Clinchers in Pro cycling
Yoln
by Yoln
With Alaphilippe win in second stage of Tour de France being the first win using clinchers in the history of le Tour, and the fact that new Roval CLX range won't be tubeless compatible, are we going to enter the era of clinchers in the Peloton?
source: https://www.cyclingnews.com/features/to ... armac-sl7/
Wilier “Cento Ramato“ : viewtopic.php?f=10&t=160943
Lynskey “the Do-it-all Helix” 🧬: viewtopic.php?f=10&t=161550
Hapsmo911
by Hapsmo911
Yoln wrote:
Wed Sep 16, 2020 9:28 pm
My guess is someone at Specialized screwed up after the molds were made. There is 0 reason not to offer your top of the line wheels without a tubless optiion regardless of their marketing. If weight was the issue, like they claim, we can all run tubulars?
Yoln
by Yoln
Hapsmo911 wrote:
Wed Sep 16, 2020 9:34 pm
I guess their point is that clinchers with latex tubes is both better in terms of RR and lighter overall (wheel + tire + tube/sealant) than their tubeless equivalents
TheRich
by TheRich
Yoln wrote:
Wed Sep 16, 2020 11:14 pm
They don't have the option to go tubeless on those wheels, so how could it be a choice between an option they have and an option they don't?
There is zero benefit in not making wheels tubeless compatible.
tommasini
by tommasini
And at the end of the article we learn that the clinchers were replaced the next day with tubulars. The sponsor promo opportunity was accomplished and now back to the safety and lighter weight of tubbies.
ichobi
by ichobi
If you look at the specialized sponsored each stage you will see that their aces tend to run clinchers. JA has been riding clinchers almost every day on the stage he breakaway.
Kamna won his stage on clinchers. He also rode it on the queen stage yesterday where he brokeaway. The rest of the guy seems to run tubular. It seems like this is the risk the teams are willing to take for the rr benefit
TobinHatesYou
by TobinHatesYou
Both Schachmann and Kamna have been on clinchers (sometimes tubeless) for their breakaway attempts. “Safety” is the only aspect where tubs matter. It’s been repeatedly shown with math that Crr differences to the thousandths are equivalent to several hundred grams worth of weight.
Singular
by Singular
TobinHatesYou wrote:
Thu Sep 17, 2020 8:36 am
There might also be an additional factors that plays a part - with for instance the new Roval models offered in only clincher models, the choice for the teams/riders would be to either choose old tubular wheels ("inferior" shape, weight, aerodynamics et cetera) or clinchers (with a potentially beneficial technological advantage in regard to for example aerodynamic concerns), not taking the one-to-one attributes of the respective system in consideration (weight, rolling resistance, safety and so forth).
Add to that the, ahem, emphasis from manufacturers for teams to use latest-and-greatest, there is not much of a surprise to see for example the Spez teams on new clincher wheels (if hypotetically all else would be equal - which it is not).
Yoln
by Yoln
TheRich wrote:
Thu Sep 17, 2020 12:37 am
According to Roval, the greater (compression) force put on a rim by a tubeless tyre requires extra material, “and that extra mass would have outweighed the benefits of tubeless tires”.
“From the Roval side, we recognize the potential of tubeless road tires,” a company representative said. “We evaluate everything in a holistic perspective in the light of what’s best for the rider we’re aiming to serve.
“For now the performance balance tips in favor of tube-type wheel/tire systems for the performance road rider (unless you have a team mechanic to glue on tubulars and a follow car with a spare wheel in case you puncture).
Right, but it has also been shown that Tubeless has similar CRR than equivalent Latex+Clincher setup:
And this is even without considering using Vittoria or Chalenge Latex tubes that have a lower CRR than the tested Michelin, so it's safe to say that in this very case, Clinchers would be faster than Tubeless. As well as lighter since it allows for the wheels to be made lighter
BikeEatSleepRepeat
by BikeEatSleepRepeat
Yoln wrote:
Thu Sep 17, 2020 5:19 pm
Indeed, the Michelin latex tubes are not especially light.
Vredestein Superlite Latex is only 48g and would most likely be the lighest/fastest set up of all.
Last edited by BikeEatSleepRepeat on Thu Sep 17, 2020 5:58 pm, edited 2 times in total.
Hapsmo911
by Hapsmo911
You are quoting specialized marketing? As a consumer I wouldnt pay $2500.00 usd for a set of wheels without the option to run them tubless. Maybe thats just me, and I dont currently run tubless.
As for pros using them. They get told what to use. Although if its me, descending at the speeds they do, I would want tubulars. But you can read into it as you see fit. I am sure there will be plenty of these wheels on the used market soon for you to get a good deal on :)
Yoln
by Yoln
Someone stated that "There is zero benefit in not making wheels tubeless compatible." I was just relaying Roval argument against that since I don't realy have the rim building expertise to verify wether it's true or not, sounds like a "believable" argument though
TheRich
by TheRich
Yoln wrote:
Thu Sep 17, 2020 6:00 pm
You've created a bit of a false dilemma though. Most people don't run latex tubes, it's a choice between butyl and tubeless. You CAN run latex and get tubeless level RR at the cost of lower durability, or you can run tubeless. That's what I mean by there being zero benefit.
Pros can do what pros do because they have a car with spares following them. We have to make compromises and those wheels should be made to suit the market where they're positioned price wise, and tube only makes them uncompetitive.
Hapsmo911
by Hapsmo911
My point is, these wheels are meant for the general public. So its stupid not make them tubless. specialized is going to spew as much marketing crap as they can because these wheels are stock on their flagship bike atm. So getting pros to use them here and there would help their sales. I mean look at this thread?
Were debating tubes for the pro peloton in 2020?
Yoln
by Yoln
TheRich wrote:
Thu Sep 17, 2020 6:16 pm
I don't think that's true, in my process at least, I started by latex before trying Tubeless as it seemed less big of an investment and less of a hassle to setup. For everyday riders, used to use clincher, Latex is the hassle free solution to get high level RR performance without the hassle of dealing with adding rim tape, buying sealant, making sure their wheels are tubeless compatible, getting tubeless ready tires, etc... With latex, you get $20 tubes, remove your butyl, place the latex ones, and that's it (and top up your tire pressure every other day haha :) )
Also, what we don't mention is that as far as GP5K are concerned, the Clincher/Latex setup offers much better ride feel and suppleness than the TL version
