Aftermarket aero/low stack stem options - vanity question
DJT21
by DJT21
I feel the traditional stem formfactor (cylindrical/tubular) looks out of place when paired with a modern carbon frame, so I'm wondering which manufacturers produce something that looks "correct"?
So far I've seen:
FSA SLK drop stem - almost perfect, but the drop is slightly too much, and it's 120mm max length isn't long enough.
Basso semi-integrated stem - not sure if this is compatible with a standard round top cap?
Deda Vinci stem - same query as above re top cap.
Syntace Flatforce stem - max length available is 110mm.
What else is out there?
fizzaz
by fizzaz
The Deda Superzero has a flat top section and they at least mention aero in its description. I have a hard time imagining the stem body has that much effect unless all the bolts are hidden.
Hexsense
by Hexsense
FSA Afterburner stem has low stack and is 12 degree angle. But it is still maxed at 120mm.
https://shop.fullspeedahead.com/en/stem ... er-stemFSA
Specialized Tarmac stem. Require rear cap that come with Tarmac SL7 Headset spacers kit which you can easily order through any dealers.
Kurt1980
by Kurt1980
Bumping this up. I'm also looking for a flat aeroish stem that suits the design language of modernish bikes, in this case a Scott Foil 1st gen. I put a Ritchey Chicane on as I thought the low profile face would suit, which it does, but it gets a bit too narrow for my liking.
Are there any non proprietary stems that look like the Syncros or BMC models below? Width and a squareish shape is probably most important, and then if possible a low profile face clamp The closer to 46mm wide (clamp width of the bar) the better, ideally a hook plate to keep it low profile at the front.
images (92).jpeg (56.18 KiB) Viewed 1178 times
The Newmen stems are the closest I can find. They're 40mm wide which is not bad. The bolts are kind of annoying, but I can live with them. This is a 120mm apparently.
TIA
Edited a bunch of times for clarity!
wheelsONfire
by wheelsONfire
Enve SES Aero 130mm
with the -12 insert attached
With 130mm, you get 127.5 or 132.5. Basically as long as you use the -12 shim, you have 5mm difference between the settings.
The stack height is 42mm.
Using -7 or -17 shim gives you a stack height of 46mm due to the shims design.
Both will be 130mm.
You can torque the stem using a normal spacer on top of the stem, but if you do, just torque the stem in place and fix it to the steerer.
Then loosen the headsettop cap screw to minimal torque (just enough for the headset top cap and spacers to remain attached)
The standard spacers (round) doesn't really apply pressure optimal, but once the stem is fixed at the steerer tube, mission is achieved.
Or you do as Enve say, cut your steerer as described. I just try to tell you it works even if you don't.
Bikes:
Open *UP* (2016.04.14)
Nickldn
by Nickldn
Left field option: Flux SLR Stem
This is a Giant product, but without the branding. It fits 1 1/4 inch steerers and 1 1/8 with a shim. 8 degrees of drop.
Very stiff stem and made in sizes up to 130mm, maybe longer. Not sure if they are still made, but can be bought on ebay at a decent price.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
Kurt1980
by Kurt1980
Thanks both for the replies, I'll have a look at the Flux stem in particular. That's more in line with what I was imagining. Any other suggestions also welcome!
frostorama
by frostorama
Prime Doyenne stem looks ok, available upto 140mm. Not very lighweight but has the modern looks:
https://www.wiggle.com/p/prime-doyenne-alloy-stem
Kurt1980
by Kurt1980
frostorama wrote:
Mon May 29, 2023 6:19 pm
That's actually a pretty nice option, if a little heavy. Price is right too.
Cheers
Kurt1980
by Kurt1980
Found this possibility on a fairly recent Argon 18 Krypton. Not sure if this will fit regular bikes, but I like the low profile front end. Weight is an unknown at this stage...Anyone have any experience with this stem?
SilverSteve
by SilverSteve
Shimano PRO Vibe stem?
