Negative, that is for a rotary post from 2020 and older models
*edit* yes it can - I was still envisioning the Domane posts.
Ok, does it exist a 7x9 clamp that fits new Emonda?MitchatTrek wrote: ↑Thu Dec 17, 2020 6:38 pmNegative, that is for a rotary post from 2020 and older models.
Doesn't the latest Émonda use the same seat mast cap as previous generations? It certainly looks that way.MitchatTrek wrote: ↑Thu Dec 17, 2020 6:38 pmNegative, that is for a rotary post from 2020 and older models.
Yep!
Just to clarify, will the lightweight rotary head rail clamps work on a 2019 Domane if you get new faceplates? Do you have part number(s) for these? Do you know if they can still be ordered?MitchatTrek wrote: ↑Tue Dec 15, 2020 6:22 pm
The lightweight rotary head rail clamps come with new faceplates, but those are designed to sit and compress into the rotary post and shouldn't sit by themselves in the new Domane post. Here is the lightweight one Gabe was mentioning:
I know we emailed, but for anyone else's reference, details below!RowdyBurns wrote: ↑Wed Feb 17, 2021 5:38 amJust to clarify, will the lightweight rotary head rail clamps work on a 2019 Domane if you get new faceplates? Do you have part number(s) for these? Do you know if they can still be ordered?MitchatTrek wrote: ↑Tue Dec 15, 2020 6:22 pm
Thanks,
Ryan
I wouldn't lubricate them, this isn't something we call for nor is it something I have ever seen done for our mast caps. Best to pop them out and rotate.Paperboy wrote: ↑Sun Feb 21, 2021 5:40 pmQuestion: I bought the 7x10 lightweight seat mast for my new 2021 Emonda, to go with the Aeolus Pro saddle. I noticed that the rotary ears on the seat mast are not lubricated. Because of this, the seat does not readily rotate. In fact, it resists rotation unless popped out of it's socket. Is this an oversight? Should I lubricate them? The rotary ears on my Specialized Allez Sprint came lubricated and readily rotate when loosened.
ThanksMitchatTrek wrote: ↑Tue Feb 23, 2021 6:28 pmI wouldn't lubricate them, this isn't something we call for nor is it something I have ever seen done for our mast caps. Best to pop them out and rotate.Paperboy wrote: ↑Sun Feb 21, 2021 5:40 pmQuestion: I bought the 7x10 lightweight seat mast for my new 2021 Emonda, to go with the Aeolus Pro saddle. I noticed that the rotary ears on the seat mast are not lubricated. Because of this, the seat does not readily rotate. In fact, it resists rotation unless popped out of it's socket. Is this an oversight? Should I lubricate them? The rotary ears on my Specialized Allez Sprint came lubricated and readily rotate when loosened.
+1TobinHatesYou wrote: ↑Tue Dec 15, 2020 9:42 pmI have not had problems just using the 7x9 railed saddles in 7x10 clamps, but YMMV.
