EE brakes
CustomMetal
by CustomMetal
So.. are they worth it? Especially on an 8kg bike which is almost as light as I can sensibily get it? Also how do they compare to the Sram red brakes?
Perdita- Burls Ti
Aurelia- Saffron Stainless/Carbon
Bertha - Trek Speedconcept
Verity - Sturdy Ti/Carbon Aero (incoming)
Serenity- Sturdy Ti (incoming)
Allegra - Sturdy Steel Lugged (incoming)
Jolene - Retired Aluminum
Lucendi
by Lucendi
If they are worth it to you or not really depends on what other components you can upgrade to what cost per lost gram.
They look amazing though; :)
CustomMetal
by CustomMetal
How is the braking compared to Sram red and DA?
Perdita- Burls Ti
micky
by micky
If you want Red/DA/SR braking power, stick to them.
EE are a good alternative with decent braking but lots of weight saving.
Depends on your priorities.
Lately a lot of people priority seems to be the braking part compared to weight saving.
neeb
by neeb
I have EE brakes on one bike and Record on another. The braking on the EEs is every bit as good as the campy brakes. You wouldn't think so comparing them off the bike, the Record brakes have a sharper "clack clack" feel when the pads hit the rims (maybe due to stronger return springs or a different pull ratio?), but when actually riding the performance of the EEs is superb. They seem to modulate very well. I also like the little hand screw to adjust the pad centering.
For me at least they are the best of both worlds - top notch performance and much less weight. At a price of course..
nickf
by nickf
Have them on 2 bikes. I would never use another rim brake caliper. Excellent power and feel. Easy to adjust, makes swapping between wheelset a breeze.
CustomMetal
by CustomMetal
Thank you all!
Perdita- Burls Ti
oldnslow2
by oldnslow2
CustomMetal wrote:
Sun Oct 11, 2020 6:14 pm
Save your money for something else.
wheelsONfire
by wheelsONfire
Argonaut sold their ready made Sram bike with EE as they were very much better with Sram than Sram Red.
I've used mine with Shimano and Sram and i say this, they're great!
If they worth the money is another thing! They will brake better than THM that is what i've been told and they also cost way less.
But again, value is up to you!
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
beanbiken
by beanbiken
Also here on two bikes with excellent results. Yes would buy again, the only negative to me is if you like to swap wheels that one set are much wider/narrow you may have to add/remove some pad spacers. Obviously once you know the correct number it is no biggie but an extra step needed
BB
Coffee & carbon
alcatraz
by alcatraz
A friend has a duraace bike (single mounting) and ee+sram levers (direct mount) bike, otherwise the rims and pads are the same. The duraace brakes have quite a bit more bite.
The ee aren't bad but the duraace are more confidence inspiring if you had to pick one for a terrifying descent. For normal riding they're all fine obviously.
It seems that "well modulating" brakes mean that you have to pull the levers more and get less initial bite. As such it comes down to personal preference because you're trading bite for control. What do you like in a brake?
torob
by torob
It really feels like EE brakes have capped rim brake innovation, forever. A genre-ender, in the best way. They're excellent.
Using Tapatalk
wheelbuilder
by wheelbuilder
Don't listen to naysayers, they perform flawlessly. Not as much absolute stopping power as 9100, but they perform very, very, well. Better than Red brakes in every measurable way. Better lever feel and modulation than 9100, but with less initial bite, and less panic-stop power, but nothing you need to actually think about or worry about. No flex at all, and the weight obviously speaks for itself. I would never even consider another rim brake if rim brakes are your preference.
edit to add, as evidenced by photo, powerful enough to use cork pads, without the slightest concern.
MeekMouse
by MeekMouse
Nothing but great things to say about eeBrakes, particularly how easy they are to adjust relative to finicky SRAM Aerolinks. I've moved on to disc on my daily driver, but am keeping the eeBrakes around for a future project bike regardless.
C36
by C36
Compared to the DA I haven’t seen power difference but the modulation appeared better on the EE.
Never before I had been able to feel, in such a fine manner, the wheel blockage limit. Really a pleasure.
Edit: that’s for a 63kg rider with a 6kg bike.
