Stiffest QR Skewer?
I ride a QR rear disc Dogma F8. When I'm out of the saddle I occasionally experience rotor rub. I figured its because the axle is flexing somewhat. I have TA front with a Carbon Ti axle and it works fine. The rear is the issue.
To reduce the flex, I wondered what the best QR axle would be in terms of stiffness. I've heard the 9100 DA QR is very stiff. Any other suggestions?
I'm currently running Enve Ti 135mm.
Thanks,
Mike
Thanks,
Mike
You have a frameset with QR rear and thru-axle front? Never seen one of those before.
I don't think the QR contributes very much to the stiffness of the axle, but a steel one would be less flexible than ti. Shimano, Campag etc rather than ultra-light QRs
- Dan Gerous
Enve Ti are very flexy, the Mavic made newer ones are better but still nowhere as stiff as Shimano and Campy... I also have an older disc brake road bike with QR, originally it had Enve Ti junk, I put standard Mavic QR I had laying around and that helped, the rear was not an issue with those in my case but the front still was.
Eventually I tried DT RWS Ti skewers which are basically bolt-ons but with a lever so still toolless and it helped tremendously, I would guess the steel version would be even stiffer but the weight is still better than Shimano/Campy and they are sold individually if you only need the rear.
Another vote for DT Swiss RWS, I get noticeably less pad rub with these. On the DT website, I think there are some numbers quantifying this.Dan Gerous wrote: ↑Wed Sep 30, 2020 3:07 pmEnve Ti are very flexy, the Mavic made newer ones are better but still nowhere as stiff as Shimano and Campy... I also have an older disc brake road bike with QR, originally it had Enve Ti junk, I put standard Mavic QR I had laying around and that helped, the rear was not an issue with those in my case but the front still was.
Agree with the above, skewers just provide a compression force to keep your chainstays together around the axel. Their contribution to axle stiffness is small.
It is the axle in your rear wheel which provides enough stiffness to keep the wheel spinning correctly and prevents too much movement.
As noted by other posters skewers with internal cams are much better at providing a compression force. Hex key skewers are good too.
If you have a brake rub issue and your frame dropouts are OK then also check the hub too.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
im on Enve TI, not an issue but keen on checking DA to see if im missing anything...Dan Gerous wrote: ↑Wed Sep 30, 2020 3:07 pmEnve Ti are very flexy, the Mavic made newer ones are better but still nowhere as stiff as Shimano and Campy... I also have an older disc brake road bike with QR, originally it had Enve Ti junk, I put standard Mavic QR I had laying around and that helped, the rear was not an issue with those in my case but the front still was.
Whats the difference between shimano hub HB-9000 and FH-9000?
thanks!
- wheelsONfire
Try Tririg Styx
https://www.tririg.com/store.php?c=styx
Bikes:
Open *UP* (2016.04.14)
i have some viewspeed ti ill sell you. pretty stiff.
