for the more niche standards.
- Michael
It's a legit question: why would anyone really think BB86 is obsolete in 2021?
Wildly popular and well supported more like?
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
Ditto. Recently replaced a Soctt Solace disc frameset with a Colnago C64 disc frameset which has a threadfit 82.5 (T45) threaded bottom bracket. I opted to use the BBInfinite PF86 bottom bracket that had been installed in my Scott Solace as the only 'out of the box' theaded solution of which I am aware is the T45 bottom bracket Ceramic Speed made in collaboration with Colnago and which costs nearly US $350.
- Michael
I would not lump BB386 with the others. It really is the only sensible standard of those (except for maybe BB86, whose main issue is that it's specifically made as an anti-SRAM standard).ms6073 wrote: ↑Tue Apr 20, 2021 8:27 pmShort answer, get a new frame as there is no practical means of removing that alloy insert. On a tangent, BB86/PF86 is hardly obsolete and from a technical standpoint, that 'older' alloy shell prevents many of the alignment issues present with curernt generation BB86 frames with an all-carbon bottom bracket shell. Finally, the newer standards like BBRight, BB386, T47, and even Colnago's Threadfit 82.5 all introduce there own set of issues, especially availability of replacement BB's for the more niche standards.
Regret having opened a can of worms by referring to bb86 as obsolete. Suffice it to say I have a BB30 I really want to use with this frame.
I thought the glue used to fasten metal inserts has a lower melt point than the resin in the carbon fiber itself, and thus the inserts can be removed with heat. Perhaps I am wrong about that.
The metal shell is 86.5mm but the bike was designed form a 68mm shell so the alu tube sticks out either end. Now I am thinking a machine shop could potentially cut off the ends and bore in bearing seats (id is 41, enlarge to 42mm).
peligro wrote: ↑Wed Apr 21, 2021 1:48 amRegret having opened a can of worms by referring to bb86 as obsolete. Suffice it to say I have a BB30 crankset I really want to use with this frame.
- wheelsONfire
You probably could send it to a company doing carbon repair work. But then again, is it worth the cost?peligro wrote: ↑Tue Apr 20, 2021 3:31 pmHi all, I have an older Fuji carbon frame which I like but for the obsolete bb86 bottom bracket shell.
It's probably cheaper to buy a used but fitting crankset.
Bikes:
Open *UP* (2016.04.14)
Would have avoided a lot of ambiguity had you mentioned wanting to use BB30 from the start. As someone who at one point was trying to find a means of using a BB30 SRM on a BB86 frameset, I am again going to suggest that you will be better served sourcing a BB30 frame. If you want the stiffness of BB30, then a simple solution would be to use a BB386 crank with a bottom bracket applicable to BB86.
- Michael
There's virtually no chance a carbon repair company would even attempt this. I once had a frame with a damaged lower headset bearing cup (carbon molded into frame) and Calfee was the only company willing to try. It didn't end well. What you're asking is many times more complex, including changing the diameter. Even if it worked it would end up being much more expensive than the frame's value and many times more expensive than a compatible crank. I use a 386 crank (power meter) among a BB30, BB86, and a BBright frame - pretty simple to find the right bottom bracket/adapters.
