Speedplay Zero PM coming?
You you mean the old cafe stop covers for the old metal cleats? These were OK, but they did have a tendency to fall off and get lost. With the walkable cleats you can just walk straight off of the bike (the cleats grip just as well as the old covers did), unless you are walking on dirt or gravel, when you need to fit the central round covers (which are more secure than the old cafe stops and smaller to carry).
What do you guys do against annoying squeaks with speesplay pedals. For me the walkable cleats are a lot more noiser. I have tried different dry lubes/wet lubes (with wet lubes you always get dirty legs somewhere), but it is a pain sometimes. Worst pedal for me regarding noise: Speedplay Aero -> Pave -> Zero.
IME, the squeaks happen when the cover isn’t fully seated on the cleat. Even one corner that is slightly on but not fully can cause noise. Look at all the corners and if you can see metal, your cover isn’t fully on.Erwin wrote:What do you guys do against annoying squeaks with speesplay pedals. For me the walkable cleats are a lot more noiser. I have tried different dry lubes/wet lubes (with wet lubes you always get dirty legs somewhere), but it is a pain sometimes. Worst pedal for me regarding noise: Speedplay Aero -> Pave -> Zero.
TT’s and triathlon. When dual entry isn’t a consideration.neeb wrote:I have wondered about the market for the aero version of the speedplay pedal. You'd have to be really, really into absolute maximisation of aero gains to sacrifice dual-sided entry for whatever fraction of a watt you'd gain from those..
'Spose so.. I'd have thought even with tri though you'd be more likely to lose 5s faffing with clipping in during the transition than to gain half that from any aero benefits..stevej wrote: ↑Fri Mar 26, 2021 1:41 amTT’s and triathlon. When dual entry isn’t a consideration.neeb wrote:I have wondered about the market for the aero version of the speedplay pedal. You'd have to be really, really into absolute maximisation of aero gains to sacrifice dual-sided entry for whatever fraction of a watt you'd gain from those..
<edit> Oh, Ok - they have the shoes attached to the pedals first, I take it back... Still, the helmets-on-backwards must lose more aero watts than the pedals gain..
To those saying there isn't a difference in pedal options.
First of all, speedplay pedals, especially with a 4 bolt shoe, have the lowest stack height of any pedal system. 3mm lower is still 3mm lower.
Secondly, ERO sports did some testing with Brandon McNulty and there was a small difference for aero speedplays pedals vs regular. I can't remember the number and the link I had saved seems to be broken when they redesigned their website. It's not massive but it does exist for track racers or tri freds.
Nice to see this updated version . May try them finally, the original were too much of a mess " for me ", after seeing one good friend with them , and only riding them one ride ( so not much I take that )
If I find the courage to drill my 3 holes shoes to 4 holes,
Or I would use northwave thin adaptator .
Dan Biggles and his conversion available at wattshop.uk for 3 holes isn't lower stack than even 4holes bont ?
I tought so. Cause they had to put more material where the 4 bolts are compared to regular version .
- customtune
- Contact:
https://podcasts.apple.com/au/podcast/c ... 0513697197
Was interesting to hear where speedplay has had issues as a company and functionally. I liked the idea of including 2 springs with a cleat. I know I've broken a couple with the rest of the cleat still working.
The foremost attraction for me is the (probably) lowest stack height, which I achieved using the Northwave adaptor and much fluffing about on my Bont shoes but without buying new shoes.
If stack height is not important to you, just buy a set and go for it. Buy the cro-mo version for the least outlay, and upgrade to aftermarket ti spindles if you enjoyed the experiment. Much later if you wish to go the whole hog buying 4-hole shoes, do some proper research to make sure you are indeed reducing stack height.
Recently, I saw the old models come on sale at Bike Bug.
Less is more.
ThanksshimmeD wrote: ↑Tue Mar 30, 2021 1:40 amThe foremost attraction for me is the (probably) lowest stack height, which I achieved using the Northwave adaptor and much fluffing about on my Bont shoes but without buying new shoes.
- customtune
- Contact:
I'd like to know if the pedal bodies of the wahoo pedals will be compatible with their power meter. And if compatible from old Speedplay to Wahoo? If the speedplay nanogram body is lighter than new composite nano and both fit the new power meter spindle could be a lighter option. Titanium spindles won't work read reliably with strain gauges attached.
