stannymenza
by stannymenza on Mon Jan 18, 2021 6:04 pm
billendk wrote: ↑Mon Jan 18, 2021 5:39 pm
Picture, picture picture
Not a lot of light left but here you go. The mount is angled down slightly so it sits more or less parallel to the ground.
Ragamuffin wrote: ↑Mon Jan 18, 2021 3:06 pm
Just wondering if anyone has seen any info or is able to measure the stack height, thanks in advance!
45mm, sorry again for the low light!
Ragamuffin
bearsdidit
- Shop Owner
by bearsdidit on Mon Jan 18, 2021 8:55 pm
pmprego wrote: ↑Tue Jan 05, 2021 1:18 pm
iamraymond wrote: ↑Mon Jan 04, 2021 4:01 pm
As far as I know, they don't make a 38cm bar. 40cm is the narrowest.
Which is hard to understand. For a company that claims that bike are unisex and just the contact points might need adjustment between genders I'd assume 40cm is way, way wider than most women would prefer. I could also use the aero argument. For a company to whom aero is supposed to be so important just makes "wide" bars. But it's okay, one can always source these components from different manufcturers.
Their decision to not make a 38CM bar is probably supported by their internal sales data. Specialized is a great marketing company but business is business.
pmprego
by pmprego on Mon Jan 18, 2021 9:31 pm
bearsdidit wrote: ↑Mon Jan 18, 2021 8:55 pm
Amen
Mr.Gib
by Mr.Gib on Sun Jan 24, 2021 5:53 pm
This from Specialized:
The minimum seatpost insertion from the top of the seatpost collar is 75mm. The maximum insertion is 215mm. If the proper saddle height can't be achieved with the stock seatpost within the acceptable range, a shorter or longer seatpost should be used.
However IMO the minimum is a bit frame dependant. 75mm might work on some frames but on others, depending on the seat-tube/top-tube/chainstay junction, it may be insufficient. I like at least 100mm regardless of frame.
Mr.Gib
by Mr.Gib on Wed Jan 27, 2021 9:50 pm
Yup, I'm not so sure the 75mm is a good number even for Specialized frames. You just want more post in the frame than 75mm.
SamD
by SamD on Mon Feb 08, 2021 12:05 pm
stannymenza wrote: ↑Mon Jan 18, 2021 6:04 pm
stannymenza, can you comment on how this mount is holding up? I have the same HideMyBell variant that is currently on my stem, but just ordered the alpinist cockpit. I was hoping to transfer the HideMyBell onto the cockpit as the interface seems the same, but my LBS guy said he did that too and his mount/GPS fell off after a few meters...
He thought it might be related to the curvature of the bar that doesn't match with the curvature of the stem.
stannymenza
by stannymenza on Mon Feb 08, 2021 3:36 pm
SamD wrote: ↑Mon Feb 08, 2021 12:05 pm
Well I've only ridden the bike outside for about 30km so far, I have my gravel bike on winter duty and the new bike on my smart trainer. But I'm not exactly sure what you mean or if you have the same mount? Mine matches the curvature pretty well and is attached by a bolt into the handlebar threads, so I don't see where it can go wrong. The only thing I would change is that I would like the mount to be angled up a little bit for legibility, other than that no complaints.
SamD
by SamD on Mon Feb 08, 2021 4:29 pm
stannymenza wrote: ↑Mon Feb 08, 2021 3:36 pm
I do have the same one indeed. Seems to match nicely on yours... I mailed hidemybell, interested to hear what they say. But I will definitely try it myself out too, hoping for the best as I really like the hidemybell. Thanks!
By the way, a few weeks ago I also asked them for a black mount instead of the orange thing, which I don't like... You can mail them too if interested. They will sell them via their webshop later on.
