SL7 or Aethos, already have SL6
Yes I was lured by the Aethos marketing, never again.
I have powermeters both on the SL7 and Aethos. The SL7 has been breaking my personal best on the climbs here.
Do you honestly believe that you've been winning races because you're on an SL7 and wouldn't have won them on an SL6?ome rodriguez wrote: ↑Wed Apr 21, 2021 2:49 amBut have you ridden the SL7? I came from SL6 and I can feel the difference. The SL7 is faster in all places. I've been winning local races with it the past few months.Roadrocket wrote: ↑Tue Apr 20, 2021 9:28 pmPlacebo or you just need to justify your purchase?ome rodriguez wrote: ↑Thu Dec 31, 2020 1:37 amI have both SL7 and Aethos, haven't ridden the latter yet. Also had an SL6 before. The SL7 is stiffer in all places and faster.
S-Works SL6: BB stiffness 76N/mm HT stiffness 105N/mm Fork stiffness 65N/mm
S-Works SL7: BB stiffness 58N/mm HT stiffness 97N/mm Fork stiffness 53N/mm
I have ridden S-Works SL6 and it was one of the stiffest bikes I ever rode (about a hair behind Cipollini RB1K, but much lighter).
With all due respect, even if the SL7 was stiffer (it´s not) and few watts faster, I doubt you would feel the difference.
Btw, just sold my Aethos because it was like an SL6
If so I've got a bridge to sell you.
mmm tasty tasty kool-aidome rodriguez wrote: ↑Wed Apr 21, 2021 6:29 amYes I was lured by the Aethos marketing, never again.
Current bikes: '24 S-Works Tarmac SL8, '24 Specialized Allez Sprint
Disgusting list of bikes owned
Really? Same as you. Probably got the Aethos of its weight, this is weightweenies anyway.gurk700 wrote: ↑Wed Apr 21, 2021 7:18 ammmm tasty tasty kool-aidome rodriguez wrote: ↑Wed Apr 21, 2021 6:29 amYes I was lured by the Aethos marketing, never again.
No I haven´t ridden SL7 yet, but I have ridden a lot of high end bikes so I can compare. Originally you wrote ´The SL7 is stiffer in all places´ which you can see is not true. Your feelings about SL7 being stiffer probably comes from the significantly stiffer seatpost. SL7 seatpost deflection 156N/mm, SL6 seatpost deflection 104N/mm, so SL7 is less comfortable, hence the ´stiffer´ feel.ome rodriguez wrote: ↑Wed Apr 21, 2021 2:49 amBut have you ridden the SL7? I came from SL6 and I can feel the difference. The SL7 is faster in all places. I've been winning local races with it the past few months.Roadrocket wrote: ↑Tue Apr 20, 2021 9:28 pmPlacebo or you just need to justify your purchase?ome rodriguez wrote: ↑Thu Dec 31, 2020 1:37 amI have both SL7 and Aethos, haven't ridden the latter yet. Also had an SL6 before. The SL7 is stiffer in all places and faster.
And how much faster is the SL7 than SL6? 10s over 100km route at the most (mainly due to aero handlebar) ?
Congrats on your victories, but if you really believe it was because you replaced SL6 for SL7, I have really nothing more to say.
You have great bike but it´s in no way ´stiffer and faster´ than SL6.
SL7.
SL8 R-Works - 6.19kg
IG: RhinosWorkshop
IG: RhinosWorkshop
viewtopic.php?p=1618024#p1618024Roadrocket wrote: ↑Wed Apr 21, 2021 10:27 amAnd how much faster is the SL7 than SL6? 10s over 100km route at the most (mainly due to aero handlebar) ?
If you go by the Tour testing, it's a lot more than 10s.
Also, road racing isn't time trialling. If you're anywhere near threshold, saving those 14W (that Tour claims to be the difference between the two, or 11W between rim SL6 and SL7) can be the difference between easily staying in the bunch with plenty in reserve and blowing.
No-one's saying that it'll turn you into Bennett or JA just by jumping on, but that doesn't mean it can't have an effect. To go back to TTs, I've lost a race by 1s before - do you honestly think that equipment differences couldn't have made up that 0.08% difference in speed?
wahtever makes your heart race imo. if you race get the tarmac, if you ride to stay healthy and for the joy of cycling, get the aethos. I am kind of in the same position. i am looking at the aethos, which i would build up with an aero bar and discard the 10-15 watts difference in a wind tunnel in certain conditions. however if you want the sl7, get it with 28mm or 30mm tires which will get you more comfort than any seatpost etc...
but as you said, you are working on yur bike yourself. the aethos is for sure less hassle to work on, play around with different stems, bars etc.
2018 Specialized Tarmac Expert
- wheelsONfire
Ridiculous all of this. If you want speed get Venge or keep SL6. SL7 is less stiff in every area except the seat mast tube. This is where you want it to be comfortable!
Bikes:
Open *UP* (2016.04.14)
I'm not gonna argue anymore. I know you still have your SL6. I hope you can ride or own an SL7 in the future. I've owned a Pinarello Dogma F10, Colnago C64, Lightweight Urgestalt, SL6, and etc. The SL7 is the fastest bike I've ridden even on climbs.Roadrocket wrote: ↑Wed Apr 21, 2021 10:27 amNo I haven´t ridden SL7 yet, but I have ridden a lot of high end bikes so I can compare. Originally you wrote ´The SL7 is stiffer in all places´ which you can see is not true. Your feelings about SL7 being stiffer probably comes from the significantly stiffer seatpost. SL7 seatpost deflection 156N/mm, SL6 seatpost deflection 104N/mm, so SL7 is less comfortable, hence the ´stiffer´ feel.ome rodriguez wrote: ↑Wed Apr 21, 2021 2:49 amBut have you ridden the SL7? I came from SL6 and I can feel the difference. The SL7 is faster in all places. I've been winning local races with it the past few months.Roadrocket wrote: ↑Tue Apr 20, 2021 9:28 pmome rodriguez wrote: ↑Thu Dec 31, 2020 1:37 amI have both SL7 and Aethos, haven't ridden the latter yet. Also had an SL6 before. The SL7 is stiffer in all places and faster.
I love the SL7 so much that I'm planning to buy another one. Just waiting the Quickstep to be available which is the original color I ordered. Still happy I got this Chameleon could have waited very long time to own one
Yes, the time trialing is all about aero (besides 100% right body position) so I would do whatever change to my TT bike that will save me even 0.5W.mgrl wrote: ↑Wed Apr 21, 2021 10:59 amviewtopic.php?p=1618024#p1618024Roadrocket wrote: ↑Wed Apr 21, 2021 10:27 amAnd how much faster is the SL7 than SL6? 10s over 100km route at the most (mainly due to aero handlebar) ?
But 210W (SL7) vs 221W (SL6) is pretty much the same considering road racing nature. If you´d have closer look at those numbers you will see the SL7 had advantage of aero handlebar and deep section wheels.
The aero handlebar alone is worth 4-5W, how much are the wheels? Put the same wheels and handlebar on SL6 and then compare.
Apples to apples.
I know you love your SL7 and I understand it, as I said it´s great bike for sure. When first released I would consider buying it if it was availible in rim brake, because I love my Mavic CXR, Bora Ultra and Roval rim wheelsets.ome rodriguez wrote: ↑Wed Apr 21, 2021 11:21 amI'm not gonna argue anymore. I know you still have your SL6. I hope you can ride or own an SL7 in the future. I've owned a Pinarello Dogma F10, Colnago C64, Lightweight Urgestalt, SL6, and etc. The SL7 is the fastest bike I've ridden even on climbs.Roadrocket wrote: ↑Wed Apr 21, 2021 10:27 amNo I haven´t ridden SL7 yet, but I have ridden a lot of high end bikes so I can compare. Originally you wrote ´The SL7 is stiffer in all places´ which you can see is not true. Your feelings about SL7 being stiffer probably comes from the significantly stiffer seatpost. SL7 seatpost deflection 156N/mm, SL6 seatpost deflection 104N/mm, so SL7 is less comfortable, hence the ´stiffer´ feel.ome rodriguez wrote: ↑Wed Apr 21, 2021 2:49 amBut have you ridden the SL7? I came from SL6 and I can feel the difference. The SL7 is faster in all places. I've been winning local races with it the past few months.Roadrocket wrote: ↑Tue Apr 20, 2021 9:28 pm
But after all, buying SL7 instead of SL6 doesn´t make much sense. SL6 is stiffer and probably only 2-3 watts behind SL7 (with aero handlebar and deep wheels).
I cannot say it is any slower than my Venge, but much better in hills and stiffer in sprints.
Enjoy your SL7.
Personally I'd go SL7, I can't see much point in not having a frame that isn't aero optimised when you aren't really compromising for it. People will talk about frame compliance, which is valid but pretty irreleveant compared to the comfort that a set of 28 tyres would give you.
The stock wheels on the S-Works SL6 were Roval CLX50s so the difference between the wheels is going to be pretty minor, doubly so because Rapides are disc only. I suspect a disc SL6 with rapides will be about the same drag as the rim with CLX50s at best.Roadrocket wrote: ↑Wed Apr 21, 2021 11:54 amBut 210W (SL7) vs 221W (SL6) is pretty much the same considering road racing nature. If you´d have closer look at those numbers you will see the SL7 had advantage of aero handlebar and deep section wheels.
Apples to apples.
