Factor Ostro
KAoslo
by KAoslo
ArtV wrote:
Fri Feb 03, 2023 12:26 am
Agree, that looks great. If dad jokes are permitted.......it looks all-white.
Haha :-D thanks!
borist
by borist
Looks awesome!
Was this done through the Prisma studio? Or did you get it custom painted?
KAoslo
by KAoslo
borist wrote:
Fri Feb 03, 2023 7:34 pm
Looks awesome!
Thanks, man.
Prisma studio, but ordered it from Factor through a local shop.
kode54
by kode54
Looks very nice and clean without additional color splashes.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
ArtV
by ArtV
Factor has released their new integrated aero bar/stem
New bar/stem: 398 g (42 cm x 110 mm)
Regular bar/stem: 320 g (420 mm x 110 mm)
Was looking forward to it, but I'll pass.
Sent from my SM-X800 using Tapatalk
LanceLegstrong
by LanceLegstrong
ArtV wrote:
Sat Feb 11, 2023 12:33 am
Ooh, that's a big weight gain. I have the current bar/stem combo on my Tarmac and love it. Don't think I'd spring for the new set for a little more aero and that weight gain.
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
fidracer
by fidracer
They are shipping the new aero barstem on all Ostros as of January 1. It's not weight weenie. A 40x110 is 390g without the top cap, 402g with it. Maybe subtract a gram or two for the white tubes. It looks cool though, and doesn't have the indentations along the bottom for externally routed cables like the non-aero version.
kode54
by kode54
Bottom does look cleaner and the shape as well. How's the top look? Doesn't have a huge back sweep as appears on website. I do like the 7 degree flare but not the extra weight. Can you measure the front to the back width? looks a bit thicker.
- Factor LS Disc
fidracer
by fidracer
The backsweep is not huge, but definitely noticeable. It's about 47mm deep (front to back) by the inside radius, 40mm deep on the outside, and 18mm thick (top to bottom). By contrast, I think the non aero barstem is 35mm deep (front to back) all along.
The flare appears to start after the lever clamp position, so I think the levers will sit square vertically and not be tilted over. A size 40 measures 40cm c-c on the hoods, and 43cm c-c on the drops.
AndreLM
by AndreLM
I agree that the weight gain is hard to swallow, but to Factor's credit, they have tons of options... including 36cm wide bars with 90-130mm stem combinations.
Sent from my Pixel 7 using Tapatalk
FactoryMatt
by FactoryMatt
any rumors of an updated frame coming out or do yall think this will remain current for awhile? unfamiliar with factors release schedule.
ichobi
by ichobi
The One is probably due for an update. If it’s going to come out it will be this year. Ostro will probably remain the more rounded option. Not sure much can be improved on it honestly.
mrlobber
by mrlobber
ichobi wrote:
Sun Feb 12, 2023 10:29 am
A pure all-out aero bike would be interesting from Factor, although they likely would sell only a handful of those.
Agree on the Ostro, plus, even disregarding the steerer saga, they likely have done several undisclosed updates already for it in the lifecycle of the model, given the likely increased weight trends observed with the bike.
kode54
by kode54
fidracer wrote:The backsweep is not huge, but definitely noticeable. It's about 47mm deep (front to back) by the inside radius, 40mm deep on the outside, and 18mm thick (top to bottom). By contrast, I think the non aero barstem is 35mm deep (front to back) all along.
Good to know. Thx for the measurements!
- Factor LS Disc
MysticRiver
by MysticRiver
Speaking of aerobars - I'm hoping to use my Ostro in a Triathalon and would ideally use my existing barstem. Does anyone know of TT extentsions/bars that woudl work for the one piece barstem? I have found this product though not sure the sizing will work...
https://www.controltechbikes.com/products/item/417.html
