All-Rounder Bike Choice
gorkypl
by gorkypl
I'd go for Open up, 3t exploro, Cervelo aspero. Build it with Force axs or Campy Ekar and it should be an ace allround bike.
Cinelli Superstar Disc - Record 12s
LedZeppelin007
by LedZeppelin007
Thanks for all of the help. Am kinda thinking of getting a relatively cheap gravel bike and getting a mid spec road bike now
pacaalpaca
by pacaalpaca
How about Allied Alfa?
Aesch
by Aesch
Cervelo Caledonia 5 as mentioned above or argon 18 krypton pro (will clear 36c).
I'm looking at the latter option as my n+1, only thing holding me back is the slightly boring paint scheme
kode54
by kode54
My friends Caledonia 5 clears 32mm tires...the chainstays look a bit tight so going up a size to 35mm tires may not be possible. 3mm clearance on chain stay with Panaracer GK on Enve 3.4 AR wheels. If the OP is looking for a frame that'll fit 38, he's going to have to look elsewhere like the Aspero.
- Factor 02 VAM Disc
- Factor LS Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Moots Vamoots Disc RSL Ti
de lars cuevas
by de lars cuevas
https://www.focus-bikes.com/int/185837- ... ombo=95842 Rode it for 4 months for a review. Underestimated bike: 35 mm clearance, relatively light, comfortable, well priced.
CustomMetal
by CustomMetal
Factor LS or Open Upper?..
Perdita- Burls Ti - 8kg
Aurelia- Saffron Stainless/Carbon - 9kg
Bertha - Trek Speedconcept
Verity - Sturdy Ti/Carbon Aero (incoming)
Serenity- Sturdy Ti (incoming)
Allegra - Sturdy Steel Lugged (incoming)
Jolene - Aluminium Crit Bike (being reborn)
raggedtrousers
by raggedtrousers
I don't know if you've seen the latest issue of Gran Fondo, but they reviewed a Canyon Grail that had road tyres/wheels. That looked a surprisingly interesting option.
Beyond that, Open Up/Factor LS/3T Exploro/Cervelo Aspero with 2 wheel sets wil be your best bet.
nickf
by nickf
My Checkpoint could really be my one bike solution, truly. Room for 40+ tires, pretty normal geometry, 16lbs built, 2x drivetrain. Everything from all day gravel rides to fast group rides running 25s. To many of the other brands have oddball geometry.
gSporco
by gSporco
saldegracia wrote:
Thu Apr 15, 2021 3:59 pm
I'd just get a race-oriented gravel bike and have two wheelsets, one for road, one for gravel. Something like the Cervelo Aspero or the 3T Exploro.
Ill throw a second hat in the rimg for an Cervelo Aspero do it all bike.
I bought a 3T strada to do a weight weenie build and by the time i got 75% of the parts sought out I am now selling the frameset..
My Aspero is fast as hell in road mode and weighs 7KG with Sram Red AXS 2x with PM, pedals, cages, computer, 28mm tires and aero profile handlebars. I can easily go to 6.5kg by swapping somethings..
In gravel mode with 43mm tires it weighs 7.3kg
I am very very happy with it
Clean39T
by Clean39T
My Canyon Endurace SLX is effectively a race bike that fits 35s - I’ve been quite happy with its performance over the 750mi I’ve had it..
darrydonds
by darrydonds
Aesch wrote:
Fri Apr 16, 2021 8:34 pm
The Argon 18 Krypton Pro (and GF) is nice. I like their simpler way of achieving integration.
Cycomanic
by Cycomanic
Based on your description I'd have a look at the Ridley Kanzo Fast:
https://www.ridley-bikes.com/en_US/bikes/SBIKAFRID004
NiFTY
by NiFTY
I suspect you won't get much for either bike you sell. Why not keep the topstone, sell the s3 and get whichever road bike you like the look of. Realistically if you are getting one bike you will need 2 wheelsets as you are hardly going to change tyres every time you change surfaces.
TheRich
by TheRich
LedZeppelin007 wrote:
Thu Apr 15, 2021 3:16 pm
Thanks, I've given that some thought. It just pains me how heavy a lot of those are and I'm not even a big weight weenie. The Domane SL7 weighs (gulp) 8.8kg.
A Boone frame weighs a pound less than a Domane and will fit 38 (and no more!) mm tires. Very stiff under power and very comfy.
