R9250 compatiblity, crankset weight changes FC-R9100 vs FC-R9200
ooo
by ooo
Another full spec 12s di2 specs with cassette sprockets listing.
Totally re-engineered with the all-rounder in mind, the Specialissima helps you fly up the climbs and dominate the flat. The carbon disc frame is light, just 750g, so none of your climbing power is wasted when the road turns upward, but it is also superbly-stiff providing excellent transfer of that power to the road. The new Specialissima is designed for World Tour professionals but it is also your complete race bike.
2022 Bianchi Specialissima Dura Ace Di2 12sp Disc
COLOR
SB: Black Carbon UD/Mermaid Scale Full Glossy
SC: CK16/Mermaid Scale Full Glossy
SJ: Greenish Blue/Mermaid Scale Full Glossy *Tavolozza colours
FRAME
Specialissima CV Disc carbon, headset 1.5" - 1.5", Seatpost 27,2mm, mechanical/electronic, BB PressFit 86,5x41, Disc brake internal cable, flat mount, thru axle 12x142mm, sizes 47-50-53-55-57-59-61cm
BOLTS/HARDWARE: AL7075-T6 large button head bolts, Torx M5*14mm x 4pcs, colour celeste bianchi with Bianchi logo
SEATPOST CLAMP: Included in the frame
HEADSET: FSA NO.55R 1.5"/ACR/Bianchi Matt black , lower 1.5"- top 1 .5", 36°- 45° ACB bearing, w/Carbon custom cone spacer specific for Disc ACR stem/handlebar, for 52mm/52mm OD head tube, w/TH-881-1 compresor
FORK Full Carbon, 1.5">1.5" 1.5" integrated head, Disc Brake internal cable, flat mount, thru axle 12x100
SHIFTER
Durace Di2 hydraulic disc brake for road
Disc-brake assembled set/J-kit direct, DURA-ACE, ST-R9270(L), BR-R9270(F), for 160mm rotor, resin pad(w/fin), hose SM-BH90 1000mm black
Disc-brake assembled set/J-kit direct, DURA-ACE, ST-R9270(R), BR-R9270(R), w/o adapter for 20mm Mount Thickness, resin (w/fin), hose SM-BH90 1700mm black +
Mount adapter for rear road disc brake mount, SM-MA-R160D/D, fixing bolt X2, snap retainer X1, washer X2 +
Small parts for SM-BH90, olive & connector insert each 2pcs
REAR DERAILLEUR Shimano, Durace Di2 12sp, RD-R9250, top normal shadow design, direct attachment, max 34T
FRONT DERAILLEUR Shimano Durace Di2 FD-R9250, brazed-on type
ELECTRIC CABLE
1 - Electric wire, EW-SD300, for external routing, 500mm (FD)
2 - Electric wire, EW-SD300, for external routing, 1200mm (RD)
CHARGER/PWRCABLE Shimano EW-EC300, 1700mm
CRANKSET Shimano Durace 12sp, FC-R9200 50x34T, hollowtech II, Crank Length: 170mm-47/54cm, 172.5mm-55/59cm, 175mm-61cm
BOTTOM BRACKET Shimano SM-BB92-41B , press fit
CHAIN Shimano Dura Ace CN-M9100
CASSETTE/FREEWHEEL Shimano CS-R9200 DURA-ACE 12sp, 11-12-13-14-15-16-17-19-21-24-27-30T
BRAKE Shimano BR-R9270 Hydraulic disc brake, included in the shifter
BRAKE LEVER Included
DISC ROTOR Shimano RT-MT900 center lock, diam.160mm
RIM/WHEELSET Vision SC40
TIRE Pirelli P ZERO Race , 26-622, 127TPI
STEM Reparto Corse Fsa NS ACR ST-OS-160, 3D Forged/CNC AL6061, clamp. 31.8mm, rise 6° , Di2 compatible, Ext: 90mm-47/50cm, 100mm-53cm, 110mm-55/57cm, 120mm-59cm, 130mm-61cm
HANDLEBAR Reparto Corse Fsa Compact HB-RK-222S/CCH/Di2, UD Weave Carbon material, diam.31.8mm, drop 125mm, reach 80mm, 4° Outward Bend, Size: 400mm-47/50cm,420mm-53/57cm, 440mm-59/61cm
GRIP/TAPE Black soft Microfiber taper w/Shockproof EVA-139
SEATPOST Reparto Corse by FSA K-Force Light SB25, UD Carbon Monocoque, clamp type 2-Bolt Head "MTC", Setback 25 mm, Length 350mm, 27.2mm diam., Di2 Battery compatible
SADDLE Fi'zi:k Antares R1, cover MicroTex thermowelded, Composite carbon co-injected Nylon WingFlex , rail carbon braided 7x9cover, Integrated Clip System, 275x142mm
2022 Bianchi Specialissima Ultegra Di2 12sp Disc
COLOR
FRAME
Specialissima CV Disc carbon, headset 1.5" - 1.5", Seatpost 27,2mm, mechanical/electronic, BB-PressFit 86,5x41, Disc brake internal cable, flat mount, thru axle 12 x 142mm, sizes 47-50-53-55-57-59-61cm
BOLTS/HARDWARE AL7075-T6 large button head bolts, Torx M5*14mm x 4pcs, colour celeste bianchi with Bianchi logo
SEATPOST CLAMP Included in the frame
HEADSET FSA NO.55R 1.5"/ACR/Bianchi Matt black , lower 1.5"- top 1 .5", 36°- 45° ACB bearing, w/Carbon custom cone spacer specific for Disc ACR stem/handlebar, for 52mm/52mm OD headtube, w/TH-881-1
SHIFTER
Ultegra Di2 hydraulic disc brake for road Disc-brake assembled set/J-kit direct,
Ultegra, ST-R8170(L), BR-R8170(F), for 160mm rotor, resin pad(w/fin), hose SM-BH90 1000mm black Disc-brake assembled set/J-kit direct,
Ultegra, ST-R8170(R), BR-R8170(R), w/o adapter for 20mm Mount Thickness, resin (w/fin), hose SM-BH90 1700mm black +
REAR DERAILLEUR Shimano Ultegra Di2 12sp RD-R8150, Ultegra Di2 12-speed, top normal shadow design, direct attachment, max 34T
FRONT DERAILLEUR Shimano Ultegra Di2 12sp FD-R8150, Ultegra Di2, brazed-on type
ELECTRIC CABLE
CRANKSET Shimano Ultegra FC-R8100, hollowtech II, Crank Length: 170mm-47/54cm, 172.5mm-55/59cm, 175mm-61cm
BOTTOM BRACKET Shimano SM-BB72-41B, press fit
CHAIN Shimano Ultegra CN-M8100, 12sp
CASSETTE/FREEWHEEL Shimano Ultegra CS-R8100, 11-12-13-14-15-16-17-19-21-24-27-30T
BRAKE Shimano BR-R8170 Hydraulic disc brake, included in the shifter
DISC ROTOR Shimano RT-MT800 center lock type, 160mm front rear, with lock ring
RIM/WHEELSET Fulcrum Racing 400 disc brake, R400 aluminium asymetric 622x19c, tubeless ready, front hub 12mm x 100mm - rear hub 12 mm x 142mm, thru axle, center lock AFS
STEM Reparto Corse Fsa NS ACR ST-OS-160, 3D Forged/CNC AL6061, clamp. 31.8mm, rise -6° , Di2 compatible, Ext: 90mm-47/50cm, 100mm-53cm, 110mm-55/57cm, 120mm-59cm,130mm-61cm
HANDLEBAR Reparto Corse fsa Compact HB-RK-222S/CCH/Di2, UD Weave Carbon material, diam.31.8mm, drop 125mm, reach 80mm, 4° Outward Bend, Size: 400mm-47/50cm, 420mm-53/57cm, 440mm-59/61cm
jever98
by jever98
Sorry if I am asking something obvious, but there are so many pages in the DA thread - did I get it right that Shimano 12spd road will have 11T as the smallest cog?
That would make me very happy!
No longer in the industry
BigBoyND
by BigBoyND
Yes, and the new cassettes will be compatible with existing HG wheels.
ooo
by ooo
new pro vibe evo dropbar have cut outs for new satellite shifters,
english distributors list this feature as integration of new shifter
some non-enlish distributors list exact satellite shifter model SW-RS801
ooo
by ooo
more fcc pdf pics (first pics posted by Ritix in next di2 topic):
Image Image
Image Image Image Image
Ritxis
by Ritxis
ooo wrote:
Tue Jun 29, 2021 1:03 pm
COLOR
FRAME
SHIFTER
ELECTRIC CABLE
COLOR
FRAME
SHIFTER
ELECTRIC CABLE
Shimano updated its technical documentation to July 30 (the previous one was in April)..........................I have not seen any news regarding the next to arrive.............It would not be more logical to wait for the new 12s for the road?
ooo
by ooo
This was mostly non road update:
- new saint/xt pedals
- new e-bike 10-11s mtb linkglide cassettes that require road 11s freehub
with new t-shirt sizing S/M/L vocabulary for freehub width in mtb section:
(road section not updated with this vocabulary yet)
There was around 10 partners who got 12s shimano contracts around april 2021
merida, bianchi, bmc, specialized and others started speccing 2022 bikes with 12s
and now distributors leaking information that is dated april 2021 that can be changed before launch
(final spec may have different chain or rotor model, that was not finalized in april)
bianchi 12s - serviziocorsa.com/Flyer_ROAD_2022.pdf (backup link)
merida 12s - merida-bikes.com/en-au/bike/3157/time-warp-tri-10k (backup link)
bmc 12s - bmc-switzerland.com/intl_en/roadmachine01-one.html (backup link)
pinarello 12s - dunbarcycles.com/2022-pinarello-dogma-f-disc.html (backup link)
cervelo 12s - jonito.de/Cervelo-P5-Dura-Ace-Di2-2022_1 (backup link)
cinelli 12s - cinelli.it/en/prodotti/pressure-en/
ooo
by ooo
BR-R9270 will be the first flatmount MONO-BODY (single piece) caliper from Shimano,
previous Dura-Ace and flatmount XTR BR-M9110 (unlike postmount XTR) disc calipers used 2-piece design
(2016 Dura-Ace disc caliper was announced with 1-piece design on pics, actual product had 2-piece design)
BR-R9270 and BR-R8170 will be first flatmount calipers with separate hex+syringe bleeding ports, like postmount BR-RS785 caliper
previous flatmount road disc calipers and postmount BR-R785 caliper (unlike BR-RS785) used design with single bleeding nipple port
(2014 BR-RS785 disc caliper was announced with bleeding nipple on pics like BR-R785, actual product had separate hex+syringe ports)
RDY
by RDY
I was under the impression that single piece calipers were fundamentally inferior. I.E. they could never match the stiffness and lightness of a bolted together 2 piece. Hence why they changed in the first place, and SRAM also did - Red AXS was revised to 2 piece when Force AXS launched, and both Force & Rival are 2 piece too. Fairly sure all Magura & Trickstuff designs are 2 piece too?
Single piece probably cheaper though ...
Highly dubious about any supposed caliper improvements already, since this almost ensures they'll be heavier - unless they're willing to sacrifice even more stiffness ... Likely making piston retraction even worse ... which they were supposed to be improving with bigger pistons ...
ooo
by ooo
New Ultegra caliper is 2-piece vs 1-piece Dura-Ace - they are not interchangeable (unlike current gen dura-ace and ultegra calipers)
I don't have info on servo-wave support, but it looks like Ultegra have more chances to support this feature vs Dura-Ace.
How it is sorted for MTB:
98g XTR BR-M9100 1-piece non servo-wave caliper (not extreme breaking + lighter caliper + lighter brake lever without servo mechanism)
136g XT BR-M8100 2-piece servo-wave friendly caliper (extreme breaking + heavier caliper + heavier servo-wave design for brake levers)
RDY
by RDY
If their one piece is lighter it likely means stiffness is out the window ...
Also, if Dura Ace and Ultegra calipers require matched brifters, that is so unnecessary and, frankly, facepalm. Seems like there is only going to be limited compatibility between DA and UT (& presumably updated GRX and 105), due to cassette divergence and, if you're right, brake divergence. Given supply shortages, no mix and match means it's going to be even more difficult to either keep your bike running or to do mix and match builds (my gravel build is a mix of GRX6, GRX8, DA, UT, originally 105 cranks (now replaced with Red AXS & Quarq Dfour). Why? Because it was impossible to get a suitable groupset or piece one together when I was building.
Ritxis
by Ritxis
ooo wrote:
Sun Aug 08, 2021 12:01 am
Why can't new Ultegra shifters be used with new Dura-ace calipers? or vice versa? from what I read in the thread (I think it was @Alfus) the new shifters will not be able or will not work well with the current calipers
ooo
by ooo
For complete bike builder shifters and calipers are shipped together
(bleeded with custom hydro line length and inline connectors)
There is no Official compatiblity, some combos may work unofficially for DIY market
for example, MichaelB reported, that he used 4-piston DH caliper with road STI:
MichaelB wrote:
Mon Jul 29, 2019 3:54 am
Also have a Cannondale Slate with MT520 calipers & R7020 levers.
henau212
by henau212
COLOR
FRAME
SHIFTER
ELECTRIC CABLE
COLOR
FRAME
SHIFTER
ELECTRIC CABLE
Any idea if a junction box is needed between derailleurs and battery? Saw that on a Patent earlier.
