Sub 6.8 kg Cannondale six13 project; NOW 5.999kg project.
New project name: Cannondal six13 5.999kg
I have just made a test setup(with heavy tires) with my new Zipp 303 rearwheel and my calculations point to 6.060 kg so the new goal is within reach when my pedals -30g, my seatpost -25g and my 10 titanium bolts arrive. But that'll probably be the end. All the low hanging fruits(cheaper parts) have been picked.
I even got the wheels for 40$ and 70$, bought as defective but now repaired.
The new wheel is for 11 speed(although I still had to modify it) but can now also take my 11S cassette with the 11T removed(-9g) making it 10Speed
The next steps would be a ring -30g for 110$, a seatpost -55g for 600$ aso.
Cannondale Super Six HiMod 2017 6.7 kg
Cannondale six13, 2004, 5.50kg
Focus Izalco Max, 2023 4.418 kg
I just received the Elita One seatpost 125g but cut to 25 cm it's 107g, combined with a new calibrated scale I'm down to 5.998kg and I still can save arond 24g on a zipp 303 I have and maybe 10g with the titanium screws underway.
Not much in WW terms but I'm satisfied with it, especially as this is a budget build at around 1100$ when the surplus has been sold off.
- obiwanshinobi
Congrats!poulhansen wrote: ↑Fri Dec 18, 2020 10:57 pmI just received my new frame from Italy, after 18 days of nervousness, before the Italian post, sent it out of the country
Now starts the fight of collecting parts. I have chosen sub 6.8 kg because I want to be qualified to wear the "Normalize My Cannondale" jersey, if I can find one.
PS: Does anyone have the weight of this bottom bracket? I don't want to take it out, just for weighing.
I did read, unless I missed it..... what size frame please?
55cm c-c
Titanium bolts and an Extralite ring at 68 g(-31g) so now 5.959kg
And I still have the Zipp 303 rearwheel which is 24 g lighter but I prefer the look of the present one
Great work. I had a Six 13 but it was too big and I had to sell it.
Does the carbon weave on the top tube wave around or is that effect cosmetic?
Scott Foil RC10 Ultegra 12 speed / Creston 50 - 7.9Kg
The weave isn't totally straight just at that point but it's only noticeable in a flash photo
I remember mine was the same there - at least it makes them look more 'hand made'!poulhansen wrote: ↑Mon Sep 20, 2021 8:28 amThe weave isn't totally straight just at that point but it's only noticeable in a flash photo
I'm not sure though, does the section of the top tube change slightly there, which causes the carbon layup to not be perfectly straight?
No. I think it's just a sign of unripe early carbonproducion methods.
There is a slight bit of corrosion under my paint but I have poured some aluminium anticorrosion fluid where there was a tiny crack and I keep it in my livingroom anyway, so I don't think it will be a problem.
I ike the look of it, the low weight was just a thing to be able to ride that jersey, but I got caught in it but I'm finished now, unless I get a really good bargain on more lightweight stuff, the next components are way too expensive new.
I have 7 bikes, so I don't use it much but I'm looking for a hillclimb somewhere where it will be the first choice.
I think this is it. 5.86kg after a new saddle and a set of July21 brakes. From now on it get's too expensive and going lower, I really should have started with a lighter frame.
In the mean time I got myself a Bianchi Mercatone Uno, Pantani that weighs close to the double but it's so beautiful.
Hmmm. I installed a set of Tune Skyline wheels 881 g and a SRAM XG-1190 cassette 148g, with the 11T removed and saved almost 400 g BUT I have been thinking it weighed 5.59 kg but I remembered wrong!. It weighed 5.95kg, so now I'm only down to 5.50 kg and not the expected 5.1 kg but I'm NOT removing the paint!
