Campy Bora WTO : Valve Extension
Hello,
So, my bora WTO didn't come with valve or valve extender. They were shipped from Europe and I gave up on trying to get them from the seller.
So I believe I need this 2-way fit valves: Campagnolo Unisex's 2-Way Fit Tubeless Valves, Silver/Black, Pair https://www.amazon.com/dp/B002SR1EUI/re ... JHRZK7CKGX
But when it comes to extenders I am not sure:
- are the valve with removable core?
- is there a non-campy product that would work?
#RETIRED# Lynskey “the Do-it-all Helix” :https://tinyurl.com/bdmb5y24
Thanks. Great username btw! Nothing better than Len Faki in the headphones to do a good Vo2max session on the trainer
Extenders are a such a PITA. Get proper valves that are the correct length.
They're not cheap, but Silca does make a set of tubeless valves in 44mm, 60mm, and 80mm lengths. But again, they're not cheap at $28 USD for the pair.
https://silca.cc/products/tubeless-valv ... peedshield
