engsohere
by engsohere on Fri Jul 29, 2022 10:18 am
KAoslo wrote:Hi all,
Im in the process of ordering a Factor Ostro Vam frameset and have a couple of questions.
1. im 176 cm and 84 cm inseam. I ride a 53 Bianchi Oltre XR4 today with a 110 stem. Factor reccomends a size 52 with a 120 mm stem. Any here with similar measurements like me that rides 52? I guess im in the middle of 52/54, but I like my bikes to be agressive.
2. Im looking at bar/stem combo, not the integrated. Want a -12 stem, and like the Extralite Hyperstem or the Zipp Service Course SL stem, in combo with the either Black Inc Aero bar or 3T Aeroflux. Question is if I can fit the brake cables through these stems? Anyone who knows?
Thanks in advance for replies.
Cheers from Oslo.
I found this image of Zipp Service Course SL. It seems to have an opening with enough room for the brake hoses.
Sent from my A574BL using Tapatalk
kode54
by kode54 on Fri Jul 29, 2022 9:16 pm
KAoslo wrote: ↑Tue Jul 26, 2022 8:46 pm
Hi all,
Cheers from Oslo.
I;m 176cm tall and 80cm inseam and ride a 52cm Factor O2 VAM with 120mm stem. I just ordered a 52cm Ostro since it is roughly the identical geometry.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
KAoslo
by KAoslo on Sat Jul 30, 2022 12:01 am
kode54 wrote: ↑Fri Jul 29, 2022 9:16 pm
Hi all,
Cheers from Oslo.
Thanks, man. I compared the geometry for my current bike against the Ostro, and think I’ll go for the 52 with a 120 mm stem as the stack is a bit lower on the ostro.
wheelsONfire
by wheelsONfire on Sun Jul 31, 2022 4:24 pm
Hi all,
Cheers from Oslo.
Would be very interesting to get feedback on ride feel between the bikes (02 VAM and Ostro)
Bikes:
Open *UP* (2016.04.14)
FabianV
by FabianV on Sun Jul 31, 2022 4:38 pm
KAoslo wrote: ↑Sun Jul 31, 2022 4:20 pm
Any more input to the sizing? Anyone similar to my sice (176, 84 inseam) that rides a 52 Ostro Vam?
I'm 179 with a 84 inseam and ride a 54 Ostro with a 110m stem.
FabianV on Sun Jul 31, 2022 9:44 pm, edited 1 time in total.
Gary71
by Gary71 on Sun Jul 31, 2022 9:38 pm
I am 176 - 84 inseam and have a 54 Factor LS (-17 130 stem slammed). I believe the factor is similar to the O2, but slightly higher stack and longer chainstays.
kode54
by kode54 on Mon Aug 01, 2022 5:03 pm
wheelsONfire wrote: ↑Sun Jul 31, 2022 4:24 pm
Hi all,
Cheers from Oslo.
6.
I haven't ridden the O2 VAM since the Aethos (about 4 months or so)...and since they're both similar in type, I've retired the O2...so getting the Ostro will be a much different ride and purpose. Ended up getting the new version of the 6.7 Enves which will go on the Ostro. Will retire the 5.6 SES.
- Factor LS Disc
Mr.Gib
by Mr.Gib on Tue Aug 02, 2022 4:48 am
I have an Ostro due to arrive in about a month. After some ride time I'll give as complete a ride comparison as possible between O2, O2 VAM, and Ostro.
Creative79
by Creative79 on Fri Aug 05, 2022 5:42 am
ericlambi wrote: ↑Mon May 23, 2022 12:34 am
Here's an unexciting photo of my finally repainted and rebuilt Ostro. No more pink and yellow! The original barstem was too long for me and I went through a bit of an odyssey trying to replace it with a 36cm bar[stem] that would have a more aero profile than the Black. In the end I have a 36cm Black handlebar and FSA stem. On the heavy side I've got vectors and the DA crank. On the light side I have the Darimo post and FarSports wheels. Weight is 7.15kg according to my luggage scale, size 52.
My mechanic advised that the post is too loose and he had to use copious amounts of carbon paste, over torque the clamp, and is still worried it won't hold, but one ride went by without issue.
hello, how is the darimo seatpost? is it 0 or 15mm? I'm looking for 0mm.
cyclespeed
by cyclespeed on Fri Aug 05, 2022 10:24 am
Creative79 wrote: ↑Fri Aug 05, 2022 5:42 am
https://www.youtube.com/watch?v=FjbV8uwLOGQ
All you need to know
jude188
by jude188 on Mon Aug 08, 2022 12:55 pm
Has anyone had luck running the Tarmac SL7 stem with the Ostro? Seems like it would be a good combination.
Perhaps with the Prime Primavera bars in a 36cm size. Narrow, aero, adjustable, travelable, ideal.
CustomMetal
- Moderator
by CustomMetal on Mon Aug 08, 2022 5:34 pm
jude188 wrote: ↑Mon Aug 08, 2022 12:55 pm
Yes, Ronald Kuba- YouTube
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
