mathias720
by mathias720 on Thu Dec 01, 2022 11:34 am
pipii wrote: ↑Mon Nov 28, 2022 10:33 am
Should be around 6.7kg as estimated with 8070 and wheels not that light.Still one or two weeks to wait for perfect setup.
Looking forward to seeing your final build. i always end up with extra weight and really cant figure where is from ( some is most deffinetly from brake fluid, but can figure rest)
on this build i ended up with around 250Gram i can figure
mathias720
by mathias720 on Fri Dec 02, 2022 2:13 pm
i 3d printed my own spacers. when i used the black inc handlebar. made me able to do custom height aswell.
didnt notice they made seatpost clamp and the stem divider thing.
interesting to see if anyone use it.
kode54
by kode54 on Sat Dec 03, 2022 11:46 am
I did as well. More for curiosity. Although the fork steerer insert should be light and do the same job given that it is squeezed in the flat ‘D’ are on front of the steerer. I was actually surprised that Factor used aluminum or similar material there and it was quite beefy/heavy.
I have to remove one spacer as I left the steerer longer just to dial in fit. I’ll probably replace it then, when I trim off the excess.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
ArtV
by ArtV on Fri Dec 09, 2022 1:22 am
mathias720 wrote: ↑Fri Dec 02, 2022 2:47 pm
just ordered a set of the stem cable splitter and the seat clamp. lets see how it is when it arriveves
I also bought the stem support and spacers but not the seat clamp. Noticed some seat posts as well but I already have the Darimo. Might be a more cost effective way to lose some weight.
tommyb
by tommyb on Sat Dec 10, 2022 9:19 pm
kode54 wrote: ↑Wed Nov 30, 2022 12:58 pm
When you’re saying stock Factor bottom bracket? If so, the answer is yes. Should work with no issues. A thin .5mm on DS is recommended by THM.
I have a Hambini in mine.
I don't think this is correct. THM has a 30mm axle, Shimano 24mm- how will the standard b/b for Shimano work with THM??
flmo
by flmo on Sat Dec 10, 2022 9:52 pm
The frame comes with a range of adapters.
CeramicSpeed T47A Aluminium cups / CeramicSpeed bearings with Wheels MFG 24mm BBRight Reducers/Adapters
kode54
by kode54 on Sun Dec 11, 2022 12:24 pm
tommyb wrote:kode54 wrote: ↑Wed Nov 30, 2022 12:58 pm
Factor include Wheels Manufacturing 24mm adapters that slide into each side of the 30mm BB. The included CeramicSpeed T47A is 30mm as well and the adapter are part of the frameset package.
- Factor LS Disc
kode54
by kode54 on Thu Dec 15, 2022 4:56 pm
More paint needed to cover up black carbon. I think the chrome is clear over raw carbon so I'm guessing that the chrome will be lighter.
- Factor LS Disc
inertianinja
by inertianinja on Thu Dec 15, 2022 5:11 pm
kode54 wrote: ↑Thu Dec 15, 2022 4:56 pm
I think the Flicker is clear over raw - I'm looking at mine right now and I can see the texture of the carbon.
