bratz
by bratz on Sun May 28, 2023 6:42 am
mrbrown4001 wrote:bratz wrote:Im ok with the bar....just not thrilled that we cant purchase different size...needed a 100mm to swap with my 90mm...any ideas how to gain some reach
Sent from my SM-N975F using Tapatalk
I’d check Facebook groups for canyon owners, I saw some people looking to swap or get rid of bars there.
Did that...cant find any...did email Canyon few weeks ago to check if it is now available to purchase separately...not available though
mrbrown4001
by mrbrown4001 on Wed May 31, 2023 6:42 pm
I’m curious to know if anyone has just tried drilling more holes in their cockpit to make it more narrow. Obvious safety issues aside is that even possible or would more need to be done to make the stock handlebars more narrow?
spdntrxi
by spdntrxi on Wed May 31, 2023 6:51 pm
mrbrown4001 wrote: ↑Wed May 31, 2023 6:42 pm
that is asking for it... I would hope that the layup would be strengthend around existing holes, but if you drill new ones no way
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
mrbrown4001
by mrbrown4001 on Mon Jun 05, 2023 9:28 pm
I spoke to a canyon USA rep online who said that a 105 di2 build of the aeroad is coming. They wouldn’t tell me if it would be an SL or an SLX model but I think we all know it will be an SLX model.
Also, canyon is clearly working on new handlebar shapes for an upcoming gravel bike. See the link below. I hope this means that what we new shapes they are working on will be compatible with their road frames. Hopefully they will come in a dimension that is at least 36cm at the hoods and they are available for purchase.
https://www.bikeradar.com/news/unbound- ... yon-grail/
Lina
by Lina on Tue Jun 06, 2023 8:42 am
But it might mean that they're abandoning the quill stem idea. Which if we're being honest should have never left the designers table. Coming up with that idea and presenting it with a straight face to someone should be grounds for immediate firing, just like approving it. It would maybe be understandable if it was one of the first integration solutions on the market. But it wasn't, it was one of the last ones and they had plenty of time to study other attempts. There were so many others out there that some brands were on their second iteration already. And it was obvious what the optimal solution was, especially when the brands that were on the second iteration were pretty much all moving to the same direction.
cnyn
cberg
by cberg on Thu Jun 15, 2023 12:51 pm
Headset also seems to have been redesigned slightly. Torque spec is higher(?) and it seems like there's a black cap below the clamping mechanism
The white SLX is also gone.
cnyn
by cnyn on Thu Jun 15, 2023 12:55 pm
Youre right, torque was 9 Nm and now the spacer/cap is as wide as the end of the stem/bar combo. Old Spacer/Cap was a bit wider than the stem/bar combo at the stem end side.
