EE brakes
physeter
by physeter
Still on first gen eebrakes; still performng flawlessly
Kumppa
by Kumppa
Changed Red brakes with EE and wouldn't switch back. EEs are alot easier to adjust and at least as powerful than Red.
mkentik
by mkentik
They perform better in every way, changed from DA, as said excellent power and very good modulation, colour variation, plus the weight saving that said it all. Rest my case
PS. I am 88 kg and with the Reynolds pads are absolute anchorsImageImageImageImage
1)Cicli Barco XCR
2)Pinarello Dogma F8 Disc
3)Colnago Oval Master Titanium
[Cicli Barco XCR]
[Cervelo S-Series]
Ritchey Break Away
Wilier Triestina Ramata
[Gios Compact Evolution]
[Colnago Master Oval Titanium]
Eddy Merckx Corsa Extra
Piton Twin
Miyata Century
Vitus 992
Daccordi 50th
corky
by corky
physeter wrote:
Mon Oct 12, 2020 7:55 am
Me too 👍
kode54
by kode54
Great looking bike and paint.
mkentik wrote:
Mon Oct 12, 2020 9:31 am
1)Cicli Barco XCR
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
GrumpyOldPizza
by GrumpyOldPizza
Worth every dollar. Went from DA9100 to eeBrakes G4. I do like the way better modulation and predictability. Yes, less panic stopping (perhaps), but a lot more control.
Any they are light.
And they are pieces of art.
Did I mention that they are light ?
Ypuh
by Ypuh
I've been eyeing them for over a year now, but haven't pulled the trigger (bought so many other stuff to compensate my decision, that I'd probably been better off just going with the eeBrakes).
Did you know they have these cool limited editions once every 6 months? Due to corona they only have one version this year, the El Fuego. Note: These limiteds pretty hard/impossible to come by, simply because they're only sold on preorder during a 2 week time window.
El Dorado
El Chulo
El Rosado
El Diablo
El Platino
El Real
El Fuego
If they decide to launch a red/black version I don't care what my bank account says.
Cervelo S3 - 7.3kg
Time ADHX - 8.7kg
eric01
by eric01
Dura ace stronger but ee is more than enough for me. Never once felt EEs were lacking. To me it’s the definition of a weight weenie part: light, functional and expensive!
C36
by C36
To be honest I realised I missed one part in the nice picture... they are more sensitive to setup than Dura ace for example (and explain why time to tune you have people complaining about lower braking power than DA) and that involve the housing length too (the housing anchoring point does move when you pull the brakes).
Another point to consider is the relatively weak std spring if you have continuous housing on your frame (or some integrated bars that male some “less than ideal” sharp corners). Then a stronger spring that exist.
2018: Cannondale SSevo2HM : 5860g
2000: R4000 caad5: junior bike restauration
1995: Indurain‘s Pinarello: restauration project
wheelsONfire
by wheelsONfire
C36 wrote:
Tue Oct 13, 2020 8:13 am
We compare EE to DA. How about if those complaining would include THM and Lekki8?
Then you can conclude the EE blows these out of the water for braking (power) and modulation.
While we're at it you may also include Campa, Sram Red and FSA.
Ax Lightness even went so far to recommend EE and that says something!!
Bikes:
Open *UP* (2016.04.14)
DHG01
by DHG01
1)Cicli Barco XCR
Very, very nice bike. Can I ask what saddle that is?
DHG01
by DHG01
I am not particularly impressed with ee; that would compare to Ultegra/DA or Campy.
Given I am contradicting a few other forum members, I am inclined to think I am the one who is wrong.
My ee s are from 2015, but they are running in wide rims (4.5 SES). I once mounted a much thinner Fulcrum rim and the bite was completely different. So I suspect earlier generations were less meant for today's rim width. Just something to bear in mind if the op is looking for used ones.
In terms of putting them on an 8kg bike; unless it is steel fork and frame, I would tend to think that at that weight there are more effective options to reduce weight.
biwa
by biwa
Which "stronger spring" is this? Is it an official part?
C36
by C36
DHG01 wrote:I am not particularly impressed with ee; that would compare to Ultegra/DA or Campy.
The adjustment is indeed a bit sensitive and reading you, I recall switching to very narrow rim without adding spacers to the brake pads resulted in quite a low braking power.
If you still have them I would spend more time trying different setups.
oldturd
by oldturd
for me, they seem to pair better with sram levers than Shimano. braking between the two seem to be night and day.. or i could have been lazy with the shimano bike
