Agree that BB86 is not ideal. But let's not overstate things - there are very nice threaded BBs that you can slot in there to replace stock plastic cups that will work trouble free for years. Although yes, 30mm axle is best avoided. I suppose this is why they went with Rotor for their CFR DA setup - Rotor allows you to choose between 30mm and 24mm axles.wheelsONfire wrote: ↑Fri Jan 27, 2023 2:57 pmOnly color that looks good is Alpecin-Deceuninck Replica and atleast here, only in CFR version which is too expensive.
Same shitty BB86 standard to
2021 Canyon Aeroad
I'm interested in an Aeroad CF SLX 8 Disc Di2, it seems to match my needs. I'm quite a tall rider at 196cm. With very tall legs so I need my saddle to be quite high. Looking at the geometrie of a XXL frame, the seatpost lenght (B) is 623mm, the seatpost itself is 335mm, minus the minimum insertion of 122mm. Would be a total of 623mm + 213mm = 836mm. That would not be enough for me, did anyone else face this problem and find a solution? Darimo for example doesn't mentoin available for the latest model Aeroad. They do make very long seatposts so I guess that could be an option.
I have a 2XL; (also SLX di2) I'm 190cm but very long legs (I think my inseam is95 or 96, measured at canyon Koblenz). I have 8mm to spare (seattube insertion wise), and the rails are 83cm from center BB. Standard saddle is then at 87.5 (top). LMK if you need me to measure anything.MrRolandos wrote: ↑Fri Jan 27, 2023 5:58 pmI'm interested in an Aeroad CF SLX 8 Disc Di2, it seems to match my needs. I'm quite a tall rider at 196cm. With very tall legs so I need my saddle to be quite high. Looking at the geometrie of a XXL frame, the seatpost lenght (B) is 623mm, the seatpost itself is 335mm, minus the minimum insertion of 122mm. Would be a total of 623mm + 213mm = 836mm. That would not be enough for me, did anyone else face this problem and find a solution? Darimo for example doesn't mentoin available for the latest model Aeroad. They do make very long seatposts so I guess that could be an option.
Its 41 mm bore is smaller than ideal for 30 mm spindles or DUB (28.99mm). BB386EVO at 46 mm would perhaps be a better choice if sticking with press fit.
That being said, I have 2 well made BB86 frames (Giant and Basso) with DUB cranks and standard, cheap SRAM DUB BB cups and haven't experienced any problems with durability or noise, and I frequently ride in wet conditions. So I have come to believe that the theoretical shortcomings of BB86 with DUB are somewhat overblown and not necessarily borne out in practice.
- wheelsONfire
The 30mm ID bearings for BB86 is 41mm OD and 25% less durable than a 42mm OD bearing.
Totally st*pid to use this BB standard.
Bikes:
Open *UP* (2016.04.14)
Yeah I am 196cm, 98cm legs. Currently rails is +/- 85cm from center and top is like 88cm. And my fitter told me I can push the saddle up more. I think thats gonna be a problemTomS wrote: ↑Fri Jan 27, 2023 9:10 pmI have a 2XL; (also SLX di2) I'm 190cm but very long legs (I think my inseam is95 or 96, measured at canyon Koblenz). I have 8mm to spare (seattube insertion wise), and the rails are 83cm from center BB. Standard saddle is then at 87.5 (top). LMK if you need me to measure anything.MrRolandos wrote: ↑Fri Jan 27, 2023 5:58 pmI'm interested in an Aeroad CF SLX 8 Disc Di2, it seems to match my needs. I'm quite a tall rider at 196cm. With very tall legs so I need my saddle to be quite high. Looking at the geometrie of a XXL frame, the seatpost lenght (B) is 623mm, the seatpost itself is 335mm, minus the minimum insertion of 122mm. Would be a total of 623mm + 213mm = 836mm. That would not be enough for me, did anyone else face this problem and find a solution? Darimo for example doesn't mentoin available for the latest model Aeroad. They do make very long seatposts so I guess that could be an option.
Could someone with an Aeroad with bars at full height tell me this distance (to the point at the center part of the bars)?
Does anyone know if people from canyon are actually reading this forum? I really wish they were more transparent about the decisions they have made with the aeroad. None of them make sense and in the US I haven’t been able to get any info from anyone on anything.
Their engineers' heads are so far up their asses that they would probably tell everone here that has an issue they're doing something wrong and the design is perfectly great. I don't know how familiar you guys are with older German engineers but some of these guys have heads that are made of concrete.mrbrown4001 wrote: ↑Mon Jan 30, 2023 7:21 pmDoes anyone know if people from canyon are actually reading this forum? I really wish they were more transparent about the decisions they have made with the aeroad. None of them make sense and in the US I haven’t been able to get any info from anyone on anything.
If you don't believe me look at their presentation about that self steering crap, talk about a circle jerk.People that raise their hand and say "this kinda doesn't make sense?" don't last in places like Canyon.
I really hope this isn’t the case.spartacus wrote:Their engineers' heads are so far up their asses that they would probably tell everone here that has an issue they're doing something wrong and the design is perfectly great. I don't know how familiar you guys are with older German engineers but some of these guys have heads that are made of concrete.mrbrown4001 wrote: ↑Mon Jan 30, 2023 7:21 pmDoes anyone know if people from canyon are actually reading this forum? I really wish they were more transparent about the decisions they have made with the aeroad. None of them make sense and in the US I haven’t been able to get any info from anyone on anything.
Have you seen the engineering choices they've made lately?mrbrown4001 wrote: ↑Mon Jan 30, 2023 7:57 pmI really hope this isn’t the case.spartacus wrote:Their engineers' heads are so far up their asses that they would probably tell everone here that has an issue they're doing something wrong and the design is perfectly great. I don't know how familiar you guys are with older German engineers but some of these guys have heads that are made of concrete.mrbrown4001 wrote: ↑Mon Jan 30, 2023 7:21 pmDoes anyone know if people from canyon are actually reading this forum? I really wish they were more transparent about the decisions they have made with the aeroad. None of them make sense and in the US I haven’t been able to get any info from anyone on anything.
Thanks for explaining the BB stuff.
I am thinking about replacing my crankset to a QUARQ+SRAM Red DUB from normal Shimano Ultegra on the Endurace. Is this combo equally bad as the standard Ultegra I have now, or is it worse, and for what reason? I know it's kinda off topic, but it's the same BB the Aeroad uses anyway.
Also, it seems to me that Canyon have obviously steered away from solely trying to create "the best bikes ever" and more into making it easier for them to make their bikes cheaper to manufacture and ship.
