leverage ratio on internal is higher and the cam surfaces are better protected from the elements for smoother operation. if youre going external cam, you might as well go tooled IMO (viewspeed, control tech, etc)
Stiffest QR Skewer?
This. I never experienced any additional flex with my extralite streeters. If there is enough flex for your wheel to rub your rum brakes then you have other issues going on. Disc brakes rubbing, eh welcome to disc brakes.Nickldn wrote: ↑Wed Sep 30, 2020 4:31 pmAgree with the above, skewers just provide a compression force to keep your chainstays together around the axel. Their contribution to axle stiffness is small.
It is the axle in your rear wheel which provides enough stiffness to keep the wheel spinning correctly and prevents too much movement.
As noted by other posters skewers with internal cams are much better at providing a compression force. Hex key skewers are good too.
If you have a brake rub issue and your frame dropouts are OK then also check the hub too.
I have seen bikes with 12mm bolt-on axles rub disc when out of the saddle or even a tight turn one way or the other. Some of the hydro brakes are such tight tolerances any amount of frame deflection will cause the disc to rub. Not the skewer.
- wheelsONfire
It's not fun if you have issues with dics rub running through axles. Heard several complain about this!nickf wrote: ↑Thu Oct 01, 2020 3:39 amThis. I never experienced any additional flex with my extralite streeters. If there is enough flex for your wheel to rub your rum brakes then you have other issues going on. Disc brakes rubbing, eh welcome to disc brakes.Nickldn wrote: ↑Wed Sep 30, 2020 4:31 pmAgree with the above, skewers just provide a compression force to keep your chainstays together around the axel. Their contribution to axle stiffness is small.
How usual is it really?
Bikes:
Open *UP* (2016.04.14)
Sorry to drain the resource, but in terms of DA 9100 rear QR, I can only find 163mm for sale.
I'm under the impression my rear spacing is 135mm and therefore I'd need a 168mm skewer. Measuring my Enve QR and it seems even longer than 168mm. Dogma F8 Disk.
1. Will 163mm work?
2. If not, can you get 168mm in DA 9100?
Thanks!!
1. Will 163mm work?
Thanks!!
I was running a DA 130mm skewer on my gravel bike (135mm spacing) for a year with no issues. There's not a heap of thread engaged but the clamping force was fine and I had no issues even when banging about off road. No pad rub whatsoever on Ultegra disc calipers.Ultradog wrote: ↑Thu Oct 01, 2020 11:42 amSorry to drain the resource, but in terms of DA 9100 rear QR, I can only find 163mm for sale.
1. Will 163mm work?
Thanks!!
I have the Enve Ti (pre Mavic) and find them inadequate for holding the rear wheel on my rim brake bike. I still use it on my front wheel, as it is light and looks good, but am using the Campy skewers that came with my Eurus wheelset for the rear wheel. I've not had an issue with other lightweight Ti skewers in the past (Am Classic, Zipp). The Campy skewers -- which use a cam mechanism and larger contact areas -- hold much more securely; the only issue is that the lever is quite wide, which means that on my frame, they can only be closed in one direction or they interfere with the dropout/frame interface.
Thanks. Those are the Enve Ti ones I have also, inadequate is an understatement actually. I have tried other cam style ones like Roval, Mavic, Shimano as well but in the end I like the RWS more. Another single data point that I have is that my gf fell over quite a few times when she was just getting into biking and using clipless pedals. Each time she fell over, the wheel would shift with any of the other cam style quick release and it would rub the brakes. Have to loosen and retighten. Don't have this problem at all with the RWS. I have the road version levers on the RWS so they are not as bulky.CyclingGiraffe wrote: ↑Thu Oct 01, 2020 7:46 pmI have the Enve Ti (pre Mavic) and find them inadequate for holding the rear wheel on my rim brake bike. I still use it on my front wheel, as it is light and looks good, but am using the Campy skewers that came with my Eurus wheelset for the rear wheel. I've not had an issue with other lightweight Ti skewers in the past (Am Classic, Zipp). The Campy skewers -- which use a cam mechanism and larger contact areas -- hold much more securely; the only issue is that the lever is quite wide, which means that on my frame, they can only be closed in one direction or they interfere with the dropout/frame interface.
With Rim brakes at least you can increase the gap between pads and the wheel by 0.5mm by adjusting the brake cable, that'll quickly help reduce brake rub when sprinting.wheelsONfire wrote: ↑Thu Oct 01, 2020 6:20 amIt's not fun if you have issues with dics rub running through axles. Heard several complain about this!nickf wrote: ↑Thu Oct 01, 2020 3:39 amThis. I never experienced any additional flex with my extralite streeters. If there is enough flex for your wheel to rub your rum brakes then you have other issues going on. Disc brakes rubbing, eh welcome to disc brakes.Nickldn wrote: ↑Wed Sep 30, 2020 4:31 pmAgree with the above, skewers just provide a compression force to keep your chainstays together around the axel. Their contribution to axle stiffness is small.
Trickier with Disk brakes. Forks and chainstays will always flex, that's what they're designed for.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
I briefly had Dura Ace 9100 skewers, but found them to not fit my frame correctly when closed. Bought some Mavic titanium ones and find them to work just as well, as the titanium shafts are quite thick. They can be hard to find though. Totalcycling was the only place I could get them. Liked them so much I bought two pairs.
- wheelsONfire
Yeah i believe so to. Question is for those talking about drag, how much will this affect the outcome?
Bikes:
none. many/most only do it when out of the saddle in anger and its very minimal, like the lip of the rotor touching the pad; there's not full-on engagement with the pad.wheelsONfire wrote: ↑Fri Oct 02, 2020 12:19 amYeah i believe so to. Question is for those talking about drag, how much will this affect the outcome?
