2021 Canyon Aeroad
- robbosmans
- Moderator
- Contact:
No just turn it around, the printing isn’t always correct. If the caliper is in the high position on a 160mm rotor, the low position will be for 140
The rear you just remove the adapter
Anyone have any suggestion on losing additional weight? Have ordered a wheelset which will probably lose close to 400g. Ordered 140mm Galfer wave rotor. So total could potentially be close to 500g lost(Estimation as no weight scale). May go TPU tubes and change the rear 28mm GPs to 25. Have yet to order to bolts for the handlebar and brake calipers.bratz wrote:Been riding the Aeroad CF SLX 8(Ultegra Di2) for a few months and am looking for ways lose some weight off the bike. I'm somewhat wanting to keep the ARC1400 wheel as I like it a lot even though it is 1700+?gram
Currently I have replaced the stock saddle with a carbon saddle , vittoria latex tubes with GP5Ks and Sram Red 11 crank with CarbonTi 52/36 chainring with Assioma pedals. Generic 15g bottle cage. Ti bolts on F/R derailleur.
Planning to replace Ultegra rotors with Galfer wave and getting the Sigeyi DM hanger.
Is there a light axle option for this bike. Any other weight loss suggestion? Need to lose some weight myself
Sent from my SM-N975F using Tapatalk
Does anyone has a feedback on these axle?
https://www.ebay.com.sg/itm/30386025765 ... media=COPY
I use that brand for my Cervelo R5 axles.bratz wrote:Anyone have any suggestion on losing additional weight? Have ordered a wheelset which will probably lose close to 400g. Ordered 140mm Galfer wave rotor. So total could potentially be close to 500g lost(Estimation as no weight scale). May go TPU tubes and change the rear 28mm GPs to 25. Have yet to order to bolts for the handlebar and brake calipers.bratz wrote:Been riding the Aeroad CF SLX 8(Ultegra Di2) for a few months and am looking for ways lose some weight off the bike. I'm somewhat wanting to keep the ARC1400 wheel as I like it a lot even though it is 1700+?gram
They work great as long as you don't over torque them.
That label is correct. It says 160mm OR 180mm on 180/160mm mount. But it's a 160/140mm mount, so the 160mm applies. 140mm is printed on the other side, so that when you flip the mount, the text facing out and readable.robbosmans wrote: ↑Tue Oct 25, 2022 1:50 pmNo just turn it around, the printing isn’t always correct. If the caliper is in the high position on a 160mm rotor, the low position will be for 140
Cool. Have a torque wrench..currently am doing my wheels at 9nm. Need to find out original axle weight.Aryeh wrote:I use that brand for my Cervelo R5 axles.bratz wrote:Anyone have any suggestion on losing additional weight? Have ordered a wheelset which will probably lose close to 400g. Ordered 140mm Galfer wave rotor. So total could potentially be close to 500g lost(Estimation as no weight scale). May go TPU tubes and change the rear 28mm GPs to 25. Have yet to order to bolts for the handlebar and brake calipers.bratz wrote:Been riding the Aeroad CF SLX 8(Ultegra Di2) for a few months and am looking for ways lose some weight off the bike. I'm somewhat wanting to keep the ARC1400 wheel as I like it a lot even though it is 1700+?gram
FYI, I measured my thru axels and they're not as depicted in the listing.bratz wrote: ↑Fri Oct 28, 2022 5:39 amAnyone have any suggestion on losing additional weight? Have ordered a wheelset which will probably lose close to 400g. Ordered 140mm Galfer wave rotor. So total could potentially be close to 500g lost(Estimation as no weight scale). May go TPU tubes and change the rear 28mm GPs to 25. Have yet to order to bolts for the handlebar and brake calipers.bratz wrote:Been riding the Aeroad CF SLX 8(Ultegra Di2) for a few months and am looking for ways lose some weight off the bike. I'm somewhat wanting to keep the ARC1400 wheel as I like it a lot even though it is 1700+?gram
The front DT Swiss thru axle (12x100mm) weights 30 grams. The rear DT Swiss thru axle (12x142mm) weights 40 grams.
Those screws look a bit „corroded(„?). Kinda similar to one of my screws that keep the handlebar width in place. Which is by the way sometimes cracking a bitcberg wrote:14g going from the old Canyon mount to their new Forward AM mount
Is the angle of the garmin similar with the new mount?
The Garmin is much closer to horizontal with the new oneEterna7m wrote: ↑Tue Nov 01, 2022 8:43 amThose screws look a bit „corroded(„?). Kinda similar to one of my screws that keep the handlebar width in place. Which is by the way sometimes cracking a bitcberg wrote:14g going from the old Canyon mount to their new Forward AM mount
