2021 Canyon Aeroad
Went out for a ride Sunday that was in winds probably in the range of 25-30mph with stronger gusts. Bike did pretty well and I was hit with a large amount of direct cross winds. The AR 58/62 handled better than some 45-50mm wheels I have used.
Hi, after 2100km the handlebar screws of my Aeroad CF SL 8.0 have loosened. It is true that I have never checked. I had tightened the screws to 5nm as recommended. Has anyone had a similar experience? do you have any tricks to overcome this problem in the future?
Aeroad CF SL 8 Disc 8kg
pedrop wrote: ↑Thu Apr 29, 2021 12:51 pmHi, after 2100km the handlebar screws of my Aeroad CF SL 8.0 have loosened. It is true that I have never checked. I had tightened the screws to 5nm as recommended. Has anyone had a similar experience? do you have any tricks to overcome this problem in the future?
Canyon Aeroad CFR Di2 | Canyon Ultimate SLX 9.0 Di2 | Trek Domane SL5 Disc (Gravel Bike / Fly-Away Road Bike) | Orbea Tera H-30 Disc (Touring Bike)
You are all spending many thousands on the bike but play around with inferior lights.
https://www.lupine-shop.com/en/new-in-t ... vzo-canyon
https://www.canyon.com/en-de/gear/acces ... 06600.html
Also available for the SL X lamp, and surely going to be available for the SL Nano soon.
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
Not sure if I would spend thousands on a light bike (7.2 kg) and then add a 360g lightAeo wrote: ↑Fri Apr 30, 2021 2:53 pmYou are all spending many thousands on the bike but play around with inferior lights.
500 euro for that monstrosity no thanksAeo wrote: ↑Fri Apr 30, 2021 2:53 pmYou are all spending many thousands on the bike but play around with inferior lights.
Same here, think I'm at 2500 km and no problem with the handlebars or seat post so far. Although I'm using the 3M electrical tape solution for the seat post as well and I'm a bit more careful with the handlebar than I would usually be.
No problems with the seatpost, but my CFR has developed a bottom bracket creak after ~1700 km. It's only on the right side and is very annoying. I'm planning on replacing the BB as soon as parts and tools arrive this week.
