Roval Alpinist Seatpost and Handlebar.
left lever inside the bar to the right bar junction. right lever in the bar in the end to the bar junction. right or left lever to fram outside the bar. If not using a y-cable between left lever and bar junction and connecting to a cable in the third end out thru the hole and into the frame.
/jonas l
http://instagram.com/jonaslundb
Ok that's where I was confused. I don't think that's possible. There aren't any holes by the shifters, at least in any pictures I've seen. So you can't go from shifter to internal.cerro wrote: ↑Wed Dec 16, 2020 9:02 pmleft lever inside the bar to the right bar junction. right lever in the bar in the end to the bar junction. right or left lever to fram outside the bar. If not using a y-cable between left lever and bar junction and connecting to a cable in the third end out thru the hole and into the frame.
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
Lancelegstrong: Wire outside down to the bar end and then inside to the other side. Agree that there isn't any holes at the shifters.
/jonas l
Specialized Concept Store in Stockholm, Sweden got
/jonas l
First ride on the alpinist cockpit and very stiff, very little flex (if any). I previously had MCFK (and Darimo on a previous bike) and would say the Roval's are stiffer..
PSA - the bolt that the Tarmac uses for the light/accessories mount isn't long enough..
Forget about the stock mount, it’s heavy! Go to shapeways and grab a 3D-printed one for half the price and half the weight.
I bought this one, fits perfectly
https://www.shapeways.com/product/EQPXE ... arketplace
No good for the Alpinist cockpit I'm afraid.marsrides wrote: ↑Sat Dec 26, 2020 12:18 amI bought this one, fits perfectly
