What issues did you have? And were they recurrent or fixed for good?velov wrote: ↑Fri Jan 20, 2023 2:08 amI've had some issues with the Quickset headset on my VXR, but nothing serious enough to stop me from riding. Personally, I couldn't care less about aerodynamics, if I got paid to ride then I probably would. Ride quality and aesthetics are the two most important factors for me. And aesthetically I think a clean front end does look better.
The Time Bicycles Thread -- Time Frames, Bikes, & Hardware Components After Sale To Cardinal Cycling Group
IMHO, iIn the end it's all about choice. I don't like the hassle of fully internal cable routing and discs as a home mechanic who loves to tinker and wrench on my bike. The list of things that one has to remove the hydraulic lines and flush/re-bleed brakes for is just too long, including travelling with a bike (who wants to bleed brakes and bring a kit/fluid in a hotel room??)mathemagician wrote: ↑Thu Jan 19, 2023 2:48 pmI have a current model AdH21 so I don't really have a dog in this fight, but I've always wondered why people get so worked up about how easy or not it is to replace headset bearings. How often are you doing it- so much that it becomes a deal breaker? So you've got to disconnect a couple of hydraulic lines and bleed some brake...who cares? Hoses for all 3 groupset manufacturers can be disconnected at the shifter, so it's not like they have to be routed through the frame again. I just don't get the big deal.steveadore wrote: ↑Thu Jan 19, 2023 11:53 amIt is certainly more sensible than some others, BUT for me the question is: Can one replace a headset bearing without touching hydraulic brake lines or not?
For people who want to chase those marginal aero gains and have the cleanest looking frame with nothing visible, go for it, more power to you. I just don't like that very very few manufacturers even let me make the choice of external cabling and/or rim brakes any longer.
In positive news, I just took delivery of a full set of R8150 Di2 components and some lovely Bora WTO 45s. Just waiting for frame delivery now!!
Road - Time Alpe d'Huez 01 rim
All-road - Diverge Elite DSW '16 disc
Internal cabling done properly doesn't mean you have to rebleed after traveling. On a well made integrated solution pretty much the only thing you need to rebleed is if you are replacing the upper headset bearing or swapping handlebars that are routed internally. But in the latter case you'd have to do it even if it's not an integrated frame.MDecius wrote: ↑Fri Jan 20, 2023 1:20 pmIMHO, iIn the end it's all about choice. I don't like the hassle of fully internal cable routing and discs as a home mechanic who loves to tinker and wrench on my bike. The list of things that one has to remove the hydraulic lines and flush/re-bleed brakes for is just too long, including travelling with a bike (who wants to bleed brakes and bring a kit/fluid in a hotel room??)mathemagician wrote: ↑Thu Jan 19, 2023 2:48 pmI have a current model AdH21 so I don't really have a dog in this fight, but I've always wondered why people get so worked up about how easy or not it is to replace headset bearings. How often are you doing it- so much that it becomes a deal breaker? So you've got to disconnect a couple of hydraulic lines and bleed some brake...who cares? Hoses for all 3 groupset manufacturers can be disconnected at the shifter, so it's not like they have to be routed through the frame again. I just don't get the big deal.steveadore wrote: ↑Thu Jan 19, 2023 11:53 amIt is certainly more sensible than some others, BUT for me the question is: Can one replace a headset bearing without touching hydraulic brake lines or not?
There was some wear inside the headtube where the top cap sits so. Not sure how that happened. I've put the VXR on permanent trainer duties till I can be bothered to get it looked at properly.steveadore wrote: ↑Fri Jan 20, 2023 8:59 amWhat issues did you have? And were they recurrent or fixed for good?velov wrote: ↑Fri Jan 20, 2023 2:08 amI've had some issues with the Quickset headset on my VXR, but nothing serious enough to stop me from riding. Personally, I couldn't care less about aerodynamics, if I got paid to ride then I probably would. Ride quality and aesthetics are the two most important factors for me. And aesthetically I think a clean front end does look better.
Has anyone tried to ride two different sizes of the ADH? I should definitely be a size M, but due to my shorter legs I find the top tube a bit too tall, so I'm contemplating a size S. The smaller size would definitely require all the spacers (30mm) under the stem and a 0 degree, 115mm stem. On the M, I could do with a -6 degree, 100mm stem. This would be an all-rounder endurance bike, not for racing, so the sizing down would not be motivated by the usual considerations of "light/nimble/aggressive" but merely by concerns about standover height and top tube clearance (I can straddle the size M, but there's not even an inch clearance). In fact, I normally prefer to size up (for lon distance leisure rides I find that more comfortable)
If anyone is between two sizes or has sized down, what has been your experience? Is it better to stay true to recommended size?
The 100mm stem IMO is on the short size. My guess is that the S is probably the correct size with the 115mm stem but if you don't like the spacers it probably won't be a problem to size up. We didn't have much, if any, standover clearance back when we had horizontal top tubes.
I'm usually in the same quandry. Ride a 56 with a 2-3cm of spacers or ride a 58 with a short stem and no spacers.
I'm fine with 100mm stems (currently ride a 90mm stem and actually like the snappier steering). I'm 179 cm tall, which is almost at the upper end of the size M range according to Time's chart. But my saddle height is only 71.5 cm. I'm not sure I would like the 115mm stem and a stack of spacers and a 0 degree stem (which almost looks like a flipped stem visually).AJS914 wrote: ↑Sat Jan 28, 2023 6:20 pmThe 100mm stem IMO is on the short size. My guess is that the S is probably the correct size with the 115mm stem but if you don't like the spacers it probably won't be a problem to size up. We didn't have much, if any, standover clearance back when we had horizontal top tubes.
Time updated their website with promo material and colorways for the 2023 AdH Disc!
https://global.timebicycles.com/en-gb/p ... dhuez-disc
Nothing much to highlight. No new colours compared to what has been floating around online for some time, max 28c clearance, and electronic shifting only
Your link is a 404, but this one should work: https://shop.timebicycles.com/collectio ... collection
Interesting to see that the 2023 is some $600 USD less than the previous version.
Thanks. I was hoping it was early this year, I'll just go with Schmolke in that case.
There is one less size available for the 2023.EvilEuro wrote: ↑Mon Jan 30, 2023 3:35 pmYour link is a 404, but this one should work: https://shop.timebicycles.com/collectio ... collection
Any idea about the weight of the new ADH?
#RETIRED# Lynskey “the Do-it-all Helix” :https://tinyurl.com/bdmb5y24
Unbelievably beautiful and shockingly low priced for what you get. Disappointed with the maximum tire size of 28, although kudos for Time speccing Goodyear F1 tires -- they are fantastic and light.
Cannondale Supersixevo 4 (7.05 kg)
Retired: Chapter2, Tarmac SWorks SL6, Orbea, Dogma F8\F10, LOW, Wilier, Ridley Noah, Cervelo R3\R5\S2\Aspero, Time Fluidity, Lapierre Pulsium, Cyfac, Felt, Klein, Cannondale pre-CAAD aluminum
