2021 Canyon Aeroad
- wheelsONfire
This is going to be one of those bikes i would never buy second hand...
Bikes:
Open *UP* (2016.04.14)
No I think the seat post issue doesn't effect all bikes and the pro bikes especially because they're serviced everyday. If a seat post wears they replace it and move on so the issue doesn't concern them.LancashireDry wrote: ↑Sun Sep 26, 2021 6:08 pmAnyone else notice that MVDP wasn't using the new seatpost sleeve today?
Does this mean the sleeve and rubber gasket is a modification to cover existing frames and there will be a new frame to achieve the original 'visual' design intent?
- willvousden
- Contact:
Ironically the MvdP version is the only Aeroad model on the Canyon website that is shown with a gasket:LancashireDry wrote: ↑Sun Sep 26, 2021 6:08 pmAnyone else notice that MVDP wasn't using the new seatpost sleeve today?
https://www.canyon.com/en-de/road-bikes ... be=WH%2FMC
But again thats a consumer bike. so the seat post isnt being cleaned and greased every day, hence it has the gasket.willvousden wrote: ↑Mon Sep 27, 2021 12:45 pmIronically the MvdP version is the only Aeroad model on the Canyon website that is shown with a gasket:LancashireDry wrote: ↑Sun Sep 26, 2021 6:08 pmAnyone else notice that MVDP wasn't using the new seatpost sleeve today?
I certainly hope that the new frames that are (supposedly!) about to become available don't use the sleeve. Does anyone know? If they do need the sleeve, you would expect they would update the photos on the website to show customers what they are actually going to deliver.LancashireDry wrote: ↑Sun Sep 26, 2021 6:08 pmAnyone else notice that MVDP wasn't using the new seatpost sleeve today?
Is the seat post replaced due to slight wear or because it has different size on the top insertion portion? If it's the same size does it mean that the solution for this is to simply glue plastic collar on top of the existing frame to get some realstate for a rubber seal?akb wrote: ↑Wed Sep 22, 2021 8:03 pmI picked up my CFR yesteday from the Service Center (Eindhoven NL). Although there was only minor wear to the seatpost they replaced it with a new one. The sleeve looks ok-ish. Don't want to disassemble it yet to inspect the internals. There are new instructions on how to place the seatpost back into the frame: clean the seatpost and don't apply any assembly paste.
The new handlebars feels a bit thin compared to the old one. I preferred the "squared rouding" of the original one. Hopefully I will get used to it.
From the wording of the last email I got from Canyon and what other users have posted, it seems like they are removing the existing "sleeve" that sits between frame and seatpost to replace it with the new one that goes further up. Looks wise for me, it's no different than the seatpost collar on the current gen Scott AddictIvanZg wrote: ↑Mon Sep 27, 2021 3:06 pmIs the seat post replaced due to slight wear or because it has different size on the top insertion portion? If it's the same size does it mean that the solution for this is to simply glue plastic collar on top of the existing frame to get some realstate for a rubber seal?akb wrote: ↑Wed Sep 22, 2021 8:03 pmI picked up my CFR yesteday from the Service Center (Eindhoven NL). Although there was only minor wear to the seatpost they replaced it with a new one. The sleeve looks ok-ish. Don't want to disassemble it yet to inspect the internals. There are new instructions on how to place the seatpost back into the frame: clean the seatpost and don't apply any assembly paste.
- willvousden
- Contact:
If new frames are going to be available soon, what are they going to do with the 2021 models that are still shown as "Coming Soon" on their website? It doesn't seem to make much sense to buy one of those right now.Mick1508 wrote: ↑Mon Sep 27, 2021 1:55 pmI certainly hope that the new frames that are (supposedly!) about to become available don't use the sleeve. Does anyone know? If they do need the sleeve, you would expect they would update the photos on the website to show customers what they are actually going to deliver.LancashireDry wrote: ↑Sun Sep 26, 2021 6:08 pmAnyone else notice that MVDP wasn't using the new seatpost sleeve today?
- robbosmans
- Moderator
- Contact:
There won’t be a “new” frame just update with the rubber sleeve.
hi all, I have a question regarding the cp10 cockpit which is on the aeroad cf sl 2021. I'm looking to replace it but before I do, I would like to know if anyone could tell me whether the cables pass through the bar or not. If they don't pass through, it would make replacing it with a different cockpit a lot more eaesy (just loosen the shifters and reattach). From the bottom of the bar it looks like they go in the bar but I can't tell for sure because off the bar tape..
I have a similar setup which is shown here:
After some Googling I found a picture from the bottom side of the cockpit without bar tape. It looks like the cables are only running through the compartment on the bottom and aren't integrated in the cockpit itself.koene wrote: ↑Mon Sep 27, 2021 9:18 pmhi all, I have a question regarding the cp10 cockpit which is on the aeroad cf sl 2021. I'm looking to replace it but before I do, I would like to know if anyone could tell me whether the cables pass through the bar or not. If they don't pass through, it would make replacing it with a different cockpit a lot more eaesy (just loosen the shifters and reattach). From the bottom of the bar it looks like they go in the bar but I can't tell for sure because off the bar tape..
