2022 New Frame Rumours
- wheelsONfire
Cervelo didn't want to disclose when new R5 is due for release!
Bikes:
Open *UP* (2016.04.14)
Saw the new Trek checkpoint today, so release should be soon. It has t47 bb, still the same seatpost setup, downtube compartment but no more adjustable rear dropouts. The cables were integrated like on the emonda, except there were no shaped spacers but standard round ones on top of the bearing cap. The cables came out from some individual holes with rubber around it, probably a good idea for a gravel bike. The steerer is fully round and the compression ring was metal, but mounted upside down on the bike... (all cables and hoses had to be removed) Got a bit closer look than I would have liked, the top bearing does look very thin. Overall it did look very sleek, pretty similar to the last generation apart from the fork and integrated cables
Sounds exactly like the bike im looking for. Mostly Gravel, but with the option to swap wheelsets for road use; Threaded BB and sleek internal cables.
Saw this on WvA IG. Looks like a green to burgundy fade.
The new BH Aerolight looks very sexy!
https://aerolight.bhbikes.com/?lang=en
- robbosmans
- Moderator
- Contact:
Whoever built this bike should be fired
Also the B-screw of the RD...
- robbosmans
- Moderator
- Contact:
The whole “wrong” list
- shifters
- b screw
- wrong chain
- wrong casette
- shimano rotors sram bike?
- old zipps
- shifters
- b screw
- wrong chain
- wrong casette
- old zipps
- Contact:
But the fork design is more “aero”maquisard wrote:Yes, the shifters/levers look terrible. The fork also looks the wrong way around, but is actually correct udging by other press infos.
Dylanlspangler wrote: ↑Wed Jul 21, 2021 1:01 pmBut the fork design is more “aero”maquisard wrote:Yes, the shifters/levers look terrible. The fork also looks the wrong way around, but is actually correct udging by other press infos.
I mean...there’s logical reasons for why it would be, but yes it’s ugly.
And if you take a pic of your bike, you dont use the small ring with the smallest sprocketrobbosmans wrote: ↑Wed Jul 21, 2021 8:17 amThe whole “wrong” list
- shifters
- b screw
- wrong chain
- wrong casette
- old zipps
Is that chain a bit short?TourmaletteduFromage wrote: ↑Wed Jul 21, 2021 6:46 amSaw this on WvA IG. Looks like a green to burgundy fade.
