Cervelo R5 2022 spotted
Conradsleight
by Conradsleight
https://twitter.com/hendriksmj/status/1 ... 5656919040
Seems like Dumoulin's already testing the new R5... looks like integrated cabling (finally), but nice to see they've kept the classic look with the seat stays. Would be nice if they went with a threaded BB, but that seems unlikely given it's Cervelo.
666pounder
by 666pounder
It also looks like they're coming back to slimmer downtube.. somewhere beetwen current model and older ones... which I think is good
moock
by moock
it is the FSA internal system. I hope you can still choose between this and standart stem...
NYCPrynne
by NYCPrynne
While I am hopeful about a new R5d, this looks suspiciously like the old.....
What else appears new besides the lack of cables which could be attributed to the FSA internal system?
Karvalo
by Karvalo
moock wrote:
Sun Jan 03, 2021 12:12 am
You think? All their other hidden cable bikes use in house systems. Not sure why they'd suddenly go for off the shelf.
NYCPrynne wrote:
Sun Jan 03, 2021 12:22 am
The fork looks different, and the top of the seatstays.
moock
by moock
Karvalo wrote:
Sun Jan 03, 2021 12:27 am
it is the FSA system, because in the picture you can see it 😉
TobinHatesYou
by TobinHatesYou
Really not a fan of the straight 1-1/2" HT look, but that's what happens with ACR...
ichobi
by ichobi
Am also asking why? The acr is not a particularly light implementation and given Cervelo history of making their own stuff (sometimes innovative), is this a reflection of erosion of engineering post Vroomen and White sell-out?
hannawald
by hannawald
Great to see another FSA implementation. Hopefully that will force them to make a proper stem for it, not a 230g Al6061 solution.
moock
by moock
The new Argon18 Nitrogen released 1 or 2 month ago.
It has also the FSA ACR system, but if you look the pdf you can change the FSA Headset with a Token Headset. There you can use any kind of 1 1/8 stem and bar combo.
The cables go in the st quite similar to the trek-emonda-system. I can post a screenshot from the a18 pdf later if you want.
edit: what i wantet to say: maybe its also possible with the R5 so you can use your cool lightweight stuff :)
TiCass
by TiCass
hannawald wrote:
Sun Jan 03, 2021 10:49 am
They will likely put something like the Vision Metron 5D Arc Integrated
https://shop.visiontechusa.com/en/type/ ... integrated
hannawald
by hannawald
moock wrote:
Sun Jan 03, 2021 2:21 pm
That would be really really great! Thank you!
moock
by moock
if this is interchagable, the token is worth gold
hannawald
by hannawald
moock wrote:
Sun Jan 03, 2021 4:57 pm
here
Thanks! I have found the assembly manual on Argon18 website. Argon18 uses atypical solution because it has a hole in the fork steerer. Usually bikes using FSA ACR doesn't have that which means you can't use Token:( There is no way how to route front brake hose into its place on fork with Token if the bike has no hole in steerer.
moock
by moock
hannawald wrote:
Sun Jan 03, 2021 5:02 pm
here
but the a18 pdf also mention 3 solutions:
Token
acr with one calbe trough the forkrake
acr same as token
