12 speed Campy crank with 11 speed drivetrain?
Apologies if this has been discussed elsewhere but this pertains to a powermeter.
I'd like to get a Power2Max Campagnolo powermeter, and I'm wondering if I get it with the 12 speed chainrings if this will cause problems with my existing 11 speed drivetrain and parts.
I do not plan on upgrading to 12 speed anytime soon, but a powermeter is a pricey part, so I'm aiming to 'future proof' if and when I do eventually get 12 speed.
I'm pretty sure that power2max cranks are compatible with either. You choose the correct chainrings. Per their page:
Please note: Make sure to use the specific 2x11 or 2x12 chainrings for your drivetrain.
i have beenusing Chorus 12 chainset with Centaur groupset for just over a year (about 15,000km), no problem at all. shifts fine, no excessive wear on chain/chainrings so far.
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes.
n+1...14 last time i checked, but i lost count
I'm using a Chorus 12 chainset in an EPS11 drivetrain. Works perfectly.
cycling / nature / music
P2max and SRM did not change anything for 11 to 12 jump.. Campy redid the logo on the crank, the arms never changed.. I own an 11s labeled SRM the new 12, and an NG on my TT bike.. they all fit the same... will not be an issue at all..
How are 4 bolt 11 speed and 12 speed chainrings dimensionally different?
I have two bikes with Chorus 12 speed 48/32 cranks and Chorus groups that both work fine. Cranks seem to be more adaptable than other parts to different chains and cassettes. I remember a Record 8 speed crank that worked fine with 9 and 10 speed and later several 11 speed cranks working fine with 10 speed groups.
