The Time Bicycles Thread -- Time Frames, Bikes, & Hardware Components After Sale To Cardinal Cycling Group
Don't recall the previous ADH01 price, but now RRP is 4400 EUR for both rim and disc frames (I'm pretty sure it was much cheaper than that).
Damn...I really lucked out with my frame purchase- think it was £1700 unpainted, in February!
Sent from my CPH2207 using Tapatalk
Few month ago the price without Active fork was 3.999€, the price with Active fork 300€ more.steveadore wrote: ↑Sat Oct 22, 2022 7:30 pmDon't recall the previous ADH01 price, but now RRP is 4400 EUR for both rim and disc frames (I'm pretty sure it was much cheaper than that).
Anyway if they really stopped manufacturing this model, the current retail price shown on the website does not mean much...
- MrCurrieinahurry
- Moderator
Was that for the 01 (top model not the 21)mathemagician wrote:Damn...I really lucked out with my frame purchase- think it was £1700 unpainted, in February!
Anybody with some info on the 2023 models (@Solo77) knows if Time will stick with BB386 EVO?
Reason I'm asking is that I just got delivered an ADH 01 but they had the wrong inventory size and on arrival the frame was actually an XS instead of an XXS. Consignment of an XXS is a 3 month wait, at which point the new models will surely be anounced and at that point I'd rather wait for the new version.
However, in the meantime I've already bough BB and 30mm cranks which I'd only use in a 386EVO, so not sure if I should return them while I still can or keep them for the upcoming model which is what I will buy most probably.
Why would they change? It's the most versatile BB standard, and pf > Threaded in just about every way assuming your tolerances aren't total dog shit. So I can't see them moving to another pf standard or threaded. I think you can assume it'll stay the same.Pato wrote: ↑Tue Oct 25, 2022 2:56 pmAnybody with some info on the 2023 models (@Solo77) knows if Time will stick with BB386 EVO?
I actually asked their customer service via email the exact same question last week, and was told that they would continue to use BB386 EVO
Comanies take a lot of decisions that don't make much sense, like fully integrated cable rounting
Awesome!!steveadore wrote: ↑Tue Oct 25, 2022 6:59 pmI actually asked their customer service via email the exact same question last week, and was told that they would continue to use BB386 EVO
Could anyone tell me if the ADHX also used the patented Time Quickset headset or not? I'm having a hard time visualizing how that system could work together with the Deda Superbox stem's spacers and the Deda DCR internal cable routing (as far as I know, that requires its own special headset)
The ADHX uses the Deda DCR headset in order to permit the cables to be routed through the headtube. https://dedaelementi.com//headset-dcr
Thanks, just found this video that shows the steerer does indeed lack the threaded sleeve for the Quicksetvelomane wrote: ↑Fri Oct 28, 2022 12:07 amThe ADHX uses the Deda DCR headset in order to permit the cables to be routed through the headtube. https://dedaelementi.com//headset-dcr
I'm not a big fan of cable routing through the headtube (though the DCR system is probably the best method for this), and I wonder if it was worth sacrificing the benefits of the Quickset for this (allegedly, the new ADH and Scylon models will also feature integration)
Well, I'm considering a frameset that comes with the Deda stem and headset included I didn't realize they were so much more expensive if purchased separately
If you want to use something else, I'm sure it can be supplied without. Time make the frame, not Deda stuff ... so if it's not optional, it ought to be.steveadore wrote: ↑Fri Oct 28, 2022 2:10 pmWell, I'm considering a frameset that comes with the Deda stem and headset included I didn't realize they were so much more expensive if purchased separately
No, it's a used set sold togetherRDY wrote: ↑Fri Oct 28, 2022 2:14 pmIf you want to use something else, I'm sure it can be supplied without. Time make the frame, not Deda stuff ... so if it's not optional, it ought to be.steveadore wrote: ↑Fri Oct 28, 2022 2:10 pmWell, I'm considering a frameset that comes with the Deda stem and headset included I didn't realize they were so much more expensive if purchased separately
