kode54 wrote: ↑Wed Oct 26, 2022 10:59 am
mathias720 wrote:cyclespeed wrote: ↑Mon Oct 24, 2022 8:26 am
mathias720 wrote: ↑Mon Oct 24, 2022 6:46 am
to those of you who have upgraded for the darimo seatpost for the factor ostro vam.
is the setback version also 25mm as the original one and the straight 0 setback?
i know some manufactures have had different ways of meassuring this. and also that darimo some times makes 15mm setback.
also if you did get the 0mm setback does it come with the loop seat mount or the classic bolt and clamp mechanism?
also show pictures!!!
i am going to buy one after my bikefit but cant get a hold of darimo for this info, have tried 3 times now.
I have the zero setback Darimo on my Ostro. You can see it on my Youtube channel.
And yes, the Ostro IS more aero than the SL7. Because I said so......
i saw your video. do you know if its true 0mm? so 25mm difference from the original 25mm setback?
Not sure if it’s exactly 0 setback. I just got my Darimo seatpost for the Ostro. Due to the positioning of the saddle clamps, it appears to be about 10-15mm of setback. I’ll post a pic later.
just got an answer from darimo.
"We have 𝘁𝘄𝗼 𝗺𝗼𝗱𝗲𝗹𝘀 with different setback
𝗧𝗵𝗲 𝗳𝗶𝗿𝘀𝘁 is 5mm forward (as factor measures it) & 𝟭𝗺𝗺 𝘀𝗲𝘁𝗯𝗮𝗰𝗸 from the center of the shape.
𝗧𝗵𝗲 𝘀𝗲𝗰𝗼𝗻𝗱 has a more common shape, 9mm setback as factor measures and 𝟭𝟱𝗺𝗺 𝘀𝗲𝘁𝗯𝗮𝗰𝗸 from the centre of the shape."
Seems like the 1mm forward is 30mm further forward that the original factor 25mm setback
and the 15mm setback is 16 mm further forward that the original 25mm setback.
is yours the straight version or setback version ?
