The best stem for carbon steerer tubes
I am looking for an aluminium stem that allows to correctly spread the clamping force of the stem over a large area of the steerer tube.
Basically, I am looking precisely for the opposite of popular stems like the Extralite ones.
This is an example of what I do not want to use
This is an example of what I would like to find
Any idea?
Any idea?
Most are much nearer the top in terms of cut-out, as you have discovered.
Bontrager Race X Lite has a smaller cut-out than many, and works well on carbon steerers and bars in my experience. I've also had success with Ritchey C220/C260 and 3T Arx (first generation), but the cut-outs are larger than the Bontrager.
There is also another option: using a 1" 1/4 (or 1" 1/2) stem with an adapter for the standard 1" 1/8 steerer tube. I think that the adapter is thick enough to evenly spread the clamping force.
~I believe every Bontrager stem has no cutout in the clamping zone~ (no, actually XXX carbon or a few only).
Btw, what's the point of this small pin-hole? I don't think it reduces much weight nor the stem really needs hole to a drain water... The diameter doesn't seems enough big for a electronic cable.
I think it's for heat escape/relief during the production/forging process, otherwise the metal might warp or something.Cemicar wrote: ↑Thu Apr 01, 2021 2:29 pmI believe every Bontrager stem has no cutout in the clamping zone.
My guess would be that it's to allow the escape of air during manufacture.Cemicar wrote: ↑Thu Apr 01, 2021 2:29 pmI believe every Bontrager stem has no cutout in the clamping zone.
any imprint on the steerer tube is the sign of over-tightening. There's no need for any torque values about 4-5 Nm for stem/steerer bolts.
I torque mine to 4Nm with a Stahlwille torque wrench and it still leaves minor imprints.stevesbike wrote: ↑Thu Apr 01, 2021 4:05 pmany imprint on the steerer tube is the sign of over-tightening. There's no need for any torque values about 4-5 Nm for stem/steerer bolts.
May I ask why you want a stem like this?
Unless you have a paper thin carbon steerer you'll be fine with extralite, I've run them for over 10yrs on various forks without any marks/blemishes.
The hole shouldn't be a problem unless the stem is over tightened. I use nothing but stems with big holes and never have a problem. My stems for a long time were Ritchey and now I use the zipp sl service course.
The Ritchey Superlogic Carbon C260 is probably the most advanced design if you're really concerned. In addition to a huge surface area, the opening has a curved radius design so the clamping force is distributed and has 3 bolts with the middle bolt going the opposing direction and all 3 have a max torque of 4Nm. The faceplate is also well-designed with the stem having a 260 degree wrap on the bar.
