lord_brush
by lord_brush on Thu May 13, 2021 10:53 am
robbosmans wrote: ↑Tue Apr 27, 2021 12:21 pm
Not for me no
Me neither- been using the Shanti for a while now and they don't leak at all.
A combination of the twist-lock, and the valve make them very water-tight. Even unlocked, the valve prevents leakage. The only thing you sometimes have to be aware of is if you use the twist-lock, the first time you unlock it, you can get a bit of pressure/ gas build-up if you've used an effervescent tablet. I guess it's a good indication of how tight they are....
The right to bear arms is slightly less ludicrous than the right to arm bears. (Chris Addison)
SamD
by SamD on Mon May 31, 2021 10:36 am
I actually wonder whether Tacx, which is owned by Garmin now, will continue to produce bottles as it is so far removed from the core business of Garmin. Anybody heard anything about this? I was curious about trying the Shanti Twist because of this thread, but they seem pretty hard to find, albeit that is not really an indication of anything anymore because of you-know-what
Discodan
by Discodan on Mon May 31, 2021 11:09 pm
FWIW I have both black and clear fly 950's and before their first use I put a layer of black duct tape and clear packing tape on the respective bottle (bottom half only). So far, a few months, it's done a great job of preventing any scuffing and still looks close to new. Once it's scuffed up I'll just replace it
req110 wrote: ↑Tue Apr 27, 2021 8:29 am
I have the 950ml Elite Fly too, and as you say it's very soft, it matters because
- easy to scratch extremely soon
- if loaded fully it can drop from bontrager XXX bottle cages or other "less secure" cages
req110
by req110 on Tue Jun 01, 2021 6:46 am
I did something similar, but then it's too tight for my other bottle cages
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
